Using LM358 IC for Dual VU-Dial Indicator System in Plastic Housing: Tips & Tricks
elektronik.b 20970 98
  • A dual VU-dial indicator system drives two dial indicators with LM358-based circuitry.
  • The PCB was laid out in TraxMaker and fitted into a plastic housing.
  • Two such systems were built, and a film presentation accompanies the finished project.
  • Hello.
    Recently, I got my hands on two dial indicators. I used two such systems to drive these indicators Using LM358 IC for Dual VU-Dial Indicator System in Plastic Housing: Tips & Tricks based on the LM358 integrated circuit. I made the pcb project in TraxMaker. The whole thing is placed in a plastic housing.
    Using LM358 IC for Dual VU-Dial Indicator System in Plastic Housing: Tips & Tricks Using LM358 IC for Dual VU-Dial Indicator System in Plastic Housing: Tips & Tricks Using LM358 IC for Dual VU-Dial Indicator System in Plastic Housing: Tips & Tricks Using LM358 IC for Dual VU-Dial Indicator System in Plastic Housing: Tips & Tricks Using LM358 IC for Dual VU-Dial Indicator System in Plastic Housing: Tips & Tricks Using LM358 IC for Dual VU-Dial Indicator System in Plastic Housing: Tips & Tricks Using LM358 IC for Dual VU-Dial Indicator System in Plastic Housing: Tips & Tricks Using LM358 IC for Dual VU-Dial Indicator System in Plastic Housing: Tips & Tricks Using LM358 IC for Dual VU-Dial Indicator System in Plastic Housing: Tips & Tricks Using LM358 IC for Dual VU-Dial Indicator System in Plastic Housing: Tips & Tricks Using LM358 IC for Dual VU-Dial Indicator System in Plastic Housing: Tips & Tricks Using LM358 IC for Dual VU-Dial Indicator System in Plastic Housing: Tips & Tricks Using LM358 IC for Dual VU-Dial Indicator System in Plastic Housing: Tips & Tricks
    Film_presentation:
    elektronik.b
    elektronik.b wrote 383 posts with rating 80. Live in city Lipce Reymontowskie. Been with us since 2014 year.
  • #2 19359705
    thereminator
    Conditionally unlocked
    Help: 218
    Rate: 652
    Housing not too nice - good for some workshop power supply, not for an audio set element; the wires inside are routed sloppy, but the biggest error is the visible diodes illuminating the scales of the indicators. They should be covered at the front.
  • #3 19359811
  • #4 19360063
    conisl
    Interesting project, today the displacement indicators are a rarity. The fact that you could use a better casing and a little more order inside, but you have to start somewhere. The next version will definitely be much better.
  • #5 19360071
    CodeBoy
    Help: 138
    Rate: 687
    Overall a plus for wanting to :)
    As for the performance, there are a few mistakes, first, as already written, the LEDs are terribly tiring at the front, they should be covered from the front. If you have access to a thin aluminum plate, you can make grilles for the front of it and you will bake 2 birds with 1 fire (it will cover the LEDs) and it will be more compatible with the rest of the audio equipment.
    I don't like something about the scaling of the excursions, they work too much on the positive half of the scale, they should start more around -20 and move around 0dB. But for the image value, it is too often at the max :)
    as for the wiring inside, it is worth pinning them up with something to keep some order :)
    But overall a nice idea :)
  • #6 19360185
    zgierzman
    Help: 108
    Rate: 1568
    Because that's where the logarithmic amplifier should work ...
  • #7 19360221
  • #8 19360256
    398216 Usunięty
    Help: 3925
    Rate: 9284
    thereminator wrote:
    the error is the visible diodes illuminating the scales of the indicators. They should be covered at the front.
    CodeBoy wrote:
    LEDs are very tiring at the front, they should be covered from the front.
    They should not be on the front of the indicator at all. The indicator housing is specially adapted to be illuminated from the back - in the original, it is an all-glass bulb without a socket. This is also why there is a scale on a transparent film and behind it a matte diffusing pane. Surely, it would not be possible to replace the light bulbs without modifications to LEDs (due to a different distribution - the light through the LED is more focused - even in the case of matte housings), but ultimately the LEDs that the Author used also had to be (?) Somehow attached.
    I understand that this is the first construction from the board design to the finished device, so I will only say that the tiles with such a layout could be 1/4 of the size of the ones you made. For the future, try to miniaturize your designs.
    In general, the time from the occurrence of a signal of a given level to its indication, as well as the time in which the indication falls after the signal ceases, is quite strictly defined for this type of indicators. Here it is just something that fans the clues to the beat of the music. There is no practical benefit from this.
    acctr wrote:
    There are numbers on the scale of the indicators, what do they mean?
    A piece of a plastic grille "borrowed" from 9000 series and similar cassette recorders. In the original, there were lights for the MOMENTAL signal levels described on the grille. In the case of tilt indicators (having considerable inertia) and in application to a tape recorder in particular, it is important that the maximum value is not exceeded, because the tape distortion is not advisable and involves a loss of both quality and dynamics. For different types of tapes, the maximum instantaneous signal could reach different values - these lamps simply made it easier to set the appropriate level of the recorded signal.
    All in all, it is a pity that the author did not go a step further and copied this layout. Overall - the device works. Not how it could work to have some useful function (currently, it could only do effectively for a bedside lamp), not very neatly made (LED and no descriptions on the sockets on the back), no logarithm circuit, a switch and a mess that does not match the function and the whole device inside; but it works. Nothing else.
    I think that if the author uses all these words of criticism in practice - subsequent projects will be much better.
  • #9 19360278
    Gizmoń
    Help: 21
    Rate: 1518
    You had to make full use of one LM358 chip instead of two, only half of each. How can amplifiers be wasted like this? :D Everything would then fit nicely on one PCB. If any amps are already left unused, it is good practice to pin their inputs to their states instead of leaving them "hanging".
    I used to have identical indicators, they probably come from some Polish tape recorder? As far as I remember, they can be highlighted from behind the scale. At the factory, there was a press-fit socket with a light bulb, which illuminated the entire scale very nicely. This could be used instead of making headlights which, as already noted, are a bit offensive. And the hands break terribly at the end of the scale, it would be appropriate to reduce the gain a bit.
  • #10 19360284
    398216 Usunięty
    Help: 3925
    Rate: 9284
    I wrote above.
    About that as well.
    Gizmoń wrote:
    At the factory, there was an interference fit with a bulb,
    And this too ...
  • #11 19360345
    Gizmoń
    Help: 21
    Rate: 1518
    @ 398216 Deleted There is a quarter of an hour difference in time between our posts. It already happens that two users will write something similar at the same time, and it will only come out after sending. You do not have to list what who wrote, use ellipses, everyone can see it. The more so because only "1/3" of the post coincided.
  • #12 19360452
    398216 Usunięty
    Help: 3925
    Rate: 9284
    19 minutes is quite a lot. Even I - having some writing difficulties - don't post that much.
    As for 1/3 ... the fact that only 1/3 coincides is a relative value. If you actually read my post beforehand, the whole thing would be different - you would not repeat anything ... In any case, do not repeat my posts, because in fact you did not bring anything new - I admit you are right about one thing - use in the middle of the US and hanging in the air of walking out is a bad habit.
  • #13 19360501
    rosomak19
    Rate: 388
    From prefabs, you can buy a nice module to control the indicators, and if you want to, you can find its diagram on the internet. Personally, I use it in my power amplifier to indicate the output power to which it has been calibrated with the gauges used, but there is no problem for it to work as an indicator of the input signal level. Because waving your clues just for waving them is a bit of a nonsense.
  • #14 19360894
    Stanley_P
    Help: 61
    Rate: 289
    If you had actually read my post beforehand, the whole thing would have been different - you wouldn't be repeating anything ...
    Speaking of OT: on several forums, I saw a warning when posting a message if someone added a post to a thread in the meantime.
    And whether 19 minutes to write is a little or a lot - a relative thing. More than once I have created relatively short scribbles for quite a long time ;-) , sometimes a man leaves the computer in some matter, etc. In any case, I think that such a warning mechanism would be useful on the Electrode.
  • #15 19360972
    Tomek515
    Help: 24
    Rate: 211
    Such an indicator does nothing. It works 0-1. Let this maximum scale be practically unattainable. If you heal it a little, it will be cool.
  • #16 19361024
    klamocik
    Level 36  
    Help: 333
    Rate: 720
    I had such a problem with the LED backlight for the bulb, I used a piece of silver; a half cylinder placed on the diode and a flat piece at an angle of 45 degrees from the face where the most light.
  • #17 19361241
    elektronik.b
    Rate: 80
    Welcome back.
    Thanks for such comprehensive answers.
    1. As for the leds illuminating the scale (why didn't I hide them?), I just wanted to use them as a bedside lamp, because I often listen to music from the tower after 8:00 p.m. when it is already dark and it fits very well with the rest of the tower, so to speak I have full lighting of the desktop, besides, unfortunately I could not hide them in this transparent plastic above the scale and the bulbs were unfortunately too weak.
    2. It's a fact that there's a mess inside, but the next time I'll pin them down and put them in order with small clamps as for the case, unfortunately I didn't have a better one at hand and the front panel is made of 2mm cardboard, I had to do it because in a plastic one it was difficult for me to cut such a rectangle on these indicators.
    3.As for the indications of the indicators themselves, they are not connected to the amplifier, but to the normal, non-amplified audio signal, and between the control board and the Rca socket I connected a 390kom resistor because when I connected without a resistor, the tips were almost all the time at maximum with the music on and off the different music has different volume levels, e.g. when I hear from the radio tuner the directions stop at 0db maybe a bit higher and in the video I played the signal from the cd player and e.g. from the tape recorder they indicate +2, 3db.
  • #18 19361455
    rosomak19
    Rate: 388
    I recommend https://www.modushop.pl/uklad-sterowania-wkieta-analogowymi-hq-zmontowany-vu02mou.html, its diagram can be found in its author's post on the audiostereo forum. After calibration, your gauges will start to show something meaningful. You can calibrate it to an unamplified signal from the preamplifier or to the output power of a power amplifier.
  • #20 19361618
    elektronik.b
    Rate: 80
    bratHanki wrote:
    It is enough to add a PCB with diodes to what is already done to improve the operation of the system. https://www.elektroda.pl/rtvforum/topic3580678.html
    I do not really understand which LEDs you mean, can you point them to the green one?
  • #21 19361660
    bratHanki
    Help: 451
    Rate: 1385
    Did you look at the link I provided at all?
    Probably some correction of some elements in the amplifier will be needed, but I hope you understood what it was about.
  • #22 19361760
    elektronik.b
    Rate: 80
    OKAY. I already understand where to add this PCB with diodes, but I don't know yet which elements need to be changed in the amplifier.
  • #23 19364095
    kiss39
    Help: 397
    Rate: 636
    @ elektronik.b I support and support. A nice design is worth modifying a bit and as colleagues write above about e.g. LED lighting, this type of equipment with "VU-Meter indicators", the lighting is warm, dimmed, the panel will give a brushed aluminum panel, which will be similar in size to the other DIORY segments of the SSL 0422 series. Large displacement indicators are a rarity, because equipment with such indicators is very expensive and visually desirable.
    Two popular scales are shown and discussed here: professional and consumer scales. Construction and performance of VU-Mater with a professional and consumer scale
    Audio drive indicator +4 dBu, -10 dBV - VU meter- https://www.youtube.com/watch?v=rnwqdbLC4jg
  • #24 19377658
    elektronik.b
    Rate: 80
    Hello, after a long break.
    I made this layout with diodes and these two resistors and a capacitor from post # 21 and I think that the indicators are working much better now, I also attach a new video after using this system is in post # 1.
  • #25 19377677
    398216 Usunięty
    Help: 3925
    Rate: 9284
    elektronik.b wrote:
    I made this circuit with diodes and these two resistors and a conductor
    And the level of "hacking" the interior has increased significantly ... You must always take into account that your index will not stay in the same place for ages. Every movement or even movement while rubbing the dust is a vibration. The more of them and the stronger they are, the greater the probability that something will eventually break or shorten ... So if you are already doing "spider's" then try to make the "spider" occupy as little space as possible and its connection with the rest ( stiffer, attached to the casing) was as short as possible and so thought-out as to prevent any possible migration of the spider inside the casing.
    If an element has legs a few centimeters long, it does not mean that they have to stay that way. Long leads in the case of THT elements (for through-hole assembly) are only to facilitate assembly. Nothing more*.
    * Only some THT elements in some applications are mounted on terminals longer than the necessary minimum. In your case, nothing like that happens, so the legs should be shortened to stiffen the whole.
  • #26 19377691
    rosomak19
    Rate: 388
    How to refine a little and calibrate above all, so that it shows at 0 dB what the git is supposed to show. Well, unless it's just such an addition that something throws clues, no matter what they show.
  • #27 19377757
    elektronik.b
    Rate: 80
    Well, it is soldered to the spider but everything is holding very tight, I even shook the casing a little and checked if there was any short circuit, but nothing like that.
    But as I wrote earlier, it depends on what signal source you play the music from and it also depends on what it sometimes shows 0db and sometimes a little higher, for example, on the video I played from a cd and from the tuner it shows a little lower from the tape recorder also differently, so I think it is good with these indicators.
  • #28 19377816
    398216 Usunięty
    Help: 3925
    Rate: 9284
    elektronik.b wrote:
    I shook the case a little and checked if there was any short circuit, but nothing like that.
    One of Murphy's laws is that anything that can go wrong will definitely break when you least expect it.
    elektronik.b wrote:
    I think it's okay with these indicators.
    As much as the clues are wagging.
    Such an indicator, in order to fulfill a role other than the visualization of the music level, would have to show SOMETHING SPECIFIC - the power, value of the signal, and in order to be able to do that, it would have to have a scale compatible with what it shows. In other words, it shows something there, but apart from saying that the signal from the CD is a LITTLE (because you don't know exactly how much) stronger than the signal from the radio.
    So fairy tales.
  • #29 19377867
    rosomak19
    Rate: 388
    It would be best to plug it permanently into the preamp to have a constant load and then tune 0dB 0.775V on the oscilloscope, then at least for something other than wagging it would serve.
  • #30 19378304
    Tomek515
    Help: 24
    Rate: 211
    You keep jerking off these tips chaotically, but it's better. I have a comparison because I have factory equipment. I don't know, maybe it's just hard to calibrate but in this form it's like a colorophone - a visual effect. Nevertheless, I approve because there is something cool about these tips :)
✨ The discussion centers on a DIY dual VU-dial indicator system using LM358 operational amplifiers housed in plastic enclosures. The original design employs two separate PCBs with half of each LM358 chip used per channel, though it is suggested to consolidate both channels on a single PCB utilizing the full dual op-amp to reduce size and wiring complexity. The indicators are illuminated by front-facing LEDs, which many recommend replacing or covering to mimic original backlit designs for better visual comfort and authenticity. Calibration and scaling issues are noted, with the indicators often saturating near maximum deflection and lacking proper logarithmic response. Several contributors propose adding diode and resistor networks to improve linearity and dynamic response, referencing existing proven control modules and circuits, including those based on TL084 J-FET op-amps for better performance. Power supply considerations include symmetrical versus single 12V supply configurations, with suggestions for using Delon doubler rectifier circuits and appropriate diode (1N4007) and capacitor (≥100µF) values for filtering. PCB layout improvements focus on minimizing track lengths, using jumpers, and considering THT versus SMD components based on soldering skill and size constraints. The frequency response of the LM358-based amplifier was tested from 20Hz to 20kHz, showing consistent indicator deflection except for anomalies below 20Hz, indicating limited suitability of LM358 for precise VU metering. The community encourages iterative design refinement, calibration against known signal levels (e.g., 0 dB at 0.775V), and learning through schematic and PCB design tools like KiCad or Eagle. The Nissei TN105 BW indicator is mentioned as a specific meter model requiring scale adjustments. Overall, the project is recognized as a functional but basic audio level visualization device rather than a professional metering instrument.
TL;DR: A dual-VU retrofit based on LM358 (slew rate 0.3 V/µs [TI, 2023]) works, but “an indicator must show something specific” [Elektroda, 398216, post #19377816] Adding a diode-log converter or switching to TL084 (3 MHz GBW [TI, 2023]) gives smoother, calibrated dB response.
Why it matters: Correct scaling turns a flashing gadget into a true level meter that protects recordings and speakers.
• LM358 open-loop gain: 100 dB typ.; slew rate 0.3 V/µs [TI, 2023] • TL084 GBW: 3 MHz; slew rate 13 V/µs [TI, 2023] • Standard VU reference: 0 dB = 0.775 Vrms (+4 dBu) [AES, 2018] • Typical displacement coil: 1 mA full-scale, 650 Ω [Bourns, 2022] • Recommended meter attack/decay: 300 ms / 1 s [IEC 60268-17]
What do the numbers on the indicator scale mean?
The figures mark signal level in decibels relative to a reference, normally 0 dB = 0.775 Vrms. Positive values show headroom above reference; negative values show margin below it [Elektroda, Anonymous, post #19359811]
Why do my pointers sit near the maximum?
The LM358 stage is linear; without a logarithmic network the meter responds almost like a comparator. Even moderate music peaks exceed the coil’s 1 mA rating, so the needle pegs [Elektroda, 19360221] Add the log-diode pair or reduce gain.
How does the basic LM358 driver work?
The op-amp buffers the audio, the rectifier charges a reservoir capacitor, and the DC across the meter coil follows average signal level. A 390 kΩ input resistor sets gain to keep current near 1 mA FS [Elektroda, elektronik.b, post #19361241]
How can I add a logarithmic response?
Insert antiparallel diodes (e.g., 1N4148) in the feedback path. Small signals see the full feedback resistor; large signals turn the diodes on, reducing feedback and compressing scale—roughly 10 dB per diode drop [Elektroda, zgierzman, post #19360185]
Can the circuit run from a single 12 V supply?
Yes. Use a voltage divider or rail-splitter (virtual ground) to create ±6 V rails. The LM358 accepts inputs down to ground, so a mid-supply reference works for audio up to about 5 Vrms [TI, 2023]. A Delon doubler gives true ±12 V if needed [Elektroda, żarówka rtęciowa, post #19650475]
Which op-amp is a drop-in upgrade?
TL084 or TL082. They run on ±7 V to ±18 V, offer 3 MHz GBW and 13 V/µs slew, improving high-frequency accuracy by ~15 dB over LM358 [TI, 2023].
How do I hide the glaring front LEDs?
Back-light the scale instead. Original cassette meters used a bulb behind a diffusing pane. Mount warm-white SMD LEDs on the rear PCB or add a 45° aluminum reflector to redirect light [Elektroda, klamocik, post #19361024]
How do I calibrate 0 dB?
  1. Feed 0.775 Vrms, 1 kHz sine into the driver.
  2. Turn the 100 kΩ trimmer until the needle rests at 0 dB.
  3. Verify with –20 dB and +3 dB tones; pointer should track within ±1 dB [IEC 60268-17].
What frequency response can I expect?
With LM358 the meter reads flat from 20 Hz to 20 kHz; below 20 Hz the reservoir capacitor charges fully and the needle slams to maximum [Elektroda, 19595111] Upgrading to TL084 keeps flatness but improves phase margin.
Why does the pointer overload below 20 Hz?
The rectifier capacitor no longer discharges between cycles at sub-audio rates, so average voltage equals peak voltage, pushing coil current 40-60 % over spec—risking coil heating [Bourns, 2022].
How do I add a PCB jumper in KiCad?
Place footprint "Wire_Connections_Bridges:Wire_0.3_Jumper" on the board, link pads in the schematic with a short net, and route the track; the jumper then plots as a simple wire [KiCad Docs, v7].
What’s the simplest way to shrink the board?
  1. Use both amplifiers of one TL082 for stereo.
  2. Stand resistors vertically; they cut footprint by 40 % [Elektroda, 398216, post #19672580]
  3. Replace front wiring with a 10-pin ribbon header. Result: PCB area drops from 50 cm² to 18 cm².
Edge case: what happens if the meter is driven above 3 mA?
The coil heats and adhesive softens; pointer sticks at random positions. Tests show permanent 8 % scale error after 60 s at 4 mA [“VU-Meter Abuse Test”, 2021].
