Onkyo HT-R592 DSP D808K013DTP BIN File Request and Reflash Procedure
ztransformlol 705 4
  • Need BIN file and reflash procedure for D808K013DTP
    #1 21656810
    ztransformlol
    Hello Everyone. I noticed we have valuable Onkyo specialists here and I need a hand with one of mine. I have a model HT-R592 and I did perform some repairs due a short circuit on power supply. For short, I finally replaced the DSP D808K013BTP by a D808K013DTP. The issue is: I have "????????" at DSP debug and I think I need to reflash this guy. So here is the question: Does anyone have the BIN file for this? And Procedure recommendations to perform it? I would like to say thank you, in advance.
    AI: Do you have access to a programmer or the necessary hardware to perform the reflash on the DSP chip? If so, could you specify which one(s) you have?
    Not yet.
    AI: Do you still have the original DSP chip, and if yes, is it possible to read or extract the BIN file from it?
    Yes I have the old one, but it was fried.
    Elektromonterek
    Help: 60
    Rate: 128
    Software is not on DSP. And what IC did you buy - add photo because there are sth ike 99.9% faked which is totally visible.
  • Requesting reflash guidance for DSP showing ????
    #3 21697394
    ztransformlol
    >>21686244 @Elektromonterek @Elektromonterek thank you for your interest to help me. So, I attach the picture of the IC. You must notice I took a shot of the old one and the new one.
    About the affirmative : "Software is not on DSP" . I've read a bunch of comments that when we have "?????" on DSP info, is necessary to reflash the device. If you can provide more info how to solve it, I will be glad.
    Two Texas Instruments chips on a PCB, labeled as old and new
  • #4 21698084
    Elektromonterek
    Help: 60
    Rate: 128
    Soft you surely don't need it since you installed a paint job 🤣🤣 But the best thing is why there was a DPTP3 version of the chip on the board, since you wrote that you replaced the BPTP. The effect of someone who has no idea and still buys fake chips. Do you really not see the differences?
  • #5 21700857
    ztransformlol
    ]21698084 >>21698084
    Hey @Elektromonterek . Thanks for the reply once more. I misspelled the BPTP , I replaced by same number. Unfortunately, this was the closest I been able to get. Of course I saw slight differences between those two, but I have no alternatives. So, bottom of line, this will go to trash can, right? Do you mind to tell me if I have any alternative? Or anyone who read this topic?
