Effect of Constant vs Variable Current on Human Body: Comparing Voltage & Exposure Time
mirekkk:) 38639 15
Which is more dangerous for the human body: constant current or variable current, assuming the same voltage and exposure time?
There is no single universal answer: the danger depends on the current path through the body, frequency, voltage, and exposure time [#4324292] In practice, 50 Hz alternating current is often considered more dangerous because it can cause ventricular fibrillation and is harder to let go of than direct current [#4324318][#4332992] Direct current has different hazards: stronger electrochemical effects, including body-fluid electrolysis, and muscle contraction that can also be serious [#4329115][#4332992][#4329477] So the two types are harmful in different ways, but for mains-frequency AC the heart-fibrillation risk is the main concern [#4324318][#4332992]
  • #1 4323935
    mirekkk:)
    Help: 12
    Rate: 17
    Hello. Which current is more dangerous for the human body, constant or variable, assuming the same voltage and time of exposure?
  • #2 4324082
    MMarcin76
    Rate: 19
    they were definitely standing
  • #3 4324148
    marcin101010
    It depends on what installation.
    If the transformer is earthed, it is permanent because if you touch - or +, you risk electric shock with good earthing.
    If it is not earthed (secondary winding), an electric shock can occur when you touch - and +. The same goes for the transfer voltage.
  • #4 4324266
    MMarcin76
    Rate: 19
    the colleague above is right, but I considered it in terms of its impact on the human body
  • #6 4324292
    jantrzu
    Help: 7
    Rate: 16
    In my opinion, the answer is more complicated and the question is too general. The flow of electricity through the body, and in fact its path, causes different reactions of individual organs. Their reaction depends not only on whether it is a direct or alternating current, but also depends on other quantities, e.g. frequency, voltage, flow time ... etc.
    So there is no unequivocal answer to such a general question.
  • #7 4324318
    neo_dc
    Level 32  
    Help: 178
    Rate: 211
    I can also add that when it comes to the 50 Hz AC current, it is dangerous because it can cause fibrillation of the heart chambers.
    The steady "fry" more if I put it that way; p
    If the frequency is much higher, there is an epidermal effect and it does not cause any harm to the body.
    As a colleague wrote above, this is a complex problem, but you can also find a lot on the Internet and in books (they do not bite).
  • #8 4324321
    Maly
    Help: 195
    Rate: 336
    Gentlemen
    Swap is much more dangerous! Especially 50Hz
  • #9 4324502
    forestx
    Rest in Peace
    Help: 299
    Rate: 496
    Gentlemen, don't talk, just think. What are the values of safe voltages?
    http://pl.wikipedia.org/wiki/Napi%C4%99cie_bezpieczne " target="_blank" rel="nofollow noopener ugc" class="postlink inline" title="" > http://pl.wikipedia.org/wiki/Napi%C4%99cie_bezpieczne
    So, since the safe voltage value is higher for direct current, it is probably logical that alternating voltages are more dangerous.
    Unless the standards were invented by idiots.
  • #10 4329115
    HeSz
    Electrician specialist
    Help: 97
    Rate: 198
    The discussion is of the type: After adding sugar, should the tea be stirred left or right ?!
    Each type of electricity carries different risks!
    50 Hz alternating current is fibrillation of the heart, direct current is the electrolysis of body fluids (the effects may appear after a long time).
    The alternating current "rejects", the direct current causes the muscles to contract, so that you cannot, for example, open your hand clasped on the cable. Etc. etc.
    The protections consist - first of all - in limiting the time of current flow through the body. And common sense.
    Regards
  • #11 4329477
    twardyboro
    Help: 11
    Rate: 32
    Direct current is more dangerous.
    The alternating current is more "unpleasant" in paralysis, that is, it is stronger and more painful, and due to the fact that the functioning of the nervous system is based on electrical impulses (a change in the concentration of ions in nerve cells), it causes muscle contraction and disturbances in the functioning of the nervous system, which in turn may lead to to the aforementioned ventricular fibrillation, etc., the flow of direct current causes electrolysis of body fluids in the body and, consequently, serious disturbances in the functioning of the organism, which, as a result, lead to the end of the life of an affected individual in a short time. The values of safe voltages for direct current are higher because direct current does not cause muscle contraction like a variable one (so-called freezing) and a person can release the voltage more easily.
    Regards.
  • #12 4329607
    forestx
    Rest in Peace
    Help: 299
    Rate: 496
    - this is how I read this statement again and ask again: does alternating current not cause blood electrolysis?
  • #13 4330862
    twardyboro
    Help: 11
    Rate: 32
    forestx wrote:
    HeSz wrote:
    direct current is electrolysis of body fluids
    50Hz is quite a low frequency so electrolysis can also occur, but certainly to a much lesser extent than with direct current.
    Regards.
  • #14 4331017
    HeSz
    Help: 97
    Rate: 198
    AC-induced electrolysis involves a small area of ions adjacent to the electrode. Has anyone developed a method of e.g. electroplating metal using alternating current?
    Regards
  • #15 4332992
    _jta_
    Electronics specialist
    Help: 3212
    Rate: 4255
    Alternating and direct current are harmful in different ways, and as far as I know, the degree of harmfulness depends on the evaluation criterion:
    direct current causes much more serious electrochemical effects (greater toxic effect), while alternating current
    greater muscle contraction (in addition, frequencies around 50Hz are the worst in this respect) - the voltage above which
    it is impossible to let go of the wire, it is smaller for alternating current, also alternating current more disturbs the heart ...
  • #16 17495734
    handler
    To the hardboro.
    You are contradicting yourself what the forestx explained.
    Since alternating current has much less safe values than direct current, how can the constant be more dangerous? 50V variable and 120V constant.
    Even on vca tests this is a question and the correct answer is that AC is more dangerous.
The discussion centers on the dangers posed by constant versus variable current to the human body, particularly under the same voltage and exposure time. Participants highlight that the effects of electricity on the body are complex and depend on various factors, including the type of current (AC vs. DC), frequency, voltage, and exposure duration. Alternating current (AC), especially at 50 Hz, is noted for its potential to cause heart fibrillation and greater muscle contraction, making it more dangerous in certain scenarios. In contrast, direct current (DC) is associated with electrolysis of body fluids, which can lead to severe long-term effects. The consensus suggests that while both types of current are harmful, AC is generally considered more dangerous due to its immediate physiological effects and lower safe voltage thresholds.
