Why Do All Node Voltages Calculate as Zero in My AC Nodal Analysis Equations?
348 19
Why do all node voltages calculate as zero in my AC nodal analysis equations?
Your node voltages come out zero because your matrix is set up incorrectly: the Y column is all zero, so the equations only produce the trivial zero solution. You need to move the source term, j60, into the Y column by bringing it to the left-hand side so at least one entry in the matrix is non-zero [#21665560] If you do not want to use the matrix form, reduce the equations until you get something like j60 = A·V1, then solve V1 and use it to find V2 and the rest [#21665560] A zero Y matrix cannot give a non-trivial solution [#21665560]
  • #1 21665541
    Naveed Akhtar
  • #2 21665542
    Earl Albin
  • #3 21665543
    Naveed Akhtar
  • Questioning missing V2 and V3 variables
    #4 21665544
    Earl Albin
  • Suggesting rectangular form for mixed complex algebra
    #5 21665545
    Earl Albin
  • #6 21665546
    Earl Albin
  • #7 21665547
    Earl Albin
  • #8 21665548
    Earl Albin
  • #9 21665549
    Naveed Akhtar
  • #10 21665550
    Earl Albin
  • #11 21665551
    Earl Albin
  • #12 21665552
    Naveed Akhtar
  • Zero-voltage nodes at 0 Hz and infinite frequency
    #13 21665553
    Earl Albin
  • Check polar-to-rectangular math and current value
    #14 21665554
    Earl Albin
  • #15 21665555
    Naveed Akhtar
  • Node V1 must be a short to be zero
    #16 21665556
    Earl Albin
  • #17 21665557
    Naveed Akhtar
  • #18 21665558
    Earl Albin
  • #19 21665559
    Naveed Akhtar
  • Move j60 to the left side of the matrix
    #20 21665560
    Earl Albin
The discussion addresses a problem in AC nodal analysis where all node voltages (V1, V2, V3) calculate as zero. The original poster provided nodal equations involving complex impedances and an AC source with a complex value of 0 + 60i (60∠90°). Respondents highlighted issues such as missing schematic details, incorrect or inconsistent node definitions, and algebraic errors in the equations. Key points include the necessity of correctly setting up the nodal admittance (Y) matrix with the AC source terms properly included on the right-hand side to avoid trivial zero solutions. The importance of verifying complex algebra, converting between polar and rectangular forms, and ensuring the reference node is correctly assigned despite reactive components (inductors and capacitors) was emphasized. It was suggested to check branch currents and node voltages by combining impedances in series/parallel and to use software tools for matrix solving once equations are correctly formulated. The zero voltage result likely stems from an incorrect matrix setup where the source term was not properly isolated, leading to a zero Y matrix and thus trivial solutions. Correcting the matrix to include the source voltage as a nonzero entry in the excitation vector enables solving for nonzero node voltages.
TL;DR: 100% of nodal voltages collapse to zero when the Y (source) column is zero—"You can't have a zero Y matrix!" [Elektroda, Earl Albin, post #21665560]
Why it matters: This FAQ helps students and hobbyists fix AC nodal-analysis setups that yield all-zero node voltages.
Why do all my nodal voltages solve to zero?
Because your excitation vector is zero. If you leave the source term out, the matrix yields the trivial all-zero solution. Move the AC source (j60) to the right-hand side so the Y column is non-zero, then solve again. “You can’t have a zero Y matrix!” [Elektroda, Earl Albin, post #21665560]
Where should the AC source appear in my equations?
Place the source phasor on the right-hand side of your nodal equations. Treat it as the excitation vector, separate from conductance/impedance terms. This prevents a zero Y column and avoids the trivial solution. [Elektroda, Earl Albin, post #21665560]
Do I need a schematic with consistent node labels (V1, V2, V3)?
Yes. Share the schematic and ensure labels match your equations. Mismatched or missing node names cause incorrect setups and confusion during checking. Clear labeling also lets others verify KCL/KVL quickly. [Elektroda, Earl Albin, post #21665544]
Should I use KCL or KVL to solve this AC circuit?
Either works. Write KCL at the nodes or convert to KVL loop equations; both lead to the same node voltages when set up correctly. Choose the form you manipulate most accurately. [Elektroda, Earl Albin, post #21665551]
How do I write correct KCL nodal equations here?
Form KCL at each node using admittances to connected elements and sources. Keep source terms separate from impedance terms. Verify each branch current expression before assembling the matrix. [Elektroda, Earl Albin, post #21665550]
What’s the equivalent of the bottom capacitor and inductor branch?
In the posted circuit, the capacitor and inductor combine to an equivalent j1. Use that single impedance in your nodal equations to simplify the matrix. [Elektroda, Earl Albin, post #21665558]
What values should I expect if my setup is correct?
A sanity check reported total current ≈ 10 A at ∠106°. With the left branch impedance, V1 was ≈ 6.20 V near ∠90°. Differences suggest algebra or setup errors. [Elektroda, Earl Albin, post #21665554]
Could V1 actually be zero volts?
Yes, but only if the node is effectively shorted. Check branch currents around V1 to confirm. Frequency extremes can guide intuition: at ∞ Hz, V1 ≈ 22.5 V while V2 and V3 are near 0 V. [Elektroda, Earl Albin, post #21665553]
How can I catch sign and algebra mistakes in complex arithmetic?
Reduce equations carefully and audit every sign. Small sign errors dominate phasor results. Re-derive reduced forms step by step, then verify with a fresh pass before solving. [Elektroda, Earl Albin, post #21665548]
What does “trivial solution” mean in nodal analysis?
It means every node voltage solves to zero. This happens when your excitation vector is zero, such as leaving j60 off the right-hand side. [Elektroda, Earl Albin, post #21665560]
Can my reference node include an inductor?
Yes. You can still choose that node as reference. Combine series reactive elements correctly first; in this case, the capacitor and inductor reduce to j1. [Elektroda, Earl Albin, post #21665558]
Should I compute in polar or rectangular form?
Use whichever reduces errors for you. “Sometimes rectangular works better than Polar.” Convert between forms as needed for clarity and accuracy. [Elektroda, Earl Albin, post #21665545]
Is there a quick three-step way to fix my matrix setup?
  1. Move the source phasor j60 to the right-hand side.
  2. Build the nodal matrix with only admittances/impedances.
  3. Solve for V1, then back-substitute to get V2 and V3. [Elektroda, Earl Albin, post #21665560]
How can I verify my equations with software?
Enter your corrected matrix into any basic linear solver or free circuit tool. Software helps confirm arithmetic, but it won’t fix wrong equations. Start with a correct setup. [Elektroda, Earl Albin, post #21665544]
Why did someone say my equations looked like KVL instead of nodal?
Because earlier, node labels didn’t match the posted equations, suggesting loop equations instead. Align your method and notation with the schematic to remove ambiguity. [Elektroda, Earl Albin, post #21665544]
