Best Way to Amplify Capacitive Microphone Output—Is LM386 Suitable?
270 13
How can I amplify the output of a two-wire capacitive microphone, and is the LM386 a suitable choice?
Yes, the LM386 can work for a basic capacitive microphone amplifier, but the mic must be biased first and some microphones may still need an extra preamp ahead of it [#21676831][#21676828][#21676832] For the simple circuit described, connect a 9V supply to the mic's positive lead and LM386 pin 6, connect the mic's negative lead to the top of a 100k potentiometer, and connect the pot wiper to LM386 pin 3 [#21676834] Tie LM386 pins 2 and 4 to ground, leave pin 7 unconnected, and place a 10uF capacitor between pins 1 and 8 to set high gain [#21676834] Take the output from pin 5 through a 100uF coupling capacitor to the speaker or headphones, and optionally add the 0.05uF capacitor with a 10 ohm resistor from pin 5 to ground for hiss reduction [#21676834] If you want a more optimized result than a quick test setup, use a dedicated low-noise microphone preamplifier and choose the design based on noise, dynamic range, distortion, or power requirements [#21676826]
  • #1 21676821
    reyhane mohebali
  • #2 21676822
    Kevin Angelo Ma
  • #3 21676823
    reyhane mohebali
  • #4 21676824
    Dean Franks
  • #5 21676825
    reyhane mohebali
  • High-gain low-noise microphone preamp reference
    #6 21676826
    Dean Franks
  • #7 21676827
    reyhane mohebali
  • #8 21676828
    Jeff Gray
  • #9 21676829
    Sambath Kumar
  • #10 21676830
    reyhane mohebali
  • #11 21676831
    Jeff Gray
  • #12 21676832
    Jeff Gray
  • #13 21676833
    reyhane mohebali
  • LM386 microphone amplifier wiring and component values
    #14 21676834
    Jeff Gray
The discussion focuses on amplifying the output of a capacitive (condenser) microphone, which typically produces a maximum voltage around 50mV, with the goal of achieving approximately 5V output, implying a voltage gain near 100. The LM386 audio amplifier was tested using its datasheet circuits for gains up to 200, but did not yield the expected results. Key considerations include whether the microphone has an internal FET amplifier or is a raw electret element; in this case, the microphone lacks an internal FET and has two wires. Proper biasing of the microphone with a DC voltage is essential for operation. Suggestions include using a dedicated low-noise microphone preamplifier stage before the LM386 or alternative high-gain low-noise amplifier designs. A detailed LM386-based circuit was described, involving a 9V supply, biasing the microphone through a potentiometer (10k–100k), and specific capacitor and resistor connections to achieve amplification. References to external resources such as EEVBlog videos on Rode amplifier design and a high-gain low-noise microphone preamplifier project were provided for further guidance.
TL;DR: A simple 9 V LM386 build can amplify a two‑wire capacitive mic; “100kohm pot can be any value from 10kohm to 100k,” and add 10 µF between pins 1–8 for high gain. [Elektroda, Jeff Gray, post #21676834]
Why it matters: This FAQ shows how to power, bias, and wire a raw electret/capacitive mic so your LM386 build actually delivers usable audio.
For: Hobbyists and students asking “what’s the best way to amplify a capacitive mic, and is LM386 OK?”
Is the LM386 suitable for amplifying a capacitive/electret microphone?
Yes, if you bias the mic and follow correct LM386 input and gain wiring. A two‑wire capsule can feed pin 3 via a volume pot, with 10 µF across pins 1–8 for higher gain. “You should be able to use your LM386, like this.” [Elektroda, Jeff Gray, post #21676832]
Do I need a preamplifier before the LM386?
Sometimes. It depends on the microphone element and your goals (noise, dynamic range, distortion, power). An additional front‑end may be required for very low‑noise work or raw elements. Ask yourself what you’re optimizing for before choosing. [Elektroda, Dean Franks, post #21676826]
How much gain do I need to turn 50 mV into about 5 V?
About 100× voltage gain. That takes a typical small mic signal near 50 mV and lifts it to around 5 V peak, assuming headroom and clipping are managed downstream. [Elektroda, reyhane mohebali, post #21676825]
Why didn’t the LM386 “200× gain” circuit work for my mic?
A common failure is missing mic bias. Without bias, a two‑wire electret outputs nothing, so the LM386 only amplifies noise. Confirm biasing first, then check wiring and grounding. “Without a bias it won’t do anything.” [Elektroda, Jeff Gray, post #21676831]
How do I bias a two‑wire capacitive/electret microphone?
Provide a DC supply to the mic through the designated lead, then route the mic return through your volume pot to the LM386 input. The post emphasizes that the capsule needs applied voltage to generate a signal at all. [Elektroda, Jeff Gray, post #21676831]
Quick 3‑step: how do I wire the LM386 for a mic test?
  1. Power: 9 V battery + to mic + and LM386 pin 6; − to ground.
  2. Input: Mic − to top of 10–100 k pot; pot wiper to pin 3; pin 2,4 to ground.
  3. Gain/output: 10 µF between pins 1–8; pin 5 via 100 µF to load; optional 0.05 µF//10 Ω to ground. [Elektroda, Jeff Gray, post #21676834]
What value should I use for the input volume pot?
Use 10 k–100 k. As the expert notes, “100kohm pot can be any value from 10kohm to 100k.” Start at 50 k if unsure, then tweak for noise and level. [Elektroda, Jeff Gray, post #21676834]
What do LM386 pins 1 and 8 do for microphone use?
They set gain. Adding a 10 µF capacitor between pins 1 and 8 drives the LM386 into its high‑gain mode, useful when boosting small mic signals. Observe polarity as shown. [Elektroda, Jeff Gray, post #21676834]
What’s the difference between a raw electret element and one with an internal FET?
A raw element needs external bias and has high source impedance. Capsules with an internal FET buffer behave like low‑impedance sources and are easier to amplify. Identify which you have before choosing a circuit. [Elektroda, Dean Franks, post #21676824]
Where can I see a high‑gain, low‑noise mic preamp example?
Check the referenced high‑gain, low‑noise microphone preamplifier design and explanation provided in the discussion. It covers design trade‑offs for noise and dynamic range. [Elektroda, Dean Franks, post #21676826]
Can the LM386 really do 200× gain?
Yes, that’s a common datasheet mode discussed in the thread. However, high gain amplifies noise and layout issues; biasing and filtering become critical. Stabilize the input and keep leads short. [Elektroda, reyhane mohebali, post #21676827]
What output components should I use for cleaner sound?
Use a 100 µF coupling capacitor from pin 5 to your load. Add a small 0.05 µF capacitor in series with a 10 Ω resistor from pin 5 to ground as a Zobel to tame hiss. [Elektroda, Jeff Gray, post #21676834]
Can I drive headphones or a small speaker directly from the LM386?
Yes. Route pin 5 through a 100 µF electrolytic to the headphone or speaker, with the other lead to ground. Keep volumes modest during testing to avoid clipping and hearing damage. [Elektroda, Jeff Gray, post #21676834]
Do I need to connect LM386 pin 7 (bypass)?
Not required in the shared build. The reference wiring leaves pin 7 unconnected and works for a basic mic amplifier test. Add bypass later if you chase noise performance. [Elektroda, Jeff Gray, post #21676834]
What supply should I start with for a quick prototype?
A 9 V battery is convenient and matches the reference wiring. It keeps the setup portable and reduces hum while you validate bias and gain. [Elektroda, Jeff Gray, post #21676834]
