How to Build a 3-Second LED Delay Circuit Using Resistor, Capacitor, and Transistor
231 6
  • #1 21663468
    George James
  • #2 21663469
    Ian Brown
  • #3 21663470
    George James
  • Base voltage and resistor values limit transistor current
    #4 21663471
    Ian Brown
  • #5 21663472
    George James
  • #6 21663473
    Ian Brown
  • #7 21663474
    Steve Lawson
The discussion addresses building a 3-second LED delay circuit using a resistor, capacitor, and transistor without employing a 555 timer. Challenges include the impracticality of using a large 2.2mF capacitor and difficulties achieving the desired delay despite varying transistor types and supply voltages. Key technical advice highlights the importance of proper transistor operation: the base voltage must be approximately 0.6 V above the emitter to saturate the transistor, ensuring sufficient collector current (Ic = ib * hfe) to drive the LED. High-value base resistors can limit base current and thus collector current, affecting LED brightness and delay. A current-limiting resistor in series with the LED is necessary to prevent excessive current. To reduce capacitor size, using a transistor with a high current gain (beta), such as a Darlington transistor, is recommended, though voltage headroom at 5 V supply is limited. The overall solution requires balancing transistor parameters, resistor values, and capacitor size to achieve the intended delay and LED activation.
