0-30V Variable Power Supply Design with 100mV Fine, 1V Coarse, CV/CC Modes
675 8
  • #1 21685401
    Vinayak Hegde
  • Need current rating and control method details
    #3 21685403
    Richard Gabric
  • Need for a 0–30 V CV/CC variable supply circuit
    #4 21685404
    Vinayak Hegde
  • #5 21685405
    Vinayak Hegde
  • Heatsink, SOA and tap-changer advice for high current supply
    #6 21685406
    Richard Gabric
  • #7 21685407
    Vinayak Hegde
  • TI LM317 schematic for 12–160 V adjustable supply
    #9 21685409
    MarcoFranceschini
The discussion focuses on designing a 0-30V variable power supply with fine 100mV and coarse 1V voltage adjustments, including constant voltage (CV) and constant current (CC) operation modes. Key considerations include whether to use a linear or switch-mode power supply (SMPS), with SMPS favored for high current but more complex and noisier. Fine voltage control can be achieved via multi-turn potentiometers or digital control, though complexity increases. Safety and protection features are critical, especially for laboratory use, including thermal management and stable operation across the voltage range. Suggested resources include tutorials and example projects from electronics-lab.com and a Texas Instruments application note featuring an LM317-based regulator design scalable for higher voltages and currents by substituting pass transistors. The design must consider power dissipation, safe operating area (SOA) of transistors, and potential use of automatic tap changers for efficiency. Stability verification with an oscilloscope is recommended to avoid oscillations. Increasing current capability to 5A requires circuit modifications and careful component selection.
