FAN7842 Bootstrap Gate Driver Placement: Closer to MCU or Power FETs?
225 7
  • #1 21659753
    Erik Hatinen
  • Place bootstrap driver close to the power FETs
    #2 21659754
    Cody Miller
  • #3 21659755
    Erik Hatinen
  • #4 21659756
    Martin Thompson
  • #5 21659757
    Alec
  • #6 21659758
    Martin Thompson
  • Bootstrap ic input ringing may need one-shot buffering
    #7 21659759
    Alec
  • #8 21659760
    Martin Thompson
In a half H-bridge motor drive using the FAN7842 bootstrap gate driver IC controlled by an MCU, the consensus is to place the bootstrap IC and associated circuitry as close as possible to the power FETs rather than the MCU, which is approximately 8 inches away. This placement minimizes the length of high current and high voltage traces, reducing current loop area and potential EMI/EMC issues. The gate driver outputs are low impedance, high current, and high slew rate signals, making short trace lengths critical to avoid inductance and ringing. Conversely, the MCU outputs driving the bootstrap IC inputs are typically high impedance and low current, so longer traces are less problematic but may still require careful signal integrity considerations. If high slew rates on MCU outputs cause signal ringing or multiple threshold crossings at the bootstrap IC input, solutions include simulation with IBIS models and proper line termination rather than adding extra components. Overall, layout prioritizes minimizing high current path lengths near the FET gates to ensure reliable switching and electromagnetic compatibility.
