Do Electrons Physically Move in a Conductor or Just Align When Voltage Is Applied?
450 11
Do electrons physically move through a conductor when voltage is applied, or do they only align in one direction?
Electrons do move through a conductor; in metals the outer electrons are loosely bound and an applied electric field drives charge carriers through the material rather than them only aligning [#21666830][#21666834] The motion is usually a slow average drift, which is why the term drift velocity is used [#21666826][#21666833] That moving charge can generate a magnetic field, heat, and, at high frequency, skin effect [#21666826]
  • #1 21666825
    victor Nyami
  • #2 21666826
    Steve Lawson
  • #3 21666827
    Peter Owens
  • Electron transfer through conductors explained as atom-to-atom exchange
    #5 21666829
    Mark Harrington
  • Electric field drives free electrons in conductors
    #6 21666830
    Steve Lawson
  • Free electrons and atomic structure discussion
    #7 21666831
    Mark Harrington
  • Incorrect noble gas and ionization claims about bonding
    #8 21666832
    Mark Harrington
  • Electrons do move, but drift velocity is negligible
    #9 21666833
    Daniel Kinney
  • Free electron model in metals and plasma
    #10 21666834
    Steve Lawson
  • #11 21666835
    Steve Lawson
  • Recommends solid-state physics and MIT notes
    #12 21666836
    Norman Chahuares
Electrons in a conductor do physically move, but their motion differs from common intuition. When a voltage is applied, electrons drift slowly with a small average velocity called drift velocity, which results in an electric current (I = Q/t). This movement of charge carriers generates effects such as magnetic fields, heat, and phenomena like the skin effect at high frequencies. The conduction mechanism involves free electrons in metals, which are loosely bound and can move through the lattice, propelled by the electric field. Rather than electrons traveling at near light speed, the electrical signal propagates rapidly due to the electric field's influence, while individual electrons move much slower. Electron flow is often described as atoms exchanging electrons rather than electrons traveling freely like cars on a highway. The concept of free electrons is central to understanding conduction in metals like copper, silver, and gold. The discussion also touches on atomic electron configurations and the stability of noble gas structures, which relate to electron gain or loss in ionic bonding but are distinct from conduction electron behavior. Educational resources and lecture notes on solid-state physics and microelectronic devices provide further detailed explanations.
TL;DR: Electrons do move; their drift speed in copper is about millimeters per second, while the signal propagates near light speed. “The electrons themselves move very slowly.” “Microscopic View of Ohm’s Law”
Why it matters: This FAQ helps students, hobbyists, and engineers clarify how current actually flows so they can reason about heat, EMI, and wiring choices.
  • Typical electron drift velocity in a 1 mm² copper wire at 1 A is on the order of mm/s; the field propagates much faster. “Microscopic View of Ohm’s Law”
  • Signal/field speed in cables is a significant fraction of c due to the medium’s velocity factor, not the electron speed. Physics Van: Do electrons move?
  • In metals, conduction uses “free” conduction-band electrons described by the free-electron model. Free electron model
  • Moving charge creates magnetic fields and dissipates heat: I²R losses appear where current flows. AAC Vol 1 Ch 1: What is Current?
  • At high frequency, skin effect shifts current toward the surface; at DC current fills the cross‑section. [Elektroda, Steve Lawson, post #21666826]
Do electrons physically move in a conductor when voltage is applied?
Yes. An electric field pushes conduction electrons, giving them a small net drift velocity superimposed on random thermal motion. The observable effects include magnetic fields around conductors and resistive heating. “Electrons do move; the drift speed is very slow compared with the signal’s speed.” Physics Van: Do electrons move?
If electrons move so slowly, why do lights turn on almost instantly?
The signal is the electromagnetic field establishing along the circuit at a significant fraction of light speed. Electrons only nudge slightly; the field communicates the push quickly through the conductor-dielectric system. That’s why devices respond essentially immediately over household distances. Physics Van: Do electrons move?
What is electron drift velocity, in plain terms?
Drift velocity is the average net speed of charge carriers under an electric field. In copper carrying 1 A through 1 mm², it’s about millimeters per second. It depends on current, carrier density, charge, and area via v = I/(nqA). “Microscopic View of Ohm’s Law”
Do electrons “hop” atom to atom or flow like a fluid?
In metals, many outer electrons occupy conduction bands and behave like a gas of charge carriers. Under an electric field, this electron gas drifts; it’s not discrete hopping in the classical sense. The free‑electron model captures this behavior for many metals. Free electron model
Where does the magnetic field around a wire come from?
Moving charge creates a magnetic field encircling the current path. The field strength increases with current, and the energy dissipated as heat follows I²R. This is why higher currents demand thicker conductors and careful layout. AAC Vol 1 Ch 1: What is Current?
Is electron flow direction the same as conventional current?
No. Conventional current points from positive to negative. In metal conductors, electrons drift from negative to positive. Both conventions predict the same measurable results when used consistently. AAC Vol 1 Ch 1: What is Current?
How fast does a signal travel in a wire or cable?
The field travels at a fraction of light speed set by the dielectric’s permittivity (velocity factor). Typical cables fall around 0.5–0.8c. The electrons’ drift remains much slower and does not limit signal speed in this context. Physics Van: Do electrons move?
What causes heating in conductors if electrons move so slowly?
Collisions between drifting electrons and the lattice convert electrical energy into thermal energy. Power lost as heat follows P = I²R. Good design minimizes resistance and manages heat with proper gauge and cooling. AAC Vol 1 Ch 1: What is Current?
What is the skin effect, and when should I care?
At high frequency, alternating current crowds near the surface, reducing effective cross‑section and raising AC resistance. It’s negligible at DC but matters for RF, high‑speed digital, and long AC runs. [Elektroda, Steve Lawson, post #21666826]
Do free electrons really exist in metals at room temperature?
Yes. In many metals, valence electrons occupy a conduction band and act as mobile carriers with minimal binding, enabling metallic conductivity. The free‑electron model explains many bulk properties despite its simplifications. Free electron model
How do batteries make electrons move through a circuit?
A chemical reaction maintains an electric potential between terminals, creating an electric field in the connected circuit. That field drives electrons through the external path while chemistry shuttles charge internally. AAC Vol 1 Ch 1: What is Current?
Can current flow from positive to negative in practice?
Conventional current direction is defined as positive to negative. In some systems with different carriers (holes, ions), carrier motion aligns with this convention. Use the convention consistently for analysis and polarity labeling. AAC Vol 1 Ch 1: What is Current?
How can I estimate drift velocity for my wire? (3‑step)
  1. Find current I and wire cross‑section A.
  2. Use copper’s electron density n ≈ 8.5×10^28 m⁻³ and charge q = 1.602×10⁻¹⁹ C.
  3. Compute v = I/(n q A). Compare across gauges to see how area affects v. “Microscopic View of Ohm’s Law”
Do semiconductors and plasmas carry current the same way as metals?
They carry current via different carriers. Semiconductors use electrons and holes; plasmas use ions and electrons. The electric field still drives carriers, but densities and mobilities differ from metals. MIT 8.02 Study Guide 6
What’s an authoritative resource to study microscopic current flow?
Study band theory basics and drift‑diffusion. Good starting points include MIT OCW notes on carrier transport and field propagation, which tie physics to circuits. MIT 6.012 Lecture 3 Notes
What is an edge case where intuition fails?
In superconductors, electrons form Cooper pairs and move without resistance below a critical temperature. Drift can exist with essentially zero I²R heating, defying normal conductor intuition. MIT 8.02 Study Guide 6
