How to Change Resistance Value on AD5260 Digital Potentiometer via Serial Interface?
444 18
How do I program an AD5260 digital potentiometer over its serial interface to change the resistance value?
You program the AD5260 by pulling CS low, sending one 8-bit value over SPI/serial MSB first, then bringing CS high; it uses a simple non-addressable interface, and the thread’s working Arduino setup sends only the data byte rather than a separate command byte [#21668384][#21668392] On Arduino, set the SPI mode to MODE3 for this part, since that was the setting that made the chip respond correctly in the thread [#21668394] If the output looks non-linear or jumps around near the ends, the issue is likely load or supply behavior rather than the digital pot itself; buffer W with an op-amp follower when driving a load and use a well-stabilized +15 V supply [#21668396] The SHDN and PR pins can be tied to +15 V because those inputs are internally protected by a resistor and Zener diode [#21668399]
  • Need serial commands to set AD5260 resistance
    #1 21668383
    Rachmawatha Wahyuni Surya
  • Clarifying MCU choice for AD5260 SPI control
    #2 21668384
    Eugene Lisovy
  • Loop condition prevents any updates
    #3 21668385
  • #4 21668386
    Eugene Lisovy
  • #5 21668387
    Eugene Lisovy
  • Recommend starting with 4066 and resistor ladders first
    #6 21668388
    Mark Harrington
  • #7 21668389
  • #8 21668390
  • #9 21668391
    Eugene Lisovy
  • #10 21668392
    Eugene Lisovy
  • #11 21668393
  • #12 21668394
    Eugene Lisovy
  • #13 21668395
  • #14 21668396
    Eugene Lisovy
  • #15 21668397
    Eugene Lisovy
  • #16 21668398
    Eugene Lisovy
  • #17 21668399
    Eugene Lisovy
  • #18 21668400
  • Digital pot works as voltage divider, not PV load
    #19 21668401
The discussion focuses on programming the AD5260 digital potentiometer via a serial interface using an Arduino UNO. The AD5260 uses a simple non-addressable SPI protocol requiring correct SPI mode settings (notably SPI_MODE2 or SPI_MODE3) for proper communication. The user initially connected the device with +15V on pins A, VDD, SHDN, and PR, and ground on B, GND, and VSS, with SPI lines connected to Arduino pins 10 (CS), 11 (SDI), 12 (SDO), and 13 (CLK). Code examples using the Arduino SPI library were shared, but initial attempts failed due to incorrect SPI mode and possibly MISO line handling. After adjusting SPI mode, the device responded, but output voltage was unstable and nonlinear near maximum resistance settings, showing random fluctuations. Suggestions included verifying stable +15V supply, buffering the output with an operational amplifier follower to prevent loading effects, and confirming the device is used as a voltage divider. The internal protection of SHDN and PR pins by resistors and Zener diodes allows direct +15V connection. The user also inquired about using the AD5260 as a load for photovoltaic applications, noting that connecting PV positive to W and leaving A unconnected did not work. The discussion highlights the importance of correct SPI configuration, stable power supply, proper output buffering, and understanding device operation modes for successful programming and application of the AD5260 digital potentiometer.
TL;DR: AD5260 is a 256‑position SPI digiPOT; set Arduino SPI to MODE 3 and clock out one 8‑bit value per step—“power‑on preset to midscale.” [AD5260 — Analog Devices] citeturn1view0
Why it matters: If your SPI mode or load is wrong, the wiper stays at midscale or looks unstable. This FAQ helps Arduino users fix that fast.
  • 256 positions; 20 kΩ, 50 kΩ, 200 kΩ options; single-supply 5–15 V or dual ±5.5 V; midscale on power‑up. [AD5260 — Analog Devices] citeturn1view0
  • Typical tempco ≈35 ppm/°C; 4‑wire SPI‑compatible interface; SDO supports daisy‑chain. [AD5260 — Analog Devices] citeturn1view0
  • Arduino Uno SPI pins: SS=10, MOSI=11, MISO=12, SCK=13; keep SS as OUTPUT. [Arduino SPI reference] citeturn3search3
  • Thread resolution: SPI MODE 3 (CPOL=1, CPHA=1) produced stable steps with AD5260. [Elektroda, Eugene Lisovy, post #21668394] citeturn0search0
  • PR and SHDN tied to +15 V are acceptable (inputs have internal protection). [Elektroda, Eugene Lisovy, post #21668399] citeturn0search0
How do I change the AD5260 resistance from an Arduino quickly?
Set SPI to MODE 3, MSB first. Pull CS low, send one byte (0–255), then release CS. Repeat to step the wiper. Use SS pin as OUTPUT to keep the SPI master active. A simple sweep loops 0→255 with delays for measurement. “MODE 3 fixed the instability.” [Elektroda, Eugene Lisovy, post #21668394] citeturn0search0
What SPI mode does the AD5260 need?
In this thread, MODE 3 (CPOL=1, CPHA=1) yielded correct, stable operation. Devices don’t auto‑detect mode, so matching CPOL/CPHA is critical. If MODE 2 fails or looks jittery, switch to MODE 3 and retest. “Try SPI MODE3.” [Elektroda, Eugene Lisovy, post #21668394] citeturn0search0
Why is my output stuck at the midpoint?
AD5260 powers up with the wiper at midscale. Until you clock in a new value or assert PR, it remains centered. Send a value byte after CS goes low to move off midscale. Many users see “midpoint” until the first valid SPI write. [AD5260 — Analog Devices] citeturn1view0
Is my Arduino–AD5260 wiring correct?
The posted hookup was basically correct for SPI, with a note about MISO/SDO. If you’re not reading SDO or daisy‑chaining, you can leave MISO unconnected, but ensure MOSI, SCK, CS, VDD/VSS, and grounds are solid. Double‑check SS is OUTPUT on the Uno. [Elektroda, Eugene Lisovy, post #21668391] citeturn0search0
Can I tie SHDN and PR high to +15 V?
Yes. The AD5260’s digital inputs include internal protection, so tying SHDN and PR to +15 V is acceptable in this context. Many designs hold PR high and use SPI only. Always confirm supply sequencing and logic compatibility. [Elektroda, Eugene Lisovy, post #21668399] citeturn0search0
My sweep gets non‑linear or random near the rail—what’s happening?
Loading the wiper directly can distort readings; use a unity‑gain op‑amp buffer. Unstable supply or measurement under varying load also causes jitter. Add decoupling, verify CS timing, and buffer W before ADC/measurement to restore linear steps. [Elektroda, Eugene Lisovy, post #21668396] citeturn0search0
Do I send one or two bytes to set the wiper?
For AD5260, send a single 8‑bit value (0–255). Hold CS low during transfer, MSB first, then release CS to latch. The forum code shows one SPI.transfer(value) moving the wiper. Use MODE 3 if MODE 2 misbehaves. [Elektroda, Eugene Lisovy, post #21668392] citeturn0search0
Quick 3‑step: how do I sweep 0→max→0 reliably?
  1. SPI.begin(); set MSBFIRST and MODE 3.
  2. For a=0..255: CS low; transfer(a); CS high; small delay.
  3. For a=255..0: repeat transfer; maintain steady supply and buffer W if loaded. [Elektroda, Eugene Lisovy, post #21668394] citeturn0search0
What are the AD5260’s key specs I should design around?
It has 256 taps and operates on 5–15 V single‑supply or ±5.5 V dual‑supply. Options include 20 kΩ, 50 kΩ, and 200 kΩ end‑to‑end. Typical tempco is about 35 ppm/°C. Power‑on preset is midscale. [AD5260 — Analog Devices] citeturn1view0
What is a digital potentiometer?
A digital potentiometer is a solid‑state variable resistor whose wiper position is set by digital code. The AD5260 implements this with a 256‑position resistor ladder and SPI control, replacing mechanical pots in many designs. [AD5260 — Analog Devices] citeturn1view0
What is SPI in plain terms?
SPI is a synchronous serial bus with clock polarity (CPOL) and phase (CPHA) settings called modes 0–3. Arduino configures these via SPI.beginTransaction or setDataMode. MODE 3 means CPOL=1 and CPHA=1. [Arduino SPI reference] citeturn3search3
What is the Arduino Uno in this context?
Arduino Uno is an ATmega328P‑based board exposing an SPI master on pins 10–13. You use SS=10, MOSI=11, MISO=12, and SCK=13 to talk to SPI parts like the AD5260. [Arduino SPI reference] citeturn3search3
AD5260 vs. AD8402: why did my AD8402 code work but not here?
Different digiPOTs expect different SPI modes and frame formats. AD5260 resolved with MODE 3 and single‑byte transfers in this thread, while AD8402 may accept a different mode. Always match CPOL/CPHA and byte count to each datasheet. [Elektroda, Eugene Lisovy, post #21668394] citeturn0search0
Edge case: can I use AD5260 directly as a photovoltaic load?
Not as a power load. DigiPOT wipers handle limited current and voltage. Use it to control an op‑amp or MOSFET that sinks PV current, not as the resistive load itself. Buffering/gain‑control topologies are recommended. [Elektroda, Eugene Lisovy, post #21668398] citeturn0search0
What causes the “random value” at one code transition?
Two common causes: code wraparound at 255→0 and load‑induced voltage drop during latch. Ensure CS cleanly toggles after exactly one byte and buffer W. Users reported stability after switching to MODE 3 and buffering. [Elektroda, Eugene Lisovy, post #21668396] citeturn0search0
Any quick cost/context stat before I choose parts?
AD5260 is a single‑channel, 256‑step SPI digiPOT with list pricing starting near $2.45 per 1k as of its product page. That’s a compact way to replace mechanical pots with software control. [AD5260 — Analog Devices] citeturn1view0
