Why Does Connecting Unsynchronized Generator and Utility via Transfer Switch Cause Damage?
366 7
  • #1 21667344
    ASAD ALI
  • Synchronization required before paralleling generators
    #2 21667345
    Steve Spence
  • #3 21667346
    ASAD ALI
  • #4 21667347
    Steve Spence
  • Out-of-phase generators create massive circulating current
    #5 21667348
    Frank Bushnell
  • #6 21667349
    Mitz
  • #7 21667350
    Frank Bushnell
  • Unsynchronized phase offset causes short circuit and engine damage
    #8 21667351
    Peter Evenhuis
Connecting two unsynchronized AC power sources, such as a generator and utility supply, via a transfer switch can cause severe electrical damage or a blast due to phase angle and frequency mismatches. Proper paralleling requires synchronization, meaning both sources must match in voltage, frequency, and phase angle before connection. Without synchronization, the out-of-phase voltages create large circulating currents and short circuits, analogous to connecting two AC voltage sources with differing polarities. This results in electrical faults, mechanical stress, and potential catastrophic failure. Synchronization is typically achieved using instruments like synchroscopes or light banks to align the lagging generator's speed and phase with the lead generator or utility bus before closing the switch. Even small phase angle errors (e.g., 10 degrees) can cause significant short circuits and mechanical damage to the generator engine.
