Combining StefanV USB Charger & 3V-5V Step-Up Converter for Windbelt Power Bank?
282 7
  • Need a proper battery charger and boost stage
    #1 21666118
    Ruuth F
  • #2 21666119
    Mark Harrington
  • Clarifying windbelt output and battery bank role
    #3 21666120
    Steve Lawson
  • #4 21666121
    Ruuth F
  • #5 21666122
    Ruuth F
  • Questioning the need to step down to 3 volts
    #6 21666123
    Mark Harrington
  • Separate chargers and rectifiers for each battery pack
    #7 21666124
    Steve Lawson
  • Basic 12 V wind generator charging circuit suggestion
    #8 21666125
    Frank Bushnell
The discussion centers on integrating StefanV's USB charger circuit with a 3V-to-5V step-up converter to create a 5V power bank powered by a windbelt generator. The main challenge is how to combine these two circuits effectively at their battery terminals to charge and draw power from a battery bank. Clarifications reveal the windbelt generator outputs approximately 3V, which requires stepping up to 5V for charging batteries and powering USB devices. Suggestions include using separate charging circuits for each battery pack with diode isolation (preferably Schottky or fast recovery diodes) to prevent backflow and maintain battery health. It is also noted that charging multiple batteries in parallel with a single circuit risks imbalance if one battery degrades. Questions arise about the rationale for stepping down to 3V batteries only to step back up to 5V, suggesting a more direct charging approach might be more efficient. Additional advice includes verifying the windbelt generator's voltage and current output under varying wind conditions and considering voltage regulation components like the 7808 regulator with heat sinking for stable output. The overall recommendation is to prototype the combined circuit and test its performance, keeping in mind the trade-offs between complexity, efficiency, and battery management.
