The discussion addresses how to calculate the maximum current that can safely flow through a cable without causing insulation breakdown due to overheating. The key concern is the cable's ampacity, which depends on conductor size, insulation type, and thermal limits. A standard example cited is a PVC insulated copper cable with a cross-sectional area of 2.5 sq-mm, which typically supports a maximum current of 15 Amps according to design standards. Several resources and calculators were recommended for quick ampacity estimation, including websites like powerstream.com and xtronics.com, which provide formulas and wire gauge ampacity tables. The conversation emphasizes the need for standard formulas and references to established electrical standards for accurate current rating calculations. AI summary based on the discussion. May contain errors.
