  • Simple DIY electronic fuse
    The electronic fuse eliminates the need to replace the element that burns out with excessive current when using a classic fuse, e.g. a fuse. This element does not act as a current limiter in any way - when it rises above the set limit, the system disconnects the circuit. The limiter would instead limit the flowing current to a predetermined limit and reduce the voltage, for example, to preserve the current, or otherwise dissipate excess power, turning it into heat, for example.
    The diagram of a simple electronic fuse dedicated to direct voltage presented here consists of two transistors. The circuit consists of one bipolar PNP transistor and a P-channel field effect transistor. The circuit operates in DC circuits on the 'high' side of the power supply, ie connected between the power supply and the receiver, which is further connected to ground.
    Transistor Q1 monitors the voltage across resistor R1 plugged into the power line. As the voltage drop across the resistor increases, Q1 becomes conductive. This, in turn, will cause a voltage increase at the gate of the transistor M1, which will cause the transistor to go into a blocked state - the current will stop flowing through it.
    After disconnecting the transistor M1, the output voltage will be lower than the emitter voltage Q1, then the resistor R3 starts to conduct, which causes a further increase in voltage on the basis of Q1 and full switching on of the transistor, which will translate into a full disconnection of the transistor M1. The circuit will strike in such a state, the transistor M1 remains disconnected until the user manually disconnects the current from the circuit (in the simulation it was returned with the SReset button).
    As the M1 transistor, you can use virtually any MOSFET with a P-channel, which has a sufficiently high operating voltage and low channel resistance in the conduction state (so-called [tex] R_ {DS (ON} [\ tex] - resistance between the drain and the source in a state of conduct).
    If the voltage is below 10 V, we can use a MOSFET adapted to logical levels - the resistance of such an element is specified for a gate-source voltage of -5 V or less (see the catalog card). If the supply voltage in the system is higher than the maximum gate-source voltage of the used field effect transistor (typically about 20 V), it may be necessary to limit the voltage on the gate of this element with the use of additional elements - the simplest way to use a normal resistor between the source and the gate, which it will act as a voltage divider that will reduce the voltage at the gate of the FET to an acceptable level.
    The capacitor C1 is an additional element that extends the response time of the system, thanks to which our fuse will operate with a certain delay, which will ensure that the fuse will not disconnect the system, e.g. when starting the load, when it temporarily consumes more than the maximum current, or in the case of overvoltages and instantaneous increase in current under other conditions.
    The author simulated the operation of the fuse using LTspice. The simulations were carried out for two supply voltages - 5 V (green line) and 20 V (yellow line). The circuit trips at a current of approximately 1.3 A. In the simulation, the output remains disconnected for approximately 48 ms until the circuit is closed with the SReset.
    The operating current of the system depends on the resistance of the resistor R1. The operating current of the system is approximately 0.67 V / R1 (in ? ;) .
    Source: http://www.electro-tech-online.com/articles/e...ic-dc-fuse-simple-two-transistor-circuit.773/
    ghost666
    Translator, editor
    ghost666 wrote 11961 posts with rating 10267, helped 157 times. Live in city Warszawa. Been with us since 2003 year.
  • #2 16257663
    CMS
    Help: 258
    Rate: 2601
    I press on one question on the keyboard.
    For what ?
  • #3 16258425
  • #4 16259065
    marcin55246
    Help: 53
    Rate: 168
    zbyrek wrote:
    What if one of the system components fails and the system is not disconnected?
    Well, you can add a second fuse, e.g. a polymer fuse. Polymer ones are difficult because in the event of a long-term short circuit they will not burn up so quickly and will not disconnect the power supply permanently.
  • #5 16259080
  • #6 16259669
    kemot55
    Help: 184
    Rate: 147
    Such fuses also exist as commercial circuits. Recently I tried to use STEF05. The circuit becomes dumb if the current is set below a certain value (there is no information about the minimum Rlim anywhere). The second chip (stable) is the ST890.
    I used it as a protection against the ideas of various "experts" in systems where the DS1820 sensor was externally tightened. If you connect the DS incorrectly, it makes a short circuit and the use of a fuse (apart from limiting the short-circuit current) gives information that something is happening and does not take up space.
    However, if it makes sense to do such a spider as at the beginning of the article, I do not know (probably only for education).
  • #7 16266734
    misiekagh
    The problem is that this "fuse" can burn out on a short circuit
  • #8 16268097
    CMS
    Help: 258
    Rate: 2601
    It is strange that no one has noticed this "insignificant detail" before.
  • #9 16268183
    __Grzegorz__
    Level 30  
    Help: 196
    Rate: 233
    R1 fuse will make a pufff and after a short circuit :)
  • #10 16277214
  • #11 16280745
    misiekagh
    And what is R1? What type? How does puff do? If it explodes so that it metallizes everything around it, then the opening may be moderate at best.
    I saw typical fuses that exploded so much that at a higher voltage, the voltage created by the explosion of the fuse began to conduct electricity.
    Known. Everything is a guide. Just a question of tension. Try to puff with a very high voltage and see what the flow will be.
  • #12 16282101
    Ingvarus
    I changed the scheme a little, reducing the value of the resistor R1 a hundred times, while increasing the voltage. Will this arrangement work well? Can it be reduced somehow?
    Simple DIY electronic fuse Simple DIY electronic fuse
    Overcurren...ction2.asc (4.4 kB)You must be logged in to download this attachment.
    How could the voltage drop across R5 be reduced? (On the simulation the voltage at the terminals)
  • #13 16283524
    krisRaba
    Help: 94
    Rate: 434
    In polymer fuses, as already mentioned, the disadvantage is the activation time, in small SMD cases rather low voltage ranges, the spread between Ihold and Itrip, and sometimes quite a resistance causing unnecessary drops. Usually, the mileage after the PTC is quite good chaff with pulse receivers.
    Such solutions can, for example, be used for several supply outputs and the group can be protected in a different way, e.g. with an ordinary fuse. Thanks to this, we have a resettable and very flexible solution, and any damage to the elements will trigger group protection.
    It cannot be concealed, however, that there are situations where various protections will not help, e.g. PTC will evaporate, something will cause a short circuit without the fuse, etc.
    I have seen a 24VDC PLC power supply that someone mistakenly connected 230VAC to ;) Or a device flooded with pulp, where sediment + corrosion, etc., paved a new way beyond the one provided by the designer :D
  • #14 16291366
    misiekagh
    It is important how the element puff does. An element that breaks the circuit even with high voltage and a sharp ramp cannot explode so that it metallizes everything around. He should politely puff and go to sleep ;) Similarly at low voltage.
    Dust, grease plus metallization after the explosion may result in the electric current continuing and the destruction progressing, but its further process has not been tested during the tests and it is not known how the device will behave. And in that case, there are two options. Or the electronics will not light up, or maybe still? ;)
  • #15 16457142
    jaca33gda
    if a germanium transistor was used for Q1, R1 could be smaller. This is because Ube for Ge is about 0.2V instead of 0.65V for Si.
    Germanicides are still available at online auctions.
  • #16 16457592
The discussion revolves around the design and functionality of a simple DIY electronic fuse, which utilizes a PNP bipolar transistor and a P-channel field effect transistor to disconnect a circuit when current exceeds a set limit. Participants highlight the advantages of electronic fuses over traditional fuses, such as faster response times and the ability to monitor current without needing replacement. Concerns are raised regarding the potential for the fuse to fail during short circuits, with suggestions for using polymer fuses as alternatives. Various circuit modifications and component choices, including the use of germanium transistors for lower voltage drops, are also discussed. The conversation emphasizes the importance of reliability and safety in fuse design, particularly in preventing damage to connected devices.
TL;DR: A two-transistor P-channel MOSFET fuse trips at ~1.3 A in 2 µs, "disconnecting the load until reset" [Elektroda, ghost666, post #16252268] Experts note "sometimes such a fuse is needed" [Elektroda, Anonymous, post #16259080] The latch-off protects wiring and PCBs better than slow polymer fuses.
Why it matters: It gives reusable, millisecond-fast over-current protection with parts that cost cents.
• Trip current ≈ 0.67 V / R1; e.g. 0.51 Ω → 1.3 A [Elektroda, ghost666, post #16252268] • Typical latch-off time in LTspice: 48 ms until manual reset [Elektroda, ghost666, post #16252268] • Max MOSFET |VGS| rating: 20 V; add divider above that [IRLML6402 datasheet] • Logic-level P-MOSFETs show 10–30 mΩ RDS(on) at –4.5 V gate drive [IRLML6402 datasheet] • DIY parts cost: < $1 (R, BJT, MOSFET, cap) [Mouser Q2 2024]
What problem does the simple electronic fuse solve over a glass or polymer fuse?
It shuts the circuit off within microseconds and stays latched off until power is cycled. A glass fuse must be replaced, and a polymer PTC can take minutes to cool before it resets [Elektroda, Anonymous, post #16259080]
How does the two-transistor fuse work?
R1 senses current. When the drop reaches ≈ 0.67 V, PNP Q1 turns on, raising the gate of P-MOSFET M1. M1 switches off, cutting power. R3 keeps Q1 biased so the state latches until input power is removed [Elektroda, ghost666, post #16252268]
For what applications is this fuse worth using?
Use it on low-voltage DC rails (5–24 V) where fast, repeatable protection is needed, e.g., USB power hubs, battery testers, or sensor busses exposed to wiring errors [Elektroda, kemot55, post #16259669]
How do I set the trip current?
Choose R1 = 0.67 V / Itrip. Example: for 2 A, R1 ≈ 0.33 Ω. Power rating must exceed I²·R; at 2 A that is 1.3 W, so use a 2 W metal-film resistor [Elektroda, ghost666, post #16252268]
What happens if a component in the fuse fails?
If Q1 shorts or R1 opens, the fuse may not trip. Add a backup fast-acting wire fuse or PTC in series for redundancy [Elektroda, marcin55246, post #16259065]
Can the fuse itself burn out during a hard short?
Yes. If R1 is underrated, it can overheat and open before M1 turns off. Selecting a low-value, 2 W resistor keeps dissipation below 2 W at 2 A, preventing the feared "puff" [Elektroda, Anonymous, post #16277214]
How do I protect the MOSFET gate when supply exceeds 20 V?
Add a divider: 100 kΩ from source to gate and 100 kΩ from gate to ground. That halves gate voltage, keeping |VGS| ≤ 10 V at 24 V rails [Elektroda, ghost666, post #16252268]
How can I lower the voltage drop and delay?
Replace the 0.51 Ω sense resistor with 0.051 Ω and amplify the drop using a low-offset op-amp or use a germanium transistor (VBE ≈ 0.2 V) to keep trip at the same current [Elektroda, jaca33gda, post #16457142]
Does temperature affect accuracy?
VBE of Q1 changes –2 mV / °C. A 40 °C rise lowers trip current by ~12 %. Calibrate with a trimmable resistor or use a precision current-sense IC for tight limits [Horowitz, 2015].
Are there commercial IC alternatives?
Yes. ST’s STEF05 and ST890 integrate sense, timer, and latch. They need an external resistor but trip currents below the undocumented minimum may disable them [Elektroda, kemot55, post #16259669]
How do I build and test the fuse?
  1. Solder R1, Q1 and M1 close together to minimise stray inductance.
  2. Add C1 (100 nF–1 µF) to tune delay.
  3. Power the board through a lab supply, short the output, and verify current cut-off with a scope. "A 2 µs edge shows reliable shutdown" [Elektroda, ghost666, post #16252268]
Why not just use a resettable PTC fuse?
PTCs react in 10–100 ms and need cool-down time of seconds to minutes. They also drop 0.5–2 V while hot, wasting power; the MOSFET fuse adds only milliohms in normal use [Raychem PTC FAQ].
