Momentary Switch & Power Loss Trigger With Binary Counter for Vehicle Circuit Design
321 8
  • #1 21669457
    Steve Lawson
  • Microcontroller required; truth table needs redesign
    #2 21669458
    Mark Harrington
  • Suggesting PICAXE, Arduino, or Karnaugh mapping
    #3 21669459
    Steve Lawson
  • Truth table needs clear inputs and outputs
    #4 21669460
    Steve Lawson
  • Hardware-first approach instead of logic tables
    #5 21669461
    Mark Harrington
  • #6 21669462
    Mark Harrington
  • Need edge-triggered latch with pulse counter
    #7 21669456
    Geoff L
  • #8 21669463
    Nick Cholas
  • Requesting a use-case narrative for all switch states
    #9 21669464
    Steve Lawson
The discussion centers on designing a vehicle circuit involving a momentary switch and an additional power source that can trigger an action upon power removal or application. The user requires a binary counter to track the number of momentary switch presses, ensuring the action does not re-trigger improperly when the other source changes state. The circuit must output only momentary signals, not continuous ones, and operate with low power suitable for automotive use. Contributors emphasize the need for a clear truth table or use cases to define input-output relationships precisely. Suggestions include using a microcontroller (uController) such as PICAXE or Arduino for implementation, though discrete logic with Karnaugh map simplification is also proposed. The counter should register switch presses and determine odd/even counts to control output activation. The ignition sense line can serve as a wake-up interrupt for the CPU. The output pin should be configurable for active high or low states. The importance of hardware schematic design and algorithm development before logic table creation is highlighted. Overall, the solution involves integrating a momentary switch input, a power state input, a binary counter register, and an output control pin to manage the triggering logic reliably in a vehicle environment.
