Schematic and Component Values for 0-12V 5A, 5V 1A, 3.3V 1A Power Supply Design
396 8
  • #1 21667687
    manoj Allada
  • LM317 resistor values and 7805 current limits
    #2 21667688
    Rohit Dubla
  • Need input voltage before choosing a switching supply
    #3 21667689
    stephen Van Buskirk
  • LM317 needs proper feedback and minimum load
    #4 21667690
    Steve Lawson
  • #5 21667691
    Steve Lawson
  • LM338 offers 5A protection and 0V output
    #6 21667692
    Steve Lawson
  • #7 21667693
    Rohit Dubla
  • #8 21667694
    Steve Lawson
  • Added disclaimer about the circuit’s pitfalls
    #9 21667695
    Rohit Dubla
The discussion addresses the design of a multi-output power supply providing 0-12V at 5A (variable), 5V at 1A (fixed), and 3.3V at 1A (fixed). Key challenges include achieving a true 0V adjustable output using linear regulators like the LM317 or LM338, which typically have a minimum output voltage around 1.25V due to their internal reference. Techniques from the LM317 datasheet can enable adjustment down to 0V, but require careful circuit modifications. The LM338, a 5A variant of the LM317, offers built-in short circuit and thermal protection, making it suitable for the high current variable output. The fixed 5V and 3.3V outputs are commonly implemented with 7805 and similar regulators, but simultaneous 1A loads on both may risk damage without proper design considerations. The discussion suggests that a switching power supply might be more appropriate for the required currents and efficiency. Several schematic references and design resources are provided, including links to datasheets and example circuits for high current adjustable supplies using LM317/LM338 and pass transistors like TIP3055. The importance of calculating resistor values for voltage adjustment and zener diode biasing is emphasized. Overall, the conversation encourages experimentation and consulting datasheets rather than relying on incomplete or approximate schematics.
