How Do Capacitor Value and Voltage Rating Affect Electret Microphone Performance?
585 8
  • Questioning capacitor value and voltage effects on electret output
    #1 21661441
    Jonny Death
  • Larger coupling capacitors pass lower frequencies
    #2 21661442
    Steve Lawson
  • Low-pass filtering more important than coupling cap
    #3 21661443
    Jonny Death
  • Drain resistor needed to read electret mic signal
    #4 21661444
    Steve Lawson
  • Eliminating the drain resistor still worked fine
    #5 21661445
    Jonny Death
  • #6 21661446
    Steve Lawson
  • Voice bandwidth determines coupling capacitor choice
    #7 21661447
    Mark Harrington
  • Cap blocks DC and low-frequency hum
    #8 21661448
    Jonny Death
  • #9 21661449
    Mark Harrington
The discussion clarifies the role of capacitors in electret microphone circuits, particularly focusing on the coupling capacitor often referred to as the "power capacitor." The capacitance value primarily affects the low-frequency response by determining the cutoff frequency through capacitive reactance; larger capacitance values allow passage of lower frequencies, improving bass response. Voltage rating of the capacitor is a safety margin to prevent dielectric breakdown and should be chosen at least 50% above the maximum circuit voltage, including possible surges. Electret microphones contain an internal JFET transistor, and the biasing resistor on the drain is essential to convert the JFET current to a usable voltage signal, although alternative configurations using current directly with op-amps or transistor bases exist. The electret's output voltage depends on sound pressure level (SPL), not on biasing voltage, but the drain resistor sets the operating point. Proper filtering, including low-pass filters and multi-band EQ, is more critical than capacitor value alone for sound quality. The discussion also highlights common misconceptions about electret mics being integrated circuits versus discrete devices and emphasizes studying accurate circuit diagrams for design. High-quality preamps can make inexpensive electret microphones perform comparably to more expensive condenser microphones.
