Combining Two 12V 750mA Transformers for 12V 2A Audio Amplifier Power Supply
279 7
  • Parallel 12 V transformers still need voltage check
    #1 21661587
    Ian Fearn
  • Parallel identical PSUs only yield 1.5A
    #2 21661588
    Frank Bushnell
  • Parallel 12V transformers may still fall short
    #3 21661589
    Steve Lawson
  • Recommend salvaging suitable transformers from discarded hi-fi units
    #4 21661590
    Mark Harrington
  • #5 21661591
    Edison Villanueva
  • Requesting correction of a 12 V transformer layout
    #6 21661586
    Edison Villanueva
  • #7 21661592
    Edison Villanueva
  • #8 21661593
    Mark Harrington
The discussion addresses the feasibility of combining two 12V 750mA transformers or power supply units (PSUs) in parallel to achieve a 12V 2A supply for an audio amplifier project. It is clarified that paralleling identical 12V PSUs with correct polarity can theoretically double the current capacity to approximately 1.5A, but this still falls short of the 2A requirement. Actual output voltage after rectification and smoothing will be around 15.5V DC with no load, which may exceed the amplifier's voltage tolerance. Voltage drops from rectifiers (~1.4V) and regulators (depending on dropout voltage) must also be considered. Using two transformers in parallel is generally not recommended due to potential imbalance and risk of damage. Alternatives include sourcing a single transformer or PSU with the correct 12V 2A rating or salvaging suitable transformers from discarded hi-fi or alarm equipment. The user shared a schematic based on the available transformers, seeking corrections and advice, with responders emphasizing the importance of proper power supply specifications for reliable amplifier operation.
