Connecting 12V SuperCap Bank to Charge 72V Battery Bank from DC Wind Generator
327 8
  • Need a dc-dc converter for 12v to 72v charging
    #1 21667181
    NuevaEra
  • 12V to 72V boost converter recommended
    #2 21667182
    Steve Lawson
  • #3 21667183
    Steve Lawson
  • #4 21667184
    NuevaEra
  • Direct battery charging is more efficient than supercaps
    #5 21667185
    Frank Bushnell
  • Using six 12 V boost converters in series
    #6 21667186
    NuevaEra
  • Use isolated inverter-charger per battery cell
    #7 21667187
    Steve Lawson
  • #8 21667188
    NuevaEra
  • #9 21667189
    Steve Lawson
A user with a DC wind generator producing nearly constant 12V DC energy is using a 12V Super Capacitor bank to store this energy and wants to charge a 72V battery bank composed of six 12V batteries in series, which powers a 72V electric motor. The challenge is how to effectively transfer energy from the 12V SuperCaps to the 72V battery bank. Direct parallel connection of the SuperCaps to individual 12V batteries is possible but inefficient and requires multiple charging cycles. Suggested solutions include using a 12V to 72V DC-DC boost converter, though such devices may not be readily available off-the-shelf and might require custom design. Alternatively, using six isolated 12V to 12-15V boost converters, each charging one 12V battery in the series string, was proposed to maintain individual battery health and prevent overcharging. Another idea involves converting 12V DC to 120VAC via an inverter, then rectifying and regulating the output to charge the 72V battery bank with proper voltage monitoring. The SuperCaps serve as an energy buffer to smooth generator fluctuations. Considerations include ensuring isolation between converters, appropriate charging voltages above nominal battery voltage, and component ratings such as diode current capacity. The system is intended for a remote zip line application in a mountainous area without grid access.
