How are Power Mosfets driven by Gate Drivers if the Vgs needs to be so high?
405 6
  • High-side gate drive needs a floating supply
    #1 21681166
    Michael Ferguson
  • Source stays near 4–5 V in constant-current sink
    #2 21681167
    Rick Curl
  • Gate drivers must be connected gate-to-source
    #3 21681168
    PeterTraneus Anderson
  • #4 21681169
    Richard Gabric
  • Floating high-side drivers keep Vgs 12–18 V above source
    #5 21681170
    Ian Stedman
  • Source follower explanation for MOSFET gate drive
    #6 21681171
    inshah khan
  • Use source-referenced gate drive for 200 V MOSFET switching
    #7 21681172
    neha dubey
The discussion addresses how power MOSFETs are driven by gate drivers when the required gate-to-source voltage (Vgs) is high, especially in circuits with high drain voltages (e.g., 200V+). It clarifies that the MOSFET source voltage is not equal to the high drain voltage but typically much lower, often just a few volts, as the source voltage follows the gate voltage in a source follower configuration. Gate drivers output current to charge the MOSFET gate capacitance, with typical output voltages around 10-30V, which is sufficient to achieve the necessary Vgs for switching. For high-side switching with high supply voltages, specialized floating or bootstrap gate driver ICs (e.g., Infineon IR2125, Linear Technology LTC7001) maintain the gate voltage above the source voltage by 10-18V, enabling proper MOSFET turn-on. The UCC20520 gate driver is designed for power converters or H-bridge circuits and may not be suitable for simple high-voltage switching without additional level shifting or floating supplies. Using P-channel MOSFETs or adding level shifting components like resistors and zener diodes can also be solutions depending on the circuit topology. The key is that gate drivers are connected between gate and source, not gate and ground, to ensure the correct Vgs is applied regardless of the high drain voltage.
