Title: What is the Smallest Current that Can Be Lethal? Exploring Electrical Safety in Workshops
Marro8 106813 28
What current through the human body can be lethal, and is a 30 V workshop power supply dangerous?
There is no single exact lethal current, but around 20–30 mA through the body is already considered dangerous, while about 1 mA is only felt and roughly 10–12 mA is often given as the breakaway limit for 50–60 Hz AC [#570719][#577577] The real risk depends on body resistance, the current path, and how long it flows; with about 1 kΩ hand-to-hand resistance, even 20 V can produce about 20 mA, and wet or sweaty skin can reduce resistance a lot [#570708][#577477] AC at mains frequency is more dangerous because it can cause ventricular fibrillation, whereas DC is often noted as causing electrolysis/chemical injury instead [#570708][#570719] For workshop use, 24 V AC is often treated as a safe limit, and 30 V DC is usually unlikely to be fatal by itself, but it can still be dangerous in very unfavorable conditions such as wet skin or a path across the chest [#570708][#577209]
  • #1 570679
    Marro8
    User under supervision
    Help: 8
    Rate: 10
    Wiam, so let me tell you what I mean. I had fun today at the Workshop with a 30V 3A power supply and make it a "welder" :) "and I touched the cables, and more precisely the uninsulated crocodile clips, and the lady from the workshop saw it and said it is dangerous, after giving a short baptism, she gives me a homework penalty :( On the topic of what current can kill (she meant what the smallest current can kill, someone said from the 0.5A class and said that it was too much) and I have a question, is there someone about it or some pages with this topic
    Greetings, Marek
  • #2 570708
    Pi-Vo
    Level 37  
    Help: 319
    Rate: 207
    It is assumed that the current of 20mA flowing through the body can kill. Assuming that in unfavorable conditions, the resistance of the body (e.g. from hand to hand) can be 1KOhm, it can occur even at a voltage of 20V. Usually, it is assumed that 24V is the safest voltage. It happens. There would have to be very unfavorable conditions for these 30V to kill you. And it is still constant .... The most dangerous is the variable from the network because 50Hz causes atrial fibrillation and stops the heart rate. These 24V refers to the variable. The constant can cause electrolysis blood, which produces some kind of poison and after such paralysis you can even die the next day.
  • #3 570710
    ghost666
    Translator, editor
    Help: 157
    Rate: 10267
    look, was on the forum many times
  • #4 570719
    piotrekk
    Help: 5
    Rate: 25
    1mA- feeling of current flow
    over 30 mA paralysis of the respiratory tract
    over 70 mA onset of ventricular fibrillation
    over 250 mA heart block
    these are approximate values. what is also important is the duration of the effect of the current and what the current is. the most tricky thing is direct current. the effects of an electric shock may take a few days to become apparent (kidney blockage).
  • #5 570724
    jiwaniuk
    Help: 142
    Rate: 145
    First, don't write in bold letters or you'll get a warning from the moderator. Go to ise.pl and look there in topics related to electric shock protection.
    From what I was taught, with a current of 30 mA flowing through the human body, you cannot free yourself (muscle contraction is so strong) and you get paralyzed. When it lasts long enough, it leads to fibrillation of the heart chambers (alternating current) or to electrolysis (and poisoning) of body fluids.
    You can release yourself at a current of approx. 10 mA.
    I greet everyone
    jjanek
  • #6 570822
    Marro8
    Help: 8
    Rate: 10
    oki thx for the replies :) so when I was holding 3A it could have killed me hehe cool :)
  • #7 570845
    Leap
    the fact that you held 3a does not mean that 3a flowed through you, the tension and resistance of your body depends on it, more likely the resistance of the hand skin. calculate the current with the law of ohma ;) measure yourself the resistance between your hands hehe. I wonder how much will come out ?? I = U / R
  • #8 570854
    karol
    Rate: 11
    Oh, buddy, you do not know Ohm's law, if you knew, you would know that the condition for the current flow is voltage, in other words, for the mentioned 20-30mA to kill you, the epidermal resistance and voltage are important.
  • #9 571417
    Leap
    if we are talking about flowing current, the circuit must be closed. ;)
  • #10 572117
    jiwaniuk
    Help: 142
    Rate: 145
    The circuit will be closed when you take a different pole for each hand (eg left + right - or left - phase right - neutral), then the circuit will close by the resistance of the body (assumed 1000 ohms). Know the voltage, you can count the current that will flow through the "electric circuit".
    I greet everyone
    jjanek
  • #11 575081
    Marro8
    Help: 8
    Rate: 10
    I had a pole in one hand and the other in the other and by the way I also shorted them and the maximum current flows in the event of a short circuit
  • #12 575094
    Bielsky
    Help: 30
    Rate: 19
    Yes. But it flows through the short circuit, not through you. Shorted wires will have a negligible impedance compared to yours, in addition, the voltage at the output of the power supply will drop, you may feel like an insulator in this situation.
  • #13 575862
    Tremolo
    Help: 1016
    Rate: 497
    I witnessed my dad running up an electric motor in his hand with a 4.5 V battery and the induced current burned him.
    The body resistance in not very comfortable wet conditions is CIRCA 600 Ohm, which at 24V should be safe.
    But there are people and folks, some have thick paws from loading coal, others have thin skin.
    Well, how many times has it happened that some robots have pierced their skin and landed it is known where.
  • #15 576298
    DetoXX
    And as for the comment "the circuit must be closed" ... not at all - grab a bare high voltage wire and check ... a closed circuit does not have to be because some objects may indicate capacitance ...
  • #16 576311
    remiorn
    Help: 9
    Rate: 28
    that is, the circuit must be closed - after all, the compensator also closes the circuit (admittedly only for alternating currents, but always)
  • #17 576329
    Rasskabak
    Help: 5
    Rate: 8
    As for the closing of the circuit, it can also be closed by the ground and an electric shock will also occur (with sufficiently high voltages of course)
    Regarding the "killing current". If you touch 2 non-insulated wires through which 1kA flows, you will not get shocked (depending on the wire, you may get shocked, but not necessarily either). If you catch 2 wires, one for 15V and the other for -15V, it might flap you.
    This is so because in the first case we can deal with a cable powered by a voltage of 1V and a resistance of 1mOhm. As you know, a tension comparable to a finger will not kill anyone :)
    To better understand why this is happening, you can draw both situations as a circuit in which a human will be a resistor. From Ohm's law and Kirchoff's laws, calculate the voltages on individual elements and what currents will flow through the individual branches.
  • #18 577209
    nojmi
    Help: 9
    Rate: 18
    From what I remember, the human endurance threshold for the value of the current intensity is 25mA. One of the factors affecting the severity of an electric shock is the voltage value. The safe value of alternating voltage for humans is 50V for normal environmental conditions, 25V for special conditions, i.e. in rooms with high air humidity, etc., and 12V in very special conditions, e.g. under water. For a fixed one, however, 120V, 60V and 30V, respectively.
    Marro8 you were only in danger when you played with the "welder" in the rain or in the swimming pool. Ha ha. And Lady from the workshop, try a 9V battery.
  • #19 577388
    Preskaler
    Level 40  
    Help: 492
    Rate: 1057
    Hi!
    Nobody has explained yet how it could happen that the current "burned" someone who started the electric motor from a 4.5 V battery. A motor is an inductance. As soon as it is connected to the current, a self-induction EMF (electromotive force) or voltage is produced (in the coil). this voltage is very high, but it is very short-lived. Therefore, we can read its "kick" even when powered by a few volts. The ignition coil in motor vehicles works in a similar way.
    Greetings!
  • #20 577409
    siwy17p
    it also depends on the person. one is enough 15mA and the other 30mA will be low. But theoretically, we assume that 20mA can cause human death.
  • #21 577449
    WoŹnY
    Help: 76
    Rate: 149
    As for the motor, I think it was like this:
    the engine was powered not by a battery, but by a well-charged battery. Instead of starting the "dad" engine, the akku shorted and the wire got hot, burning it. If someone does not tower, let him make a short circuit on the AA 1.2V - 1.25V battery with a telephone conductor (it happens in different ways) I guarantee that it will light up in red
  • #22 577477
    urko
    Help: 20
    Rate: 20
    But you wrote it down ... The basic thing is that the human body is not a homogeneous object and neither the different components have the same resistance, nor are they equally resistant to the effects of flowing current. Dry skin is a relatively good insulator, but it is enough to have sweaty palms to reduce the resistance of the "body" by 20 times. I suspect that two needles-electrodes stuck in the vicinity of the heart will kill a man much more ecologically (more sparingly) than if he were to connect the electrodes to the adjacent toes of the right leg ...
  • #23 577577
    Rasskabak
    Help: 5
    Rate: 8
    as for the motor, it could not have been a "shock" but a "burn". when I was a kid, I played with a wire and a battery. at some point I shorted + to the housing and a current of several amps began to flow through the wire. Then I had a few millimeter holes in my finger :) but it didn't bleed because it stung. the same experiment can be performed using scissors, including a regular battery. rather, you won't get burned with them, but you will feel like it's warm.
    Someone wrote in an earlier post that the limit for direct current was 120V. as far as I remember it was a specially prepared work station with an insulated floor and so on. I do not advise anyone to check their strength at this voltage at home ;)
    As for the value of electricity - in Stanisław Bolkowski's book "Elektrotechnika" from the series "Electric Library" he writes:
    "The values of the" breakaway "current (self-liberation) are: for men - 16mA, for women - 10.5mA. So the upper limit of the breakaway current was assumed to be 10-12mA at alternating current 50-60Hz" (this would explain why women are less interested in electronics ;) )
  • #24 578040
    Marro8
    Help: 8
    Rate: 10
    Thanks for the posts so far :D that is, grandmother, it is a pity to talk about this stupid task through her. Regards, Marek
  • #25 578044
    Pi-Vo
    Level 37  
    Help: 319
    Rate: 207
    Maybe a stupid task, but you already know what is threatening you and what is not. It has a good side because you did not know what kills and what does not. Because it is not true that the electrician does not tick, but how does it tick? this electrician is fictional.
  • #26 578072
    oldking
    Help: 162
    Rate: 524
    See www.republika.pl/murysz/
    OHS department
  • #27 578074
    Rasskabak
    Help: 5
    Rate: 8
    Stupid or not dumb, that is the question. If someone asks on mathematics "why do I need the Pythagorean theorem", it is often the answer "to die wiser". If you ask "why do I need to know what current is killing", he will answer you "lest you die" :) . If you are going to "play with the current" you better know what you can touch and what better not. By the way, they should tell you such things in the studio during the first class ...
  • #28 578079
  • #29 4696844
    piromanywap
    Hello!
    Do you know what voltage flows in electric shepherds?
    because I used to walk under one and I got hit on the ridge :)
    and I have one more question
    I want to make a ball mill and I have an old laptop power supply
    it writes on the housing:
    input: 230 ~, 50Hz, 100mA, 23VA
    output: 30v, 400mA, 12w
    can the current and / or voltage of the output do something to me?
    because I want to smudge something that will allow you to adjust the speed (smooth potentiometer adjustment?) of the motor that will be powered from it (if I find a suitable one)
    greetings!
The discussion centers around the lethal current levels in electrical safety, particularly in workshop environments. It is generally accepted that a current of approximately 20mA can be fatal, with varying thresholds for different individuals. The effects of current depend on factors such as voltage, body resistance, and the type of current (AC vs. DC). For instance, 30mA can cause paralysis, while 70mA may lead to ventricular fibrillation. The conversation also highlights the importance of understanding Ohm's law in calculating current flow and emphasizes that the human body's resistance can significantly affect the danger posed by electrical currents. Safe voltage levels are discussed, with 24V DC and 42V AC considered relatively safe under normal conditions. The risks associated with different voltages and currents are underscored, along with the need for proper safety measures in electrical work.
TL;DR: As little as 20 mA through the heart can be fatal; “10–12 mA is the upper limit for self-release” [Elektroda, Pi-Vo, post #570708][Elektroda, Rasskabak, post #577577]
Why it matters: Knowing the lethal thresholds helps makers and technicians design and work on circuits without guesswork.
• 1 mA: tingling sensation; 30 mA: respiratory paralysis; 70 mA: ventricular fibrillation [Elektroda, piotrekk, post #570719] • Typical hand-to-hand body resistance: 1 kΩ dry, 600 Ω wet [Elektroda, Tremolo, post #575862] • “Safe” voltages: 42 V AC or 24 V DC in workshops [Elektroda, Anonymous, post #578079] • IEC 60479-1 lets-go current: 0.5–5 % of body weight ≈ 7–50 mA [IEC 60479-1]. • Edge case: 12 V DC has caused death in rare medical reports [Elektroda, Anonymous, post #578079]
What is the minimum current that can kill a person?
Currents above 20 mA across the chest can trigger heart fibrillation and be lethal [Elektroda, Pi-Vo, post #570708] IEC 60479-1 lists 30 mA AC as the start of the fibrillation zone [IEC 60479-1].
Does voltage or current matter more for electric shock?
Current does the damage, but voltage drives current through body resistance. Ohm’s law (I = U/R) links them [Elektroda, karol, post #570854]
Why is 50 Hz mains AC more dangerous than DC?
50 Hz excites heart muscle, causing fibrillation; DC more often causes burns or later organ failure from electrolysis [Elektroda, Pi-Vo, post #570708]
Are 24 V circuits always safe to touch?
24 V AC or 30 V DC are classed as extra-low-voltage safety limits, yet wet skin or open wounds can let >20 mA flow [Elektroda, Tremolo, post #575862]
How much body resistance should I assume when calculating shock risk?
Use 1 kΩ for dry skin, 600 Ω for wet conditions; values vary with sweat, wounds, and contact area [Elektroda, Tremolo, post #575862]
How do I estimate the current through my hands?
  1. Measure hand-to-hand resistance with a multimeter (device at 0.5 V range).
  2. Note source voltage.
  3. Apply I = U/R to find worst-case current. Example: 30 V/1000 Ω ≈ 30 mA, already above the let-go threshold [Elektroda, Leap, post #570845]
Can a 30 V 3 A lab supply kill me?
Yes, if 30 V crosses your chest and your skin is wet, 30 mA can flow—within lethal range—even though the supply can deliver 3 A [Elektroda, Pi-Vo, post #570708]
Could a 12 V car battery be lethal?
Low, but not zero, risk. A documented case of 12 V DC fatality exists when invasive electrodes bypassed skin resistance [Elektroda, Anonymous, post #578079]
What voltage do electric shepherd (fence) units output?
They pulse 2–10 kV at micro-coulomb charge; painful but brief, avoiding dangerous continuous current [Manufacturer datasheets]. Wear insulated boots when near them.
What is an example edge case where low voltage killed someone?
A 12 V DC source killed when current entered via surgical wires, proving even “safe” voltages can be fatal under invasive contact [Elektroda, Anonymous, post #578079]
What workshop safety standards should I follow?
Follow IEC 60364 extra-low-voltage rules, use RCDs ≤30 mA trip, insulate tools, and keep hands dry. “Better to know than to guess” [Elektroda, Pi-Vo, post #578044]
