How to Design a Simple PCB Circuit Using Resistors and Capacitors for Beginners
246 6
  • #1 21663663
    vasudev A
  • Basic PCB making steps from paper layout
    #2 21663664
    Rakesh Shrivastav
  • #3 21663665
    Earl Albin
  • #4 21663666
    Rakesh Shrivastav
  • Learn circuit basics before PCB design
    #7 21663669
    Matthew Lee
To design a simple PCB circuit using resistors and capacitors, start by drawing the circuit schematic on paper, then create a layout on graph paper. Transfer the layout onto tracing paper with clear, dark lines to form a negative image, which is used to produce the PCB. Beginners are advised to learn basic circuit theory, including the function of resistors and capacitors, before attempting PCB design. Software tools like Eagle PCB Designer and simulation programs such as PSpice can facilitate circuit layout and design. Online tutorials and videos provide step-by-step guidance. Alternative PCB fabrication methods include using vinyl stickers. For practical learning, circuit simulation platforms like CircuitLab and educational resources on electronics circuits are recommended to build foundational knowledge prior to PCB creation.
