How to design a 1.2V 15A power supply from 12V/9V input? LM317 or alternatives?
336 12
How can I convert 9V or 12V input into 1.2V at 15A, and is an LM317 suitable for that job?
Use a switching buck converter for this job; a linear LM317 regulator is not suitable for delivering 15A directly. The LM317 is only rated for about 1 to 1.5A, and dropping 12V to 1.2V at 15A would force the regulator to burn about 162W as heat [#21668605] A common efficient example mentioned was the Linear Technology LTM4627 uModule, where 12V to 1.2V at 15A can be done with about 85% efficiency and the 12V source only needs to supply roughly 1.5A [#21668609] Another reply notes that efficient switch-mode supplies can provide much higher output current at lower voltage, whereas linear regulation at that power level is impractical [#21668614] If you insist on a linear approach, one reply suggests boosting the LM317 with multiple 2N3055 pass transistors and adequate input current, but that is still a much less efficient and more complex solution [#21668616]
  • #1 21668604
    JP
  • Linear regulator would dissipate 162 W at 15 A
    #2 21668605
    David Adams
  • #3 21668606
    JP
  • #4 21668607
    Chuck Sydlo
  • #5 21668608
    Chuck Sydlo
  • #6 21668609
    DAVID CUTHBERT
  • #7 21668610
    JP
  • Transformer and high-current switching regulator needed
    #8 21668611
    stephen Van Buskirk
  • #9 21668612
    Chuck Sydlo
  • #10 21668613
    Chuck Sydlo
  • Switch mode supply can exceed input current
    #11 21668614
    Rodney Green
  • #12 21668615
    stephen Van Buskirk
  • LM317 with four 2N3055 pass transistors
    #13 21668616
    Jimmy Babida
Designing a 1.2V 15A power supply from a 12V or 9V input presents significant challenges. The LM317 linear regulator alone cannot handle 15A, as it is rated for about 1 to 1.5A maximum. To achieve 15A output with an LM317, multiple power transistors such as 2N3055 can be used as current boosters, requiring at least four in parallel, along with appropriate resistors and a sufficiently powerful input source capable of delivering over 20A at 9-12V. However, linear regulation at this current and voltage drop results in substantial power dissipation (e.g., 162W at 12V to 1.2V, 15A), causing excessive heat and inefficiency. A more practical and efficient solution is a switching regulator, specifically a buck converter, which can step down voltage with higher efficiency and lower heat dissipation. An example is the Linear Technology LTM4627 uModule, which can deliver 1.2V at 15A with about 85% efficiency, requiring only about 1.5A input current at 12V. For AC mains input (230V), a transformer is needed to step down voltage before rectification and regulation, but such high current DC supplies require large, costly components and careful design. Overall, switching power supplies are recommended over linear regulators for this application due to efficiency and thermal management considerations.
TL;DR: 1.2 V at 15 A equals 18 W, and “you can’t make watts out of thin air.” Use a high-current buck converter, not an LM317 alone. [Elektroda, stephen Van Buskirk, post #21668615]
Why it matters: This FAQ helps makers choose a safe, efficient path to 1.2 V/15 A from 12 V or 230 V AC without burning 162 W as heat.
What is a buck converter, and is it suitable here?
A buck converter steps voltage down while increasing current, conserving power minus losses. It’s the efficient way to get 1.2 V at 15 A from 12 V. [Elektroda, DAVID CUTHBERT, post #21668609]
How much 12 V input current do I need for 1.2 V/15 A?
With an 85% efficient buck, expect about 1.5 A from 12 V. That aligns with module guidance for this operating point. [Elektroda, DAVID CUTHBERT, post #21668609]
Is a linear regulator chain a good idea for 1.2 V/15 A?
No. A linear drop from 12 V to 1.2 V at 15 A dumps roughly 162 W as heat, demanding massive heatsinking and wasting power. [Elektroda, David Adams, post #21668605]
How do I get 1.2 V/15 A from 230 V AC safely?
Step down with a transformer, rectify with a bridge, add large filter capacitors, then use a high-current switching stage. Size everything for 15 A. [Elektroda, stephen Van Buskirk, post #21668611]
Could an LM317 drive pass transistors to reach 15 A?
One proposal used LM317 driving four 2N3055 pass transistors with 0.15 Ω emitter resistors and ~20 A input. Thermal design remains critical. [Elektroda, Jimmy Babida, post #21668616]
Why not use the LM317 as the main 15 A regulator?
It can act as a driver, not the 15 A element. LM317’s current rating and the heat at low output voltage make it unsuitable alone. [Elektroda, David Adams, post #21668605]
What’s the practical difficulty level of a 15 A switching supply?
It is non-trivial. High-current switchers need careful layout, magnetics, and protection. “No piece of cake,” as one expert said. [Elektroda, stephen Van Buskirk, post #21668615]
Any quick analogy for why 12 V/1 A can’t feed 1.2 V/15 A?
Think squirt gun versus garden hose. The source power is too low to sustain the higher-current load, regardless of regulator type. [Elektroda, Chuck Sydlo, post #21668607]
What if my application truly needs 1.2 V at 15 A?
State the load details. Contributors noted there may be simpler solutions depending on the device, wiring, or cell configuration. [Elektroda, Chuck Sydlo, post #21668613]
How do I plan a 12 V → 1.2 V/15 A buck design?
  1. Select a 15 A-capable buck module (e.g., LTM4627 class). 2. Size the 12 V source for ~1.5 A at 85% efficiency. 3. Validate thermals and wiring. [Elektroda, DAVID CUTHBERT, post #21668609]
What’s a common failure or edge case to watch for?
Under-sizing a linear stage risks thermal runaway. At 12 V in, a 1.2 V/15 A linear drop means about 162 W to dissipate. [Elektroda, David Adams, post #21668605]
