Is there a way to measure how much electricity a person has received, for instance after an electric
270 9
Can a person’s received electrical shock be measured afterward with a device that detects how much electricity they got?
No—after the shock, there is no residual voltage left behind on the person, so you cannot wave a device over them to measure how much electricity they received [#21679818] The amount can only be inferred indirectly from the circumstances, such as the shock source, entry and exit points, and the resistivity of the skin and tissue [#21679820] It is the current through the body that causes damage, not “electricity levels” remaining afterward [#21679820] The thread notes that fatal shocks often occur around the 100 mA range, while higher currents more often cause severe burns and tissue damage [#21679820] In a fatal case, the source and injuries may allow a rough estimate of the power involved, but not a direct measurement after the fact [#21679818][#21679820]
  • #1 21679817
    Erik Haugen
  • No residual voltage remains after a shock
    #2 21679818
    Rick Curl
  • #3 21679819
    Erik Haugen
  • Fatal shocks can occur at about 100 mA
    #4 21679820
    Richard Gabric
  • #5 21679821
    David Ashton
  • Temperature rise as a measurable effect of AC exposure
    #6 21679822
    Erik Haugen
  • #7 21679823
    David Ashton
  • #8 21679824
    Erik Haugen
  • AM radio and sound meter for low-frequency detection
    #9 21679825
    David Ashton
  • #10 21679826
    Erik Haugen
There is no residual electrical charge or voltage left in a person after receiving an electric shock, making direct measurement of the amount of electricity received impossible. The damage caused by the shock can sometimes be used to estimate the current involved, which is the primary factor in injury severity. Fatal shocks typically occur around 100mA, while higher currents cause burns and tissue damage. Devices like RF field strength meters can detect radio frequency or microwave energy but cannot measure low-frequency AC current directly. Low-frequency AC can be detected using an amplifier and coil or sensitive AM radios. Infrasonic audio frequencies (below 20 Hz) may cause physiological effects such as nausea and disorientation and can be measured with sound level meters, though these are unrelated to electrical measurement. Non-lethal crowd control devices emitting microwave or RF energy may cause temperature increases detectable by specialized sensors, but no handheld device exists to "wave over" a person to measure electrical exposure post-shock.
