Why Does Only LED 10 Light Up on My LM3915/LM3916 VU Meter Circuit?
282 8
  • Only LED 10 lights, suggesting wiring error
    #1 21669920
    Travis Moore
  • Check input signal and 0V power reference
    #2 21669921
    Steve Lawson
  • #3 21669922
    William Main
  • Suspect incorrect ±12 V supply wiring
    #4 21669923
    Travis Moore
  • #5 21669924
    Travis Moore
  • #6 21669925
    Travis Moore
  • Add a -12 V supply to IC1 pin 4
    #7 21669926
    Steve Lawson
  • #8 21669927
    Steve Lawson
  • Op-amp supply keeps LED 10 latched on
    #9 21669928
    Travis Moore
A user building a VU meter circuit based on LM3915 and LM3916 ICs encountered an issue where only LED 10 lights up upon powering the circuit. The problem was suspected to be incorrect wiring, particularly regarding the power supply connections. The circuit requires a dual power supply of +12V and -12V along with a common ground, but the user initially connected only +12V and ground, lacking the -12V line. It was emphasized that the -12V supply is essential for proper operation and should be connected directly to pin 4 of IC1 with a decoupling capacitor to ground. Additionally, the grounds of the power supply and signal source must be connected together. The user confirmed having an input signal and a connected ground but used substitute op-amps (JRC4558D, LM741, TL061) instead of the recommended TL072, which may affect behavior. Without +12V to the op-amp, the LEDs scroll through rapidly, but with it connected, only LED 10 remains lit. The user plans to test with TL072 op-amps upon arrival. Troubleshooting steps include verifying power connections with a voltmeter, ensuring proper input signal presence at IC pins, and confirming common ground connections.
