Best Metal for Conductive, Springy Strip in Gatling Potato Gun Tazer Ignition?
312 18
What metal should I use for a springy conductive strip that rakes across spinning steel barrels to transfer tazer power?
Use spring steel or beryllium copper; the thread leans toward spring steel because it is easier to find and cheaper, while beryllium copper is the classic spring-copper option [#21661006][#21661011] For a limited-use home project, 6061-T6 aluminum was also suggested, since its oxide layer should be punched through at tazer voltages and sliding contacts tend to self-clean [#21661023] If you want ready-made parts, spring clips or battery contacts with beryllium copper spring plates were also suggested as practical sources [#21661022]
  • Springy conductive strip material recommendation
    #1 21661005
    Andrew LeVino
  • #2 21661006
    Bob Loy
  • #3 21661007
    Andrew LeVino
  • #4 21661008
    Bob Loy
  • #5 21661009
    Bob Loy
  • #6 21661010
    Andrew LeVino
  • Spring steel recommended over beryllium copper
    #7 21661011
    Bob Loy
  • Spring strip suggestion and saltwater conductivity idea
    #8 21661012
    Steve Lawson
  • Redesigning the electrical system for water cooling
    #9 21661013
    Andrew LeVino
  • #10 21661014
    Steve Lawson
  • Using a tiny arc to trigger ignition
    #11 21661015
    Steve Lawson
  • Motor-fed arc rod to maintain gap
    #12 21661016
    Steve Lawson
  • #13 21661017
    Andrew LeVino
  • #14 21661018
    Steve Lawson
  • #15 21661019
    Andrew LeVino
  • Commutator-based rotating firing mechanism suggestion
    #16 21661020
    Frank Bushnell
  • #17 21661021
    Sarah Harris
  • Beryllium copper spring clip recommendations
    #18 21661022
    Todd Hayden
  • #19 21661023
    DAVID CUTHBERT
The discussion centers on selecting an optimal conductive, springy metal strip for a Gatling-style potato gun ignition system using a taser to fire each barrel as the cylinder rotates. Beryllium copper (spring copper) is initially suggested for its conductivity and spring properties, though concerns arise about its anti-sparking characteristics, which are clarified to refer to mechanical sparks rather than electrical conductivity. Spring steel is proposed as a more readily available and cost-effective alternative with sufficient conductivity for taser-level currents. Additional ideas include using actual springs for flexibility, though potential welding to contact surfaces is a concern. Innovative concepts such as water spray with conductive impurities and ionized gas arcs are discussed but deemed complex or impractical. A mechanical commutator from an electric motor is recommended as a proven high-current sliding contact solution. Other suggestions include using 6061-T6 aluminum for its self-cleaning sliding contact properties despite oxide formation. Sources for beryllium copper spring clips and battery connectors are provided, including Seastrom and Becu Manufacturing, along with a Digikey part link for spring clips. Titanium or tungsten carbide drill bits are mentioned as durable arc contact materials. Overall, the consensus favors spring steel or beryllium copper strips for the conductive, springy contact, with practical considerations for availability, cost, and mechanical wear.
TL;DR: For a 2-inch conductive, springy contact on a rotating potato-gun igniter, use 6061‑T6 aluminum or spring steel; “sliding contacts are self-cleaning.” [Elektroda, DAVID CUTHBERT, post #21661023]
Why it matters: This FAQ helps hobbyists choose and mount reliable sliding contacts for taser-based multi-barrel ignition.
What metal works best for a conductive, springy strip on a rotating taser ignition?
Use 6061‑T6 aluminum for an easy, robust sliding contact, or spring steel for durability against repeated rakes. Aluminum’s oxide gets punched through at taser voltages, and sliding action self‑cleans. Spring steel is cheap and widely available. [Elektroda, DAVID CUTHBERT, post #21661023]
Is beryllium copper (BeCu) a good choice here?
Yes, for springiness and stable contact pressure. Its “non‑sparking” property refers to preventing mechanical sparks, not stopping electrical conduction. It will still pass taser discharge to your barrel contacts. Consider clip forms if you need defined preload. [Elektroda, Bob Loy, post #21661008]
What size should the contact strip be for each barrel pass?
Build around a 0.5–0.75 inch width and about 2 inches length so the barrel plate reliably sweeps the contact during rotation. This footprint balances contact area and manageable spring force in compact builds. [Elektroda, Andrew LeVino, post #21661005]
Where can I buy suitable spring contacts or clips?
Repurpose battery contacts or spring plates from suppliers like Digi‑Key, or order spring clips from Seastrom. Some BeCu manufacturers will provide samples. These parts give consistent pressure and easy mounting. [Elektroda, Todd Hayden, post #21661022]
Will a simple steel spring work as the brush?
Yes, a metal coil or leaf spring can flex and return to position during each sweep. Watch for a failure edge case: localized arcing can cause micro‑welding of the spring to the track under poor alignment or excessive pressure. [Elektroda, Steve Lawson, post #21661012]
How do I keep visible sparks to a minimum for a safer user impression?
Favor a solid sliding contact over intentional air gaps. Avoid pointed electrodes facing the track, and use smooth, flat interfaces. As one user noted, visible arcing can be unsettling to operators. A continuous brush‑on‑plate contact reduces arc length. [Elektroda, Andrew LeVino, post #21661017]
Could I adapt a motor commutator approach for multi‑barrel firing?
Yes. A commutator provides timed conduction via segmented copper and stationary brushes. One proposal ties opposing segments to a barrel, with an event every 180 degrees. This gives robust, repeatable timing on a rotating assembly. [Elektroda, Frank Bushnell, post #21661020]
Quick how‑to: build a simple commutator contact for a rotating ignition ring?
  1. Salvage a suitable DC motor; keep the commutator and shaft.
  2. Remove windings; connect each barrel to opposing commutator segments.
  3. Mount fixed brushes to feed the taser output as the shaft rotates. [Elektroda, Frank Bushnell, post #21661020]
What is a commutator, in plain terms?
A commutator is a segmented conductor on a rotating shaft. Stationary brushes touch the segments to route current at specific angles. In this project, segments can map to barrels, giving synchronized firing as the cylinder turns. [Elektroda, Frank Bushnell, post #21661020]
Can I use a PCB track and a spring-loaded ball for smoother contact?
Yes. A ball catch with adjustable spring force can ride over a copper PCB track. This offers low-friction, self-centering contact and easy force tuning by swapping springs or adjusting preload. [Elektroda, Sarah Harris, post #21661021]
Does aluminum’s oxide layer block the taser current?
Not in this setup. At taser voltage, the thin oxide breaks down. Sliding contact also wipes and refreshes the interface. As the contributor put it, “sliding contacts are self-cleaning,” which helps maintain reliable ignition. [Elektroda, DAVID CUTHBERT, post #21661023]
Is deliberately arcing across a small air gap a workable strategy?
It can work, since a spark uses ionized air as the path. Keep the gap tiny to limit energy loss before the chamber spark. A pointed rod near the strip starts the arc at a lower voltage. [Elektroda, Steve Lawson, post #21661015]
What tip materials survive repeated tiny arcs if I try the gap method?
Use hard, high‑melting materials like tungsten carbide or titanium drill bits for the pointed electrode. Expect erosion; design for adjustability or replaceable tips to maintain a consistent gap over time. [Elektroda, Steve Lawson, post #21661016]
Any sourcing tips beyond electronics suppliers?
General hardware outlets carry springs and small metal stock. Ask auto parts stores for specific spring dimensions if needed. Older electronics retailers carried hobby materials, but specialty distributors now offer better part selection online. [Elektroda, Steve Lawson, post #21661012]
What is beryllium copper (BeCu)?
BeCu is a copper alloy with beryllium that combines decent conductivity with strong spring properties. It resists fatigue and keeps contact force over many cycles, making it ideal for clips and brush fingers. [Elektroda, Bob Loy, post #21661006]
What’s a practical takeaway for first‑time builders?
Keep it simple: a 0.5–0.75 inch by ~2 inch 6061‑T6 aluminum or spring‑steel brush against steel plates. Scale later if needed. This balances availability, durability, and reliable conduction for hobby builds. [Elektroda, Andrew LeVino, post #21661005]
