Designing a Band Pass Filter for 25 kHz Frequency from Microphone Input
207 6
  • #1 21665530
    furious 555
  • #2 21665531
    Eugene Lisovy
  • Simple RC zero-pole band-pass with 10 kΩ and 640 pF
    #3 21665532
    Earl Albin
  • #4 21665533
    Earl Albin
  • High-Q notch or bandpass filter recommendation
    #5 21665534
    Mark Harrington
  • #6 21665535
    Earl Albin
  • Advocates teaching digital design over analogue filters
    #7 21665536
    Mark Harrington
The discussion addresses designing a band pass filter to isolate a 25 kHz frequency from a microphone input, eliminating other frequencies. It confirms that a band pass filter is suitable for this purpose. One approach involves using an RC network with equal resistor and capacitor values, for example, a 10 kΩ resistor paired with a 640 pF capacitor, maintaining the RC product constant at approximately 6.4×10⁻⁶ to target 25 kHz. The design can be implemented with a zero followed by a pole stage, optionally buffered by an operational amplifier. Additional suggestions include exploring notch filters or high-Q band pass filters using op-amps. Programmable digital filters from Maxim Integrated are also mentioned as an alternative for more precise filtering, though some debate the necessity of digital solutions versus fundamental analog design knowledge. Relevant resources include online active filter calculators and application notes on op-amp notch and band pass filters.
