Analog Bandwidth Required for 125Mbps 8b10b Serial Link Over Copper Cable?
297 9
How do I determine the analog bandwidth needed to run a 125 Mbps 8b10b serial link over copper cable?
There is no single “fundamental analog frequency” for a 125 Mbps 8b10b link; for NRZ-like data the spectral content depends on the pattern, and a common rule of thumb puts the first null at the bit rate itself, about 125 MHz rather than 62.5 MHz [#21660440][#21660442] If you need the practical analog bandwidth, use the rise-time rule BW = 0.35/Tr, because the transmitter/receiver rise time, not the bit rate alone, determines the required bandwidth [#21660443] The harmonics are only relevant insofar as they affect signal integrity and rise time [#21660444] For the cable, pay attention to impedance, attenuation, dispersion, crosstalk, return loss, and shielding rather than trying to reduce everything to one bandwidth number [#21660438]
  • Need cable bandwidth for 125 Mbps 8b10b link
    #1 21660435
    Eric Vogel
  • #2 21660436
    Frank Walker
  • #3 21660437
    Eric Vogel
  • Cable impedance, attenuation, and crosstalk considerations
    #4 21660438
    Todd Hayden
  • 8b10b link bandwidth estimated at 62.5 MHz fundamental
    #5 21660439
    Eric Vogel
  • Bandwidth depends on cable loss and receiver design
    #6 21660440
    Todd Hayden
  • 8b10b fundamental frequency is about half the data rate
    #7 21660441
    Eric Vogel
  • Spectral spacing set by 125 Mbps pattern length
    #8 21660442
    Todd Hayden
  • Rule of thumb for required analog bandwidth
    #9 21660443
    Frank Walker
  • #10 21660444
    Frank Walker
A custom serial data link using 8b10b encoding at a line rate of 125 Mbps (with a 100 Mbps pre-encoded throughput) requires careful analog bandwidth specification for copper media such as coaxial or UTP/STP cables over distances up to 300 feet. The fundamental frequency or analog bandwidth is debated: some suggest it is half the line rate (62.5 MHz), while others reference the full line rate (125 MHz) as the fundamental frequency. The bandwidth needed depends on the signal rise time, with a common rule of thumb BW = 0.35 / Tr (rise time), which accounts for harmonics affecting signal integrity. The spectral content is complex due to 8b10b DC balancing and pseudo-random data patterns, resulting in a spectrum envelope rather than a single fundamental frequency. Cable characteristics critical for long runs include impedance matching, attenuation, capacitance-induced dispersion, crosstalk, insertion loss, return loss, NEXT, and FEXT. Practical testing on Belden 7927A (CAT6a) cable at 300 feet showed successful operation. Consulting cable manufacturers like Belden with specified bandwidth requirements based on rise time and attenuation is recommended for optimal media selection.
