How to Detect Stuck Bullets in Rotating Lead Casting Molds Using Sensors?
258 10
How can I detect whether a rotating lead-casting mold has actually emptied after the bullet is released?
Use a sensor just past the mold exit to verify that the bullet really left the cavity; an optical or mechanical sensor can detect the slug’s exit, and the machine should only continue if that sensor is triggered, otherwise stop and alarm the operator [#21661531] If you want extra protection, fit both an exit-detection sensor and a second sensor that checks for a still-occupied mold, so the system can retry or stop safely [#21661531] For a hot, lead-contaminated environment, fiber-optic sensors with glass leads were suggested as a suitable high-temperature option, and capacitive sensors were also mentioned as alternatives [#21661539] Another idea was to add a diverter/flap in the product path and use weight/resistance timing so the machine pauses if the expected mass is not present [#21661536]
  • Suggesting sensor checks for stuck bullets in molds
    #1 21661530
    Dimitar Bo
  • Dual sensor scheme to detect stuck bullets
    #2 21661531
    Frank Bushnell
  • Graphite powder spray to prevent mold seizing
    #3 21661532
    Jonny Death
  • #4 21661533
    Dimitar Bo
  • #5 21661534
    Dimitar Bo
  • #6 21661535
    Jonny Death
  • Weight-triggered diverter and mold inspection questions
    #7 21661536
    Tony Matteo
  • #8 21661537
    Jonny Death
  • #9 21661538
    Dimitar Bo
  • Fiber optic or capacitive sensors for mold detection
    #10 21661539
    John King
  • #11 21661540
    Resis Tor
The discussion addresses detecting stuck bullets in rotating lead casting molds that pour molten lead into multiple caliber-specific molds (9mm, 10mm, .45). The molds rotate, open, and drop bullets, but sometimes bullets remain stuck, causing molten lead spillage and operational issues. Proposed solutions include using optical or mechanical sensors positioned near the mold exit to detect the presence or absence of bullets by reflection or mechanical activation. If a bullet is detected as stuck, the machine can pause, attempt to dislodge the bullet via a mechanical actuator (e.g., a weighted linear actuator), and if unsuccessful, stop and alert the operator. Alternative detection methods suggested include capacitive sensors, fiber optic sensors rated for high temperatures, and weight-based detection systems. Preventative measures focus on reducing mold burring and sticking by applying graphite powder as a dry lubricant inside molds, which also improves bullet performance. However, caution is advised against liquid coatings due to buildup and steam explosion risks. Mold maintenance through careful cleaning and professional polishing is recommended to avoid burs that cause sticking. Brands mentioned for sensors include Keyence and Moeller Electric, with AutomationDirect cited as a supplier of fiber optic sensors. The discussion emphasizes combining sensor detection with mechanical clearing and preventive lubrication to ensure reliable mold emptying and casting quality.
