How to Connect Clock Signals Between FPGA, Memory, and LED Display in Simple Processor
279 11
How do I use a clock to synchronize an FPGA, memory, and LED display so the FPGA reads stable data and updates the display correctly?
You do not use the clock to switch the memory or display on and off; you use it to tell registers or flip-flops when to transfer and latch data [#21668654][#21668656] In a simple FPGA-to-memory path, the FPGA puts an address on the bus, the memory data is allowed to settle, and then the FPGA captures that data on a clock edge once it is stable [#21668654][#21668662] If you are only doing a BCD-to-7-segment conversion, you may not need a clock at all unless there is multiplexing or some other sequential step involved [#21668654] The important rule is to clock the system no faster than the slowest part can settle, so you do not present the next value before the current one is valid [#21668662] In other words, the clock coordinates when state changes happen; it does not continuously drive the bus itself [#21668656]
  • Clarifying how to clock FPGA, memory, and display
    #1 21668653
    Shenan Doah
  • Clocked registers hide ripple counter glitches
    #2 21668654
    Steve Lawson
  • #3 21668655
    Shenan Doah
  • #4 21668656
    Steve Lawson
  • Need for clocked synchronization of memory reads
    #5 21668657
    Shenan Doah
  • Recommend starting with microcontrollers before FPGA
    #6 21668658
    Mark Harrington
  • #7 21668659
    Shenan Doah
  • #8 21668660
    Mark Harrington
  • #9 21668661
    Mark Harrington
  • Use the slowest component as the clock limit
    #10 21668662
    Bob Loy
  • Start with finite state machine basics first
    #11 21668663
    Mark Harrington
  • #12 21668664
    Bob Loy
The discussion addresses how clock signals synchronize operations between an FPGA-based simple processor, memory, and an LED display. A clock is essential when data or state transitions must occur at precise intervals, triggering data transfer between stages on clock edges rather than switching buses on and off. In simple BCD to 7-segment converter examples, a clock may not be necessary unless multiplexing is involved. Synchronization ensures that the FPGA reads stable data from memory before processing and updating outputs like LED displays, preventing intermediate or invalid states due to propagation delays. The clock frequency should accommodate the slowest component in the system to allow all devices to settle to their final states. Understanding finite state machines and sequential logic fundamentals, including D-type flip-flops, is crucial for designing synchronized digital circuits. Beginners are advised to first master basic microcontroller concepts, registers, timers, and assembly language before progressing to FPGA design.
TL;DR: In mixed-speed designs, LEDs settle ~1,000,000× slower than FPGA logic; "don’t send out clock pulses any faster than your slowest component." [Elektroda, Bob Loy, post #21668662]
Why it matters: If you clock memory–FPGA–display chains too fast, you read bad data or show garbled digits.
Do I need a clock for a BCD-to-7‑segment converter on an FPGA?
Not for a single, non‑multiplexed digit. That path is purely combinational, so no clock is required. If you multiplex multiple digits, you will need a clocked refresh to scan them. Keep the scan rate within the display’s limits to avoid flicker. [Elektroda, Steve Lawson, post #21668654]
What does the clock actually do in this context?
The clock does not turn buses on or off. It triggers data transfers between stages, such as from a register’s input to its output, on a defined edge. This controlled timing prevents downstream logic from seeing transient states during propagation. [Elektroda, Steve Lawson, post #21668656]
How should I pick a safe clock frequency for FPGA–memory–LED display?
Base it on the slowest element. Logic settles in nanoseconds, while LED displays respond in milliseconds—about one million times slower. As Bob said, “don’t send out clock pulses any faster than your slowest component.” [Elektroda, Bob Loy, post #21668662]
How do I avoid sampling invalid data from memory?
Register boundaries. Drive the address, wait one defined edge for memory to settle, then capture data into a register on the next edge. This hides internal propagation and presents stable data to later stages. [Elektroda, Steve Lawson, post #21668654]
Why do ripple counters cause glitches, and how do I fix them?
Ripple counters update bits sequentially, producing temporary illegal combinations. Downstream logic may misread these. Latch the counter’s value into a parallel register on the opposite clock edge. That exposes only stable, correct outputs. [Elektroda, Steve Lawson, post #21668654]
What is a D‑type flip‑flop, in simple terms?
A D‑flip‑flop is a one‑bit storage element. It copies input D to output Q only on its active clock edge. Between edges, Q holds its value, isolating downstream logic from input transients. [Elektroda, Steve Lawson, post #21668656]
How do I sequence a memory read to a display with an FSM?
Model the controller as states like IDLE, READ_ADDR, LATCH_DATA, and UPDATE_DISPLAY. Each transition occurs on a clock edge, ensuring deterministic timing. This approach organizes hand‑offs between memory, processing, and display refreshing. [Elektroda, Mark Harrington, post #21668658]
Can a design work without any clock at all?
Yes, if everything is purely combinational and outputs can tolerate propagation delay. However, you risk visible glitches during transitions, especially with displays. Adding registers and a clock eliminates those transients at observation points. [Elektroda, Steve Lawson, post #21668654]
What happens if I clock the chain too fast?
You can latch unstable memory data and the display can blur or never reach its intended value. The slowest device dictates the safe update rate, so exceeding it breaks correctness or readability. [Elektroda, Bob Loy, post #21668662]
How do rising vs. falling edges help synchronization?
Use opposite edges to create setup time between producer and consumer. For example, clock a counter on falling edges, then capture its outputs on rising edges so values settle before sampling. [Elektroda, Steve Lawson, post #21668654]
Is an FPGA a good place to start learning digital design?
It’s powerful but steep for beginners. Learning finite state machines and timing basics first reduces frustration and clarifies how to coordinate components. Then, FPGA tools like Vivado or Quartus make more sense. [Elektroda, Mark Harrington, post #21668663]
How do I connect an address bus, data bus, and clock in practice?
Drive address from a register, allow memory to settle, then capture data into a register on a defined clock edge. Feed the display from a register as well, updating it at a safe rate. This register‑to‑register timing prevents glitches. [Elektroda, Steve Lawson, post #21668654]
Can I multiplex a 7‑segment display without artifacts?
Yes. Scan each digit at a fixed rate that the LED can follow. Keep the refresh within the display’s response time to avoid ghosting and dimming while maintaining readable output. [Elektroda, Bob Loy, post #21668662]
Quick 3‑step: How do I read memory and show it on LEDs safely?
  1. On edge N, load and hold the address in a register.
  2. On edge N+1, latch memory data into a register.
  3. At a display‑safe rate, transfer that register to the LED driver. [Elektroda, Steve Lawson, post #21668654]
Why did my LED display flash random segments during testing?
You likely observed transient states while upstream logic settled. Without a registering stage, the display reveals those brief combinations. Insert a clocked register before the display to show only stable values. [Elektroda, Steve Lawson, post #21668654]
