What do you think about a new do it yourself e-paper display kit?
264 10
Can a DIY e-paper display kit support different colours or OLED-style displays, and what are its practical advantages and uses?
The kit is currently monochrome electrophoretic e-paper, with two-colour versions planned, and its main advantage is that you can draw your own segment layout directly on the electrode film, up to 24 segments, while assembling the display’s active layer yourself [#21669732][#21669737] It is a 7-inch display that can be controlled through a computer communication interface or directly by ESD, and it is viewable from both sides [#21669737] It can be used for industrial small-scale applications and alpha-numeric displays, although the marker tip size and drawing accuracy limit how complex the segments can be [#21669738] A dot-matrix version is possible, but it requires a PCB back-plane, which removes flexibility and makes the display only one-sided [#21669738] Compared with plain paper, the e-paper can invert segment colours to create blinking or hiding/emerging effects, with the image on the other side appearing mirrored and inverted [#21669740] E-paper is also noted as useful when low power is important [#21669735]
  • Suggesting OLED, LCD, and educational kit alternatives
    #1 21669731
    Mark Harrington
  • #2 21669730
    Andrus Kurvits
  • Monochrome e-paper kit with custom segment layout
    #3 21669732
    Andrus Kurvits
  • Transparent background would make it a shop window display
    #4 21669733
    Mark Harrington
  • Marker-drawn segment layouts on thin double-sided e-paper
    #5 21669734
    Andrus Kurvits
  • #6 21669735
    DAVID CUTHBERT
  • Questions about interfacing and possible e-paper display uses
    #7 21669736
    Mark Harrington
  • 7-inch e-paper kit with custom 24-segment layout
    #8 21669737
    Andrus Kurvits
  • Dot matrix version would need a PCB backplane
    #9 21669738
    Andrus Kurvits
  • #10 21669739
    DAVID CUTHBERT
  • #11 21669740
    Andrus Kurvits
The discussion centers on a do-it-yourself (DIY) e-paper display kit based on electrophoretic technology, currently monochrome with potential for two-color combinations. The kit allows users to design custom segment layouts (up to 24 segments) by drawing directly on the electrode film, enabling flexible and thin displays viewable from both sides. Unlike OLED or LED technologies, the e-paper kit supports home fabrication and low power consumption, making it suitable for educational and small-scale industrial applications such as shop signage. The display interfaces with external driver circuitry and software to control segment activation, supporting alphanumeric and potentially dot matrix configurations, though the latter requires a rigid PCB backplane and loses double-sided visibility. The e-paper display differs from ordinary paper by enabling color inversion, blinking, and dynamic segment visibility. While OLED on glass offers transparent backgrounds and vibrant color, the e-paper kit emphasizes ease of assembly and customization. Price competitiveness and educational value compared to LED, LCD, and OLED technologies were debated, with e-paper offering unique advantages in power efficiency and user-driven design. Demonstrations of the concept are available via online videos showcasing the segment drawing and display capabilities.
