How Does a Capacitor Pass AC but Block DC? Physical Explanation Behind the Behavior
363 10
Why does a capacitor block DC but allow AC to pass in physical terms?
A capacitor does not let current flow through the insulating gap; instead, it stores charge on its two plates, so a DC source produces only a brief charging current and then the current drops to zero at equilibrium [#21665006][#21665004][#21665011] With AC, the voltage keeps changing polarity, so the capacitor is continuously charging and discharging and current keeps flowing in the external circuit [#21665006][#21665011] In that sense, the capacitor has infinite impedance at 0 Hz (DC), which is why steady DC is blocked after the initial charge-up [#21665011] The “passing AC” behavior is really the repeated buildup and release of charge on the plates, not electrons flowing through the dielectric [#21665006]
  • #1 21665003
    Dixit Patel
  • #2 21665004
    Peter Evenhuis
  • #3 21665005
    Earl Albin
  • Capacitor behavior explained with membrane analogy
    #4 21665006
    Steve Lawson
  • #5 21665007
    Peter Evenhuis
  • Capacitor blocks DC and passes AC by alternating charge flow
    #6 21665008
    abhijeet Sathe
  • #7 21665009
    Vinod Sharma
  • #8 21665010
    abhijeet Sathe
  • Capacitor current decays to zero under DC
    #9 21665011
    Earl Albin
  • #10 21665012
    Peter Evenhuis
  • Models are useful but only approximate analogues
    #11 21665013
    Steve Lawson
A capacitor blocks direct current (DC) because once charged, no continuous current flows through it; the voltage across its plates stabilizes, preventing further charge movement. In contrast, alternating current (AC) involves continuously changing voltage polarity, causing the capacitor plates to alternately charge and discharge, resulting in a current flow in the external circuit. Physically, current does not flow through the dielectric insulator between the plates; instead, charge accumulates on the plates, creating an electric field that changes with the AC signal. Analogies such as a jar divided by a membrane or a vessel with a rubber membrane illustrate that while charge or energy transfer occurs, actual charge carriers do not pass through the capacitor's dielectric. The capacitor's impedance is frequency-dependent, being infinite at zero frequency (DC) and decreasing with increasing AC frequency, allowing AC current to "pass" by continuous charging and discharging cycles.
