JVC RX-8010 Receiver: Are 75°C Power Transistor Temps Normal at Half Volume?
384 10
Are the 2SD2395 power transistors in my JVC RX-8010 receiver supposed to run around 75°C and be too hot to touch at half volume?
Yes, those transistors can run that hot in this receiver, especially when the volume is raised and the speakers are 8 ohms, because they appear to be crude series-pass regulators feeding low-voltage rails and can have significant collector-emitter voltage across them [#21667664][#21667666] If the collector-side resistors have not burned and the receiver is otherwise operating normally, that points toward normal behavior rather than a failed part [#21667663] One reply also noted that the 2SD2395 datasheet lists a 150°C maximum junction temperature, so 75°C on the heatsink is probably within safe limits, though adding a fan or larger heatsink would reduce temperature further [#21667659]
  • 75°C heatsink temperature at half volume questioned
    #1 21667657
    casu Micu
  • #2 21667658
    Mark Harrington
  • 2SD2395 junction temp and heatsink advice
    #3 21667659
    Steve Lawson
  • #4 21667660
    Rodney Green
  • Need full schematic to trace power transistor rails
    #5 21667661
    Mark Harrington
  • #6 21667662
    Steve Lawson
  • #7 21667663
    David Adams
  • Series pass regulators likely causing transistor heating
    #8 21667664
    Steve Lawson
  • High heat on 2SD2395 output transistors at moderate volume
    #9 21667665
    casu Micu
  • #10 21667666
    Steve Lawson
  • #11 21667667
    casu Micu
The discussion concerns the temperature of six 2SD2395 power transistors on a JVC RX-8010 receiver, which reach approximately 75°C at half volume. The user experienced failures in Darlington pair transistors (2SD2560 & 2SB1647) on the front right and left channels, replaced them, and set the idling current per the service manual, resolving the immediate issue. The 2SD2395 transistors are part of crude series pass voltage regulators supplying various voltages (5.6V, 6.2V, ±12V, 9V) in the receiver. Given the datasheet maximum junction temperature of 150°C for the 2SD2395, 75°C on the heat sink is likely within normal operating range, though adding a fan or larger heatsink could improve cooling. The power transistors get hot due to voltage drop across emitter-collector junctions and current load, especially with 8Ω speakers and higher volume levels. The presence of small wattage resistors in the collector circuits that are not burnt suggests normal operation. Complete schematics and voltage/load measurements would aid further diagnosis.
