Why Does ISDN's 20x Frequency Band Increase Only Double the Bit Rate vs Dial-Up Modem?
414 6
  • #1 21666452
    Magoumba Serigne Amar
  • ISDN uses two 64 kbit/s bearer channels
    #2 21666453
    Peter Evenhuis
  • Questioning whether reliability or protocol overhead explains ISDN speed gain
    #3 21666454
    Steve Lawson
  • Questioning the 80 kHz ISDN bandwidth assumption
    #4 21666455
    Todd Hayden
  • ISDN uses 8-bit PCM bearer channels
    #5 21666456
  • #6 21666457
    john Poole
  • ISDN as backup during ADSL lightning outages
    #7 21666458
    Peter Evenhuis
The discussion addresses why the ISDN frequency band, which is approximately 20 times wider than that of dial-up modems (4 kHz to 80 kHz), results in only about double the bit rate (56 kbps to 128 kbps). ISDN Basic Rate Interface (BRI) consists of two 64 kbps bearer (B) channels for voice or data and one 16 kbps data (D) channel for signaling, totaling 144 kbps gross throughput. The 128 kbps figure refers to the combined capacity of the two B channels. Dial-up modems transmit analog audio signals limited by a low-pass filter around 3.2 kHz, effectively using 7 bits per sample at 8000 samples per second, yielding 56 kbps. ISDN uses digital transmission with 8 bits per sample at 8000 samples per second per channel. The bandwidth increase is not directly proportional to bit rate due to differences in modulation methods, channel structure, and signaling overhead. ISDN was designed for existing telephone infrastructure and predates widespread internet use, whereas technologies like ADSL, which operate on top of ISDN or POTS lines, provide significantly higher speeds by utilizing more advanced modulation and wider frequency bands. The discussion also notes ISDN's reliability and legacy use as a backup connection compared to ADSL, which is more susceptible to line noise and environmental factors.
