How to Combine Two AC Inputs for Load Sharing up to 2KW With Priority Switching?
603 12
How can I combine two AC sources so the first one powers the load up to its limit and the second one supplies only the extra power when the load exceeds that limit?
You cannot directly “sum” two independent AC sources for priority load sharing unless they are synchronized and precisely in phase; otherwise you would need to rectify both sources to DC and then invert back to AC [#21681289] A standard grid-tie solar inverter already works in a similar way on the AC side: it holds its output slightly above the grid voltage so it supplies as much load as it can, and any excess power flows back to the grid [#21681291][#21681292] If you want to avoid exporting to the grid, a controller can use a current sensor, contactor, or PLC/microcontroller logic to detect export or loss of grid and switch in grid power only when solar is insufficient [#21681294][#21681298] Another practical option mentioned was to feed the load from an inverter powered by solar DC, with the grid rectified and smoothed into the same DC bus, possibly with battery storage for continuity when solar is low [#21681294]
  • #1 21681287
    Abdul Rasheed
  • #2 21681288
    jak peter
  • AC sources must be phase-synchronized for sharing
    #3 21681289
    Rick Curl
  • Proposes solar-grid power sharing for DC loads
    #4 21681290
    Abdul Rasheed
  • Suggesting a solar inverter with battery storage
    #5 21681291
    David Ashton
  • Grid-tie inverter synchronization and export metering
    #6 21681292
    Rick Curl
  • Preventing solar export while using grid power
    #7 21681293
    Abdul Rasheed
  • Suggesting inverter with grid-islanding contactor control
    #8 21681294
    David Ashton
  • #9 21681295
    Abdul Rasheed
  • Microcontroller or PLC priority switching for solar and grid
    #10 21681296
    Abdul Rasheed
  • Solar PV with battery inverter as grid-synced backup
    #11 21681297
    Conrad Mannering
  • IBoost as export-sensing load controller
    #12 21681298
    David Ashton
  • #13 21681299
    Abdul Rasheed
The discussion addresses the challenge of combining two AC power inputs to share load up to 2 kW with priority switching, where AC1 supplies up to 1 kW and AC2 supplements any additional load. Key technical issues include the difficulty of paralleling unsynchronized AC sources without phase alignment, making direct AC load sharing complex. A common solution involves rectifying both AC inputs to DC, then inverting back to AC for load supply, though this typically results in equal load sharing rather than prioritized distribution. The context involves on-grid solar systems aiming to maximize solar energy utilization without feeding excess power back to the grid, which is problematic in some regions due to grid overload. Standard grid-tie inverters synchronize solar DC output with the grid and feed excess power back, but they disconnect during grid outages and do not prevent export to the grid. Alternative approaches discussed include using microcontrollers or PLCs to control contactors for priority switching and load sharing, and employing devices like the I-Boost, which diverts excess solar power to local loads (e.g., hot water tanks) to avoid grid export. Battery storage systems combined with inverters can provide backup power and load management but add complexity. The overall solution requires precise synchronization, power sensing, and control logic to prioritize solar power usage, supplement with grid power as needed, and prevent backfeeding to the grid.
TL;DR: Two 1 kW AC sources won’t naturally share 1.0 kW and 0.2 kW unless synchronized; “easier to do with DC than with AC.” Use sync’d inverter, anti‑islanding, and load diversion for priority solar with zero export. [Elektroda, Rick, post #21681289]
Why it matters: This FAQ helps builders and facility engineers design safe, zero‑export solar that tops up from grid only when needed.
Can I just parallel two AC sources to share load up to 2 kW?
Not safely unless they are synchronized in voltage, frequency, and phase. Otherwise, circulating currents and instability occur. A practical approach is rectifying both to DC, filtering, then using an inverter to supply a single AC bus. Sharing then becomes controlled, not accidental. “Easier to do with DC than with AC.” [Elektroda, Rick, post #21681289]
What is a grid‑tie inverter and why does it matter here?
A grid‑tie inverter converts PV DC to AC that matches the grid’s voltage and phase, powering local loads first and exporting surplus. Utilities use bidirectional meters, and anti‑islanding prevents backfeed during outages to protect workers. This aligns with a priority‑to‑solar design, minus export if you add diversion. [Elektroda, Rick, post #21681292]
How do I stop exporting solar while still maximizing self‑consumption?
Use a zero‑export/diverter controller with a current transformer. When it detects export, it routes surplus to a resistive load (e.g., water heater) or a storage battery, keeping export at or near zero while preserving grid top‑up when PV is low. [Elektroda, Conrad Mannering, post #21681297]
Can the system keep running when the grid goes down?
Yes, if you add grid isolation and an inverter that supports standalone (islanded) operation. A contactor disconnects the grid on loss‑of‑mains, and the inverter continues serving local loads from solar and storage. Without isolation, anti‑islanding will trip and stop production. [Elektroda, David, post #21681294]
How do I prioritize solar and only top up from the grid?
Three steps:
  1. Measure building import/export with a CT.
  2. Use a PLC/MCU to modulate local loads or enable grid input only when PV < load.
  3. Open a contactor on grid loss; keep inverter supplying the local island. [Elektroda, Abdul Rasheed, post #21681296]
What if I need asymmetric sharing, like 1.0 kW from source A and 0.2 kW from source B?
Direct AC paralleling won’t hold that ratio. Convert to DC and use a single inverter, or use one synchronized inverter as the master and supplement from the other side via controlled DC or diversion. Equal sharing is the natural outcome without active control. [Elektroda, Rick, post #21681289]
Is there a real‑world sizing example for zero‑export top‑up?
Yes. The thread discusses a 30 kW DC building load with 25 kW solar available. The control scheme draws the missing 5 kW from the grid to meet demand, keeping solar fully utilized without export. This illustrates the top‑up concept at medium scale. [Elektroda, Abdul Rasheed, post #21681290]
What is anti‑islanding, in plain terms?
Anti‑islanding is protection that forces a grid‑tie inverter to stop output during a grid outage. It prevents backfeeding the public network, which could injure utility crews. Any system that continues during outages must positively isolate from the grid first. [Elektroda, Rick, post #21681292]
Could a simple contactor and MCU handle priority switching?
Yes. Sense current flow, prefer solar, and enable grid only for the deficit. On detecting zero grid, open the contactor to form an islanded microgrid. Pair this logic with an inverter designed to operate without the grid present. [Elektroda, Abdul Rasheed, post #21681296]
What’s a solar diverter (like I‑Boost) and where does it fit?
A diverter monitors export and instantly routes excess PV to local thermal storage, such as a hot‑water tank. It raises self‑consumption and enforces zero‑export limits. Think of it as an automatic priority load that soaks up surplus. [Elektroda, Conrad Mannering, post #21681297]
What failure edge case should I plan for?
Plan for grid loss while PV is producing. Without fast isolation, the inverter’s anti‑islanding will shut down generation to avoid energizing lines, causing a sudden loss of power. Proper contactor control prevents backfeed and keeps local supply online. [Elektroda, Rick, post #21681292]
Why not just feed excess to the grid and get credit?
You can, but policies may pay less for exported energy than the retail import price. The thread also notes concerns about local grid stress from aggregate exports. Zero‑export with diversion maximizes onsite use while respecting constraints. [Elektroda, Abdul Rasheed, post #21681295]
Is AC combining ever preferable to DC combining here?
Not for fine‑grained sharing. AC combining needs precise phase sync and tends toward equal sharing. DC combining with one robust inverter gives deterministic control over contribution and simplifies priority logic. “Easier to do with DC than with AC.” [Elektroda, Rick, post #21681289]
Do I need batteries for this approach?
Not strictly. You can maximize self‑consumption with diversion alone. Adding a battery increases resilience and time‑shifts energy for outages or evening peaks, and some inverters can sync seamlessly when grid returns. [Elektroda, Conrad Mannering, post #21681297]
What components form a basic zero‑export, priority‑solar stack?
Core pieces: PV array, inverter capable of islanding, grid isolation contactor, CT for import/export sensing, PLC/MCU for logic, and an optional diverter or storage. This stack enforces solar‑first, grid‑top‑up, and safe islanding. [Elektroda, David, post #21681294]
