LM317T & 2N3055 Regulator for 9.5V Laptop From 11.5-14V Solar/Battery System
312 13
How can I build a 9.5V regulator from an 11.5–14V solar/battery supply using an LM317 and 2N3055 transistors for a laptop load?
Your LM317 + 2N3055 emitter-follower regulator is probably dropping out because 11.5V input does not leave enough headroom for a stable 9.5V output under load, so you need a low-dropout regulator instead [#21665663] One reply suggests using a low-dropout linear regulator rated for about 3A with Vce under 1V, or building one if you cannot buy one [#21665663] Another reply provides a CircuitLab design using 2N3055 pass transistors that should work down to 11.5V, but it is not very efficient and may lose regulation near the minimum input voltage; it would work better with a PNP power transistor for true low-dropout operation [#21665668]
  • Insufficient voltage headroom for LM317 and 2N3055 regulator
    #1 21665658
    ed Kemp
  • #2 21665659
    Cody Miller
  • Describes LM317 and 2N3055 regulator wiring tests
    #3 21665660
    ed Kemp
  • #4 21665661
    ed Kemp
  • Linear regulator cannot hold 9.5 V from 11–14.5 V input
    #5 21665662
    ed Kemp
  • Insufficient headroom causing regulator dropout
    #6 21665663
    Earl Albin
  • Use 12 V supply for EeePC 701
    #7 21665664
    Peter Evenhuis
  • Need practical low-dropout circuit suggestions
    #8 21665665
    ed Kemp
  • 701 netbooks enter protection mode at 12 V
    #9 21665666
    ed Kemp
  • #10 21665667
    Peter Evenhuis
  • 2N3055 regulator works but loses regulation near 11.5V
    #11 21665668
    Steve Lawson
  • #12 21665669
    Joel Sparks
  • #13 21665670
    Steve Lawson
  • #14 21665671
    Momename Garaipoom
A user with a solar/lead-acid power system (11.5–14.5 V) seeks to build a stable 9.5 V linear regulator for multiple Eee PC 701 netbooks, using only an LM317T and two 2N3055 transistors in parallel. The laptops require a tightly regulated 9.5 V ±200 mV supply and draw up to 5 A total. The user’s initial circuit, based on a standard LM317 with 2N3055 pass transistors, experiences voltage drop under load, likely due to insufficient voltage headroom (dropout voltage). Attempts to adjust resistor values and remove emitter resistors did not improve regulation. Suggestions include adding bulk capacitance, using diodes to drop voltage, and considering low dropout regulators or PNP pass transistors for better performance. Some responders note that the Eee PC 701 can operate on 12 V directly, referencing official ASUS power supplies rated at 12 V/3 A, but the user reports regional model differences causing protection mode activation at 12 V. A shared CircuitLab schematic demonstrates a possible regulator design with noted inefficiencies and limited regulation near the input voltage minimum. The discussion highlights challenges of linear regulation with limited parts and low input-output voltage differential, emphasizing the need for low dropout solutions or alternative approaches given the user’s remote location and limited component availability.
TL;DR: Need 9.5 V ±0.2 V at up to 4 A for two EeePC 701s? "You need a low dropout linear regulator." Use LM317 + 2N3055 only if you keep headroom, or feed 12 V with a series diode when charging is off. [Elektroda, Earl Albin, post #21665663]
Why it matters: This FAQ helps off‑grid tinkerers power 9.5 V laptops reliably from 11.5–14.5 V solar/lead‑acid systems with the parts on hand.
Why does my LM317 + 2N3055 regulator sag when I load it from 11.5–14 V?
Because the regulator lacks headroom. The LM317 needs dropout across itself and any pass device. With low input, the 2N3055 stage falls out of regulation and voltage drops. As one expert put it, “You need a low dropout linear regulator.” [Elektroda, Earl Albin, post #21665663]
How much current should I plan for an EeePC 701?
Expect about 0.1–2 A per laptop during use. The original switch‑mode supply was rated 2.5 A, which aligns with brief peaks. Two units can reach ~4 A combined under load. Size wiring, fusing, and heatsinking for these currents. [Elektroda, ed Kemp, post #21665660]
Can I run an EeePC 701 straight from 12 V?
Yes, some users report the 701 runs from 12 V. Use a series power diode to drop voltage a bit and protect against reverse flow. Do not power it while the battery is being charged, since charging raises bus voltage and can trip protection. [Elektroda, Peter Evenhuis, post #21665664]
How do I drop a little voltage safely from 12–14 V?
Insert one or two series power diodes on the positive rail. Each diode adds a small drop and reverse‑polarity protection. This simple method helps when the engine/charger is off, preventing overvoltage to the laptop. Add more diodes if your system idles high. [Elektroda, Peter Evenhuis, post #21665667]
Is there a low‑dropout approach with my parts?
A PNP‑based pass stage can form a lower‑dropout regulator than an NPN emitter follower. One shared design note states a PNP version could meet 11.5 V input limits more comfortably, whereas the shown NPN stage loses regulation near the minimum. [Elektroda, Steve Lawson, post #21665668]
What resistor values did the OP try around the LM317?
Adjust to ground was 1.4 kΩ, adjust to output 220 Ω, and a 10 Ω from output to final node. The 2N3055 bases tied to the LM317 output. Several variations were tried, including removing the 10 Ω and changing the adjust connection, without improving droop. [Elektroda, ed Kemp, post #21665660]
Do two 2N3055s in parallel fix the droop?
Not by themselves. The OP used two 2N3055s in parallel and still saw the output collapse under load. The fundamental limit was input headroom, not just transistor current capability or heatsinking. [Elektroda, ed Kemp, post #21665658]
What bulk capacitance should I place on the output?
Add bulk capacitance at the regulator’s output to support transient load steps. A contributor specifically asked about adding output bulk capacitance to stabilize the laptop load and reduce sag. Large electrolytics you have on hand can help. [Elektroda, Cody Miller, post #21665659]
What input range should I design around in a solar/lead‑acid setup here?
Design for roughly 11–14.5 V at the regulator input. Your control strategy must maintain regulation at the low end and protect the load at the high end. This span defines the required dropout and dissipation window. [Elektroda, ed Kemp, post #21665662]
Is there a ready‑to‑try schematic from the thread?
Yes. One member shared a full schematic and simulator link showing a 9.5 V regulator using power transistors, along with notes on its regulation limits near 11.5 V input and efficiency trade‑offs. Start from that and adapt. [Elektroda, Steve Lawson, post #21665668]
Why did my car laptop charger fail high to 12 V?
The OP reported a charger that failed high, outputting the full 12 V and tripping the laptop’s protection. That failure mode is a known edge case; design your fallback to tolerate a direct 12 V bus if possible. [Elektroda, ed Kemp, post #21665666]
What quick steps get me running today without new parts?
  1. Disconnect any charger so the bus sits near 12 V.
  2. Insert one or two series power diodes to drop and protect.
  3. Connect the EeePC 701 and verify charge LED shows normal behavior. This field method avoids low‑headroom regulation issues. [Elektroda, Peter Evenhuis, post #21665667]
