Is a Lead-Acid Battery Discharged When 1A Flows Toward the Negative Terminal?
207 7
  • Current direction alone does not determine battery discharge
    #1 21660997
    Geraldo Lopes Serodio
  • #2 21660998
    Calinoaia Valentin
  • #3 21660999
  • #4 21661000
    Milivoje Bulaji
  • #5 21661001
  • #6 21661002
    Milivoje Bulaji
  • #7 21661003
  • Battery discharge explained as reversible chemical reaction
    #8 21661004
The discussion addresses whether a lead-acid battery is discharged when a 1A current flows toward its negative terminal. It is clarified that during discharge, current flows from the positive to the negative terminal, while charging involves current flowing from negative to positive. The apparent paradox arises when ideal voltage source models are used, which do not account for internal impedance. Introducing internal series resistance (e.g., 0.025 Ω) and parallel resistance (e.g., 1 kΩ) resolves this paradox by reflecting real battery behavior. The chemical reactions in lead-acid batteries are reversible, with charging converting PbSO4 back to PbO2 and discharging converting PbO2 to PbSO4. Thus, the battery discharges chemically when current flows toward the negative terminal, consistent with practical electrochemical processes rather than idealized circuit models.
