LM317LCLP USB-Powered Circuit Outputting Only 3V/1.45V Instead of 3.3V/1.6V
837 17
Why does my LM317L USB-powered circuit only reach about 3.0V and 1.45V instead of 3.3V and 1.6V, and how can I fix it?
Your circuit is likely hitting the LM317L’s dropout limit and thermal limiting: with a USB supply that may be only 4.75V, the regulator needs roughly 1.5–1.9V of headroom, so a 3.3V output can sag to around 3.15V or less, especially if the part is getting hot [#21669399] The 36Ω divider load alone draws about 92mA at 3.3V, which is already close to the LM317L’s 100mA limit and leaves very little current for the rest of the load [#21669397][#21669400] That means the divider is not a light “sense” load; it is a major part of the regulator load and contributes to heating and output droop [#21669400][#21669410] One suggestion was to lower R1 from 1.2kΩ toward 470Ω if you keep using an LM317-type regulator, and to verify the actual input-to-output voltage drop directly [#21669396][#21669399] A better fix is to use a low-dropout regulator instead of the LM317L, or redesign with separate regulators and a supply voltage with enough headroom, since the present USB-powered setup is marginal [#21669399][#21669409]
  • USB supply voltage too low for LM317 dropout
    #1 21669395
    John S
  • Lower R1 to compensate for low-voltage reference shift
    #2 21669396
    Malcolm Whinfield
  • Voltage divider midpoint likely tied to adj pin
    #3 21669397
    Rohit Dubla
  • Voltage divider load current limited by 36 ohms
    #4 21669398
    John S
  • Dropout voltage and thermal limiting likely causing sag
    #5 21669399
    Steve Lawson
  • #6 21669400
    Steve Lawson
  • LM317 dropout likely too high for 3.3 V output
    #7 21669401
    John S
  • 36 Ω load leaves too little current for black box
    #8 21669402
    Steve Lawson
  • Load-dependent dropout requires circuit redesign
    #9 21669403
    John S
  • Datasheet limits matter more than simulation
    #10 21669404
    Rohit Dubla
  • Estimated load resistances from measured current draw
    #11 21669405
    John S
  • Using two LM317 regulators from a 9 V adapter
    #12 21669406
    John S
  • #13 21669407
    Steve Lawson
  • #14 21669408
    Rohit Dubla
  • Suggesting fixed 3.3 V regulator instead of LM317
    #15 21669409
    Steve Lawson
  • Reduce input-output voltage difference for LM317L efficiency
    #16 21669410
    Malcolm Whinfield
  • #17 21669411
    Steve Lawson
  • Questioning low-power switching regulator efficiency
    #18 21669412
    Rohit Dubla
A circuit designed to convert 5V USB input to 3.3V and 1.6V outputs using an LM317LCLP adjustable linear regulator is producing lower voltages (3V and 1.45V) than expected. The design includes a 1.2kΩ resistor (R1), a 2kΩ potentiometer (R2), and a voltage divider with two 18Ω resistors in series parallel to the output capacitor. The issue is attributed to the LM317's dropout voltage, which can be as high as 1.5–1.9V depending on load current, making it unsuitable for a 5V USB supply when targeting 3.3V output. The load current through the voltage divider is approximately 92mA, close to the LM317L's 100mA maximum output current, causing voltage drop and regulator heating. Suggestions include lowering R1 to reduce reference voltage impact, replacing the LM317L with a low dropout regulator such as the LM1086CT-ADJ (typical dropout ~1.3V), or using separate regulators for each voltage output powered from a higher voltage source (e.g., 9V wall adapter). The importance of verifying load current, avoiding voltage dividers for load supply, and breadboarding or simulating with real load conditions is emphasized. Alternative fixed low-dropout regulators like the 78L33A, MCP1702, or LP2950-33LP are recommended for improved efficiency and stability. The discussion highlights the need to consider dropout voltage, load current, and thermal dissipation in linear regulator designs, especially when powered from limited voltage sources like USB.
TL;DR: USB 5V can dip to 4.75V, and LM317L dropout is ~1.6–1.9V; “Looks like part of your problem might be Dropout Voltage.” [Elektroda, Steve Lawson, post #21669399]
Why it matters: If you power LM317L from USB, dropout plus USB tolerance can cap output near 3.0V, not 3.3V.
Why does my USB-powered LM317L only output ~3.0V instead of 3.3V?
Because USB can be as low as 4.75V and LM317L’s dropout near 100 mA is ~1.6–1.9V. That leaves only ~3.15V headroom, so the regulator cannot reach 3.3V. Measure Vin–Vout to confirm dropout on your board. “Looks like part of your problem might be Dropout Voltage.” [Elektroda, Steve Lawson, post #21669399]
How much current do two 18Ω resistors in series (as a divider from 3.3V) draw?
About 92 mA: I = 3.3V / (18Ω + 18Ω) = 0.0917 A. That quiescent load already uses most of an LM317L’s 100 mA capability, leaving little for your actual circuit. This heavy divider also increases dropout and heat. [Elektroda, Steve Lawson, post #21669400]
What is dropout voltage in plain terms?
Dropout is the minimum difference between input and output for a regulator to regulate. With USB min at 4.75V, a 3.3V rail needs ≤1.45V dropout. LM317L often needs ~1.6–1.9V near 100 mA, so it falls out of regulation from USB. [Elektroda, Steve Lawson, post #21669399]
How do I measure dropout on my existing PCB?
Load the 3.3V rail as in use, then measure Vin and Vout pins. Dropout equals Vin minus Vout. If this value rises near 1.6–1.9V at your load, the LM317L can’t hold 3.3V from USB’s 4.75–5.25V. [Elektroda, Steve Lawson, post #21669399]
Why did the LM317L get painfully hot when powered from 7V?
Linear regulators burn the voltage difference as heat: P ≈ (Vin−Vout)×I. Heat can trigger internal thermal limiting, which lowers output voltage until the die cools. That looks like random sag but is self-protection. [Elektroda, Steve Lawson, post #21669399]
Should I reduce R1 from 1.2 kΩ to 470 Ω on the LM317L?
Lowering R1 can improve reference behavior at low input headroom, aligning with datasheet guidance. Using 470 Ω is a common starting value for LM317 reference current. Recalculate R2 to set your target voltage afterward. [Elektroda, Malcolm Whinfield, post #21669396]
Is a resistive divider a good way to derive 1.6V from 3.3V?
Not with low resistor values. Your 36Ω divider wastes ~92 mA and starves the regulator and load. Use a dedicated 1.6V regulator or redesign the divider with high values if the 1.6V node draws almost no current. [Elektroda, Rohit Dubla, post #21669397]
What regulators should I pick for 3.3V and 1.6V rails?
Use an LDO or fixed 3.3V regulator, and a separate adjustable/fixed LDO for 1.6V. Options suggested include 78L33A, MCP1702, LP2950-33, or LP2951-ADJ; check capacitor requirements and current limits. [Elektroda, Steve Lawson, post #21669409]
Can I trust Multisim or other simulators for regulator behavior?
Simulators won’t enforce real device limits like dropout, thermal limits, and max current. Always read the datasheet and breadboard critical cases. “The importance of going through the datasheet cannot be understated.” [Elektroda, Rohit Dubla, post #21669404]
How do I redesign using two regulators from a 9V, 700 mA adapter?
Feed both regulators from 9V, one set to 3.3V and the other to 1.6V. Ensure the adapter’s current covers both loads with margin, and that each IC’s current limit exceeds its rail draw. [Elektroda, Rohit Dubla, post #21669408]
What current does the ‘black box’ actually draw at 3.3V and 1.6V?
Measured values were Icc ≈ 73 mA at 3.3V and Iac ≈ 2.17 mA at 1.6V. That implies about 45Ω and 737Ω effective resistances respectively (V/I). Size regulators and thermal design for these loads. [Elektroda, John S, post #21669405]
Quick 3‑step: how do I diagnose low LM317L output from USB?
  1. Measure USB input under load; note the minimum it reaches.
  2. Measure Vin and Vout at the regulator; compute dropout.
  3. Measure load current and regulator temperature; watch for thermal limiting. [Elektroda, Steve Lawson, post #21669399]
Will a linear regulator here be inefficient? Does it matter?
Linear efficiency is limited by (Vout/Vin). Large Vin−Vout becomes heat, so heatsinking or lower Vin helps. If efficiency is not a requirement, simplicity may win; otherwise consider LDOs or switching options. [Elektroda, Malcolm Whinfield, post #21669410]
Could thermal limiting be the hidden failure mode on my board?
Yes. If the LM317L overheats, it reduces output current or voltage to protect itself. This looks like droop under load and recovers as temperature falls. Improve cooling or reduce Vin−Vout and load. [Elektroda, Steve Lawson, post #21669399]
