Guitar Amp Crunching Noise at Boston Venue—Grounding or RF Interference Issue?
186 8
  • Shared circuit likely coupling bass amp noise into guitar amps
    #1 21668361
    Nicholas Wiedeman
  • #2 21668362
    David Adams
  • #3 21668363
    Peter Evenhuis
  • Check venue grounding and cable screening
    #4 21668364
    Frank Bushnell
  • #5 21668365
    Rodney Green
  • #6 21668366
    Nicholas Wiedeman
  • #7 21668367
    Nicholas Wiedeman
  • #8 21668368
    Frank Bushnell
  • RF transmitters can radiate through cables and wiring
    #9 21668369
    Robert Speer
A recurring interference issue occurs at a specific Boston venue where bass guitar amplifiers induce a "crunching" noise in guitar amplifiers, despite being plugged into different outlets on the same circuit. The problem manifests with both solid-state and valve guitar amps, and persists even when the guitar is unplugged, indicating the noise is not acoustic feedback. The equipment functions correctly at other locations, suggesting the fault lies within the venue's electrical environment. Key suspected causes include inadequate grounding and potential radio frequency (RF) interference coupling through the power lines. Recommendations include verifying proper earth continuity and grounding of the building's power system, ensuring all equipment chassis have low-resistance grounding connections, using isolation transformers, and checking cable shielding and continuity. The interference may also stem from internal communications systems or external radio transmitters acting as unintended antennas, with power wiring and interconnections radiating RF noise. Testing with oscilloscopes to trace signal coupling on power lines and implementing Faraday shielding on valve amps are advised to mitigate the issue.
