Generating -3V from +10V Supply on PCB Without Additional Negative Supply
348 14
How can I generate a regulated -3 V supply from a single +10 V PCB supply with the same ground?
Use a small voltage-inverter/charge-pump or a dedicated buck-boost converter; the thread suggests an ICL7660 for low-current rails and an MC34063A configured as a negative converter [#21665305] [#21665316] [#21665317] The ICL7660 is only suitable for low output current, with one reply noting about 40 mA maximum into a 60 ohm load and that it is mainly intended for CMOS/TTL or RS232-style conversion [#21665317] If you need more current or a more robust solution, a positive-to-negative buck-boost regulator is the simplest option [#21665307]
  • #1 21665303
    anupam shakya
  • #2 21665304
    Eugene Lisovy
  • #3 21665305
    gurpreet Bhui
  • Using a +3 V regulator to create -3 V reference
    #4 21665306
    Stephen Van Buskirk
  • Buck-boost converter recommended for -3V rail
    #5 21665307
    Earl Albin
  • #6 21665308
    gurpreet Bhui
  • #7 21665309
    Earl Albin
  • Using isolated DC-DC module to derive -3V from 10V
    #8 21665310
    Earl Albin
  • #9 21665311
    Steve Lawson
  • #10 21665312
    Earl Albin
  • #11 21665313
    alpesh Patel
  • LDOs need current sinking for shared rails
    #12 21665314
    Earl Albin
  • #13 21665315
    Eugene Lisovy
  • #14 21665316
    Eugene Lisovy
  • IC can generate only about 40 mA at 60 ohms
    #15 21665317
    Mark Harrington
The discussion addresses generating a -3 V supply from a single +10 V supply on a PCB without adding a separate negative power supply, sharing the same ground reference. Several solutions are proposed: using a charge pump IC like the ICL7660 voltage converter to invert the +10 V to -10 V and then regulating down to -3 V; employing a buck-boost (positive-to-negative) DC-DC converter module for efficient negative voltage generation; stacking regulators with careful current sinking and shunting considerations; and using isolated DC-DC converters combined with diode voltage drops and low dropout (LDO) linear regulators to achieve the desired negative voltage. The importance of load current specifications and thermal dissipation is emphasized. Some responses highlight the complexity of creating a negative rail from a single positive supply without isolation or additional components, noting that linear regulators alone cannot create a negative voltage relative to the same ground. Schematics involving the MC34063A switching regulator and charge pump ICs are referenced for practical implementation. Overall, the consensus is that a dedicated inverting DC-DC converter or charge pump IC is the most straightforward and compact solution for generating -3 V from +10 V with a common ground.
TL;DR: Need -3V from +10V? A simple charge‑pump like ICL7660 delivers up to 40 mA; "IOUT is very low." Use buck‑boost or isolated DC‑DC for higher current. [Elektroda, Mark Harrington, post #21665317]
Why it matters: This FAQ helps PCB designers quickly pick a safe, space‑efficient way to create a -3V rail without adding a full negative supply.
What’s the simplest way to get -3V from a +10V rail on my PCB?
Use a charge‑pump inverter such as the ICL7660. It needs only capacitors and can generate about −3V at light loads. Its practical output current is around 40 mA, beyond which voltage droop increases. Keep traces short and add low‑ESR caps near the IC. [Elektroda, Mark Harrington, post #21665317]
How do I build a quick -3V inverter with ICL7660 (3 steps)?
  1. Drop or regulate a +3V node if needed, then feed the ICL7660 VIN.
  2. Wire the ICL7660 in voltage‑inverter mode with the recommended flying and reservoir capacitors.
  3. Take −VOUT as your −3V rail and tie circuit ground to the original board ground. “Refer the datasheet and feed it to ICL7660.” [Elektroda, gurpreet Bhui, post #21665308]
I need more than 40 mA. What should I use instead of ICL7660?
Pick a buck‑boost (positive‑to‑negative) DC‑DC module or controller. These regulate better at higher current and waste less power. As one expert put it: “A very simple slam dunk solution is to buy a buck‑boost.” Size around one square inch is typical for small modules. [Elektroda, Earl Albin, post #21665307]
Can I just shift ground with a linear regulator to get -3V?
Beware: when you stack regulators to move ground, the reference regulator must sink current. Many LDOs source only, so voltage rises and heat increases. Without proper sink/shunt capability, the scheme fails under load. This approach needs detailed current‑path analysis and thermal design. [Elektroda, Earl Albin, post #21665314]
Will two 3V LDOs in series give me -3V with respect to ground?
No, not reliably with standard LDOs. LDOs behave as current sources; driving current back into them forces their node upward unless they can sink. That creates instability and heat. Use a genuine inverting converter or an isolated supply referenced as negative. [Elektroda, Earl Albin, post #21665314]
Can I derive -3V from AC using rectifiers and filters?
Yes, but it’s bulky and unregulated. A simple AC/bridge/RC design needs heavy 120 Hz filtering and large capacitors. Regulation will vary with load. For compact, stable rails, a buck‑boost or inverting converter is the better fit on modern PCBs. [Elektroda, Earl Albin, post #21665307]
How do I use an isolated DC‑DC to create a clean -3V?
Use a small isolated 10–12V to 5V module. Reference its + output to your board ground through diode drops or an LDO to land near −3V at the board. Isolation lets you define the negative rail cleanly and regulate it if needed. [Elektroda, Earl Albin, post #21665310]
What frequency and noise should I expect from an ICL7660 inverter?
The internal oscillator runs at about 10 kHz. You can lower it to ~1 kHz by adding a 100 pF capacitor from pin 7 to supply. Lower frequency eases switching loss but increases ripple amplitude, so size capacitors accordingly. [Elektroda, Mark Harrington, post #21665317]
What is a charge‑pump inverter?
It’s a switched‑capacitor circuit that flips a positive input to a negative output using flying capacitors. The ICL7660 and MAX232 families use this method. It’s efficient for low current rails and requires few external parts. [Elektroda, Mark Harrington, post #21665317]
What is a buck‑boost (positive‑to‑negative) converter?
It’s a switching regulator topology that inverts voltage and regulates the negative output. It handles higher current loads than simple charge pumps and maintains regulation across varying loads. Many off‑the‑shelf modules implement this compactly. [Elektroda, Earl Albin, post #21665307]
Which design details must I specify before choosing a method?
State load current, allowable ripple, noise sensitivity, isolation needs, and available PCB area. Without these, proposals miss the mark and can fail under real‑world conditions. Document exact operating modes and duty cycle for worst‑case sizing. [Elektroda, Earl Albin, post #21665312]
Can MC34063A generate -3V from +10V?
Yes. Configure MC34063A in an inverting topology per shared schematics to produce a regulated negative rail. Select inductor, diode, and feedback resistors for −3.0 V and your load current. Validate ripple and stability on your PCB layout. [Elektroda, Eugene Lisovy, post #21665316]
Could I just use a 555 timer to drive a charge pump?
You can. A 555 can clock a discrete charge pump similarly to RS‑232 style inverters. Ensure the driver frequency, capacitor size, and diode selection meet your load current and ripple targets. Watch thermal limits at higher loads. [Elektroda, Mark Harrington, post #21665317]
