CD4027 Push ON/OFF Latch Circuit to Drive 5V Relay Using 3V Input Voltage
450 22
How can I build a push-on/push-off latch with a CD4027 that runs from 3 V and switches a 5 V relay?
Run the CD4027 from the 3 V logic supply, but drive the 5 V relay through a transistor stage powered from a separate 5 V source or regulator; do not try to feed the relay directly from the 4027 output [#21660567] If you want a clean push-button clock input, condition the switch with an RC network and a Schmitt-trigger inverter such as a 74AC14, or use a double-pole, single-throw pushbutton into the S/R inputs; the Schmitt stage gives a sharp edge and prevents the 4027 from sitting in its active region during switch bounce [#21660570] Add local decoupling capacitors across VDD/VSS on the ICs and make sure unused inputs are tied high or low [#21660574][#21660588] If relay current is causing supply dips, route the relay current on separate supply lines so it does not share the same feed as the logic [#21660584] For the output transistor, PN2222A was suggested as a suitable choice [#21660586]
  • #1 21660566
    RAJU MUKTAWAR
  • Clarifying supply roles and relay coil current requirements
    #2 21660567
    Steve Lawson
  • #3 21660568
    Steve Lawson
  • #4 21660569
    RAJU MUKTAWAR
  • Schmitt trigger input conditioning for 4027 latch
    #5 21660570
    Steve Lawson
  • Power dip on joystick controller when latch circuit switches
    #6 21660571
    RAJU MUKTAWAR
  • Requesting relay specs and clearer fault description
    #7 21660572
    Steve Lawson
  • #8 21660573
    RAJU MUKTAWAR
  • Relay current may be overloading the 8.5 V supply
    #9 21660574
    Steve Lawson
  • #10 21660575
    Steve Lawson
  • #11 21660576
    RAJU MUKTAWAR
  • #12 21660577
    RAJU MUKTAWAR
  • Measure supply current limit with a potentiometer load
    #13 21660578
    Steve Lawson
  • #14 21660579
    RAJU MUKTAWAR
  • #15 21660580
    Steve Lawson
  • #16 21660581
    RAJU MUKTAWAR
  • #17 21660582
    RAJU MUKTAWAR
  • #18 21660583
    Chris Tremlett
  • Separate relay supply and add 10 nF decoupling caps
    #19 21660584
    Steve Lawson
  • #20 21660585
    RAJU MUKTAWAR
  • #21 21660586
    Steve Lawson
  • Shared 4027 supply likely prevents simultaneous operation
    #22 21660587
    RAJU MUKTAWAR
  • #23 21660588
    Steve Lawson
The discussion focuses on designing a push ON/OFF latch circuit using the CD4027 flip-flop IC to drive a 5V relay with a 3V input control voltage. Key challenges include powering the 5V relay coil when the control logic operates at 3V and managing relay drive current. Solutions involve using the 3V supply for the CD4027 and push button input, while employing a transistor (e.g., BC547 or BC337) to switch the relay coil powered by a regulated 5V supply derived from an 8.5V source via a 7805 voltage regulator. Debounce filtering at the CD4027 clock input is addressed by adding an RC network and Schmitt trigger inverters (74AC14) to produce clean rising edges and prevent multiple triggering. Users report issues with supply disturbances affecting a connected Sony PS2 joystick controller, likely due to current draw or component faults; suggestions include isolating relay supply lines, adding decoupling capacitors (10nF) across IC power pins, and verifying power supply current capacity. For running the entire circuit at 3V with 3V relays, it is recommended to isolate relay supply lines from logic supply lines and use suitable transistors like PN2222A or BC337 to drive relays with coil resistances around 45-65 ohms. Problems with simultaneous operation of both halves of the CD4027 are attributed to improper input handling and insufficient decoupling. Overall, the circuit is feasible with proper power management, input conditioning, and component selection.
TL;DR: Build a push-on/off latch with a CD4027 at 3 V that drives a relay via a transistor; a 5 V, 167 Ω coil draws ~30 mA. “The Schmitt trigger (74AC14) conditions the push button signal.” [Elektroda, Steve Lawson, post #21660570]
Why it matters: This FAQ helps hobbyists and repairers wire a reliable 3 V pushbutton latch that safely switches 5 V relays without browning out consoles or controllers.
How do I wire a 3 V push ON/OFF latch to drive a 5 V relay from an 8.5 V source?
Power CD4027 from 3 V. Regulate 8.5 V to 5 V with a 7805 for the relay. Use the 4027 Q (via a base resistor) to drive an NPN transistor that switches the 5 V relay coil. Add a flyback diode across the coil. This keeps logic at 3 V while the relay sees 5 V. [Elektroda, Steve Lawson, post #21660567]
How do I debounce the pushbutton and get a rising-edge clock?
Use an R–C into a 74AC14 Schmitt trigger, then another inverter to restore polarity. This converts the noisy push into a sharp rising edge. As stated, “The Schmitt trigger (74AC14) conditions the push button signal.” [Elektroda, Steve Lawson, post #21660570]
Can the logic run at 3 V while the relay runs at 5 V?
Yes. Run the CD4027 and switch from 3 V. Regulate the 8.5 V rail down to 5 V for the relay. Drive the relay through a transistor from the 4027 output. Ensure the 8.5 V source can supply the relay current. [Elektroda, Steve Lawson, post #21660567]
Which transistor should I use to drive two small 3 V relays from the 4027?
Use a PN2222A with an appropriate base resistor and a diode across each coil. It offers robust switching for low-voltage relay loads from logic-level control. [Elektroda, Steve Lawson, post #21660586]
Pressing SW1 glitches my controller—how do I stop the brownout?
Separate the relay’s 3 V feed from the logic 3 V wiring to prevent shared drops. Add 10 nF decouplers close to each IC. This layout reduces transients that reset sensitive controllers. "Run separate lines to the source" to keep relay current off logic traces. [Elektroda, Steve Lawson, post #21660584]
How much current do my relays need, and what base current is required?
Example: two 5 V, 167 Ω coils draw about 60 mA total. With a BC547 at β≈120 at 100 mA, base current needs about 0.5 mA. The 4027 at 3 V may not source that reliably, so use proper buffering. [Elektroda, Steve Lawson, post #21660574]
Can I swap the switch and R1 to trigger on the positive edge?
Use two Schmitt inverters after the R–C to produce a press-detected rising edge at the 4027 clock. This achieves your positive-edge requirement without rewiring the basic R–C. [Elektroda, Steve Lawson, post #21660570]
How do I run the entire setup from 3 V using 3 V relays?
Drive the 3 V relays from the 3 V rail through a transistor, not directly from the 4027. Route separate supply lines for relay and logic, and place 10 nF decouplers at the IC pins. [Elektroda, Steve Lawson, post #21660584]
Why won’t both halves of my CD4027 work at the same time?
Tie all unused inputs definitively high or low, and decouple each supply pin pair with 10 nF. Floating inputs or poor decoupling can prevent the second flip-flop from toggling. Describe exact failure modes during debugging. [Elektroda, Steve Lawson, post #21660588]
My circuit works even without the 74AC14—what changed?
A faulty component caused the earlier disturbance. After replacement, the latch worked cleanly without the Schmitt trigger in that build. Component health can mimic debounce issues. [Elektroda, RAJU MUKTAWAR, post #21660579]
How can I test whether my 3 V or 8.5 V rails can supply enough current?
Use a potentiometer as a variable load with volt and current meters. Start at high resistance, lower slowly, and note the current when voltage sags. Stay within safe limits to avoid damage. [Elektroda, Steve Lawson, post #21660578]
What does the CD4027 do in this latch?
The CD4027 stores the ON/OFF state. A conditioned button pulse clocks it, toggling Q, which then drives the transistorized relay stage. The Schmitt-triggered edge prevents active-region oscillation. [Elektroda, Steve Lawson, post #21660570]
What relay current should I expect with two 3 V, 65 Ω coils in parallel?
Each coil draws about 46 mA at 3 V. Two in parallel need roughly 92 mA. Size the transistor and supply wiring accordingly, and add flyback diodes. [Elektroda, RAJU MUKTAWAR, post #21660585]
Is a 74AC14 mandatory for debounce?
It’s recommended to avoid slow edges that increase IC current. However, a clean switch and healthy components can work without it in some builds. Use it when reliability is critical. [Elektroda, Steve Lawson, post #21660570]
Any quick build steps for the 3 V to 5 V relay latch?
  1. Power CD4027 and button from 3 V; add 10 nF decouplers.
  2. Condition the button with R–C into two 74AC14 inverters.
  3. Use Q to drive an NPN that switches a 5 V relay fed by 8.5 V→7805; add a flyback diode. [Elektroda, Steve Lawson, post #21660567]
