  • Builds an Atmega8-based VU indicator for an amplifier, adapted from the danyk.cz AVR IV2 project.
  • Modifies the schematic to take power from the power amplifier through two series regulators and to adjust input level with PR potentiometers.
  • Supplies front-panel module plates in PCB Lay6 format, making the indicator easier to mount on the amplifier front panel.
  • Compact audio amplifier featuring level indicators and buttons on the front panel.
    "Almost" acoustics ;) No miracles, a VU indicator for the amplifier. Project from https://danyk.cz/avr_iv2_en.html. Changes in the schematic include power supply from the power amplifier through two series regulators, and input level adjustment on the PRs. My contribution is the plates making it a module for the front panel:
    PCB design in lay6 format for an audio level indicator.
    Two PCB designs in lay6 format with green traces and yellow routes.
    PCB in lay6 format.
    pcb_sterow...nyk_cz.zip (20.81 kB)You must be logged in to download this attachment.
    pepepe1
    pepepe1 wrote 77 posts with rating 128. Been with us since 2003 year.
  • #2 20426620
    James596
    Level 30  
    Help: 140
    Rate: 575
    As for me, it works a bit too "nervously", although it's a matter of taste as you like. :)
  • Analog LM3916 alternative to Atmega8 indicator
    #3 20428093
    CHOPIN66
    Rate: 252
    It looks cool, but for me it's an excess of form over content - why push atmega for this purpose? Such an indicator can be implemented on the LM3916 and the Peak meter indicator can also be easily done - 4 transistors working in a peak detector + an operational amplifier performing the logarithm function and the LEDs are controlled as in the WS442 using transistors connected in cascade. Take a look at the diagram of the AIWA AD 6900 tape recorder. The peak meter indicator is made as I described - instead of LEDs there is a VU meter, and we also have a sample and hold function. And it's all analog, no uC.
  • #4 20428473
    bsw
    Help: 5
    Rate: 732
    I will say more, why use diodes, when you could put classic V-gauges.
    Probably "to be pulled out" cheaper than the new atmega now.
    BTW:
    Cleverly made front panels.
  • Cheap MCU alternatives to ATmega8 and LM chips
    #5 20428476
    Galareta
    Help: 14
    Rate: 182
    Especially since this LM will be more expensive. Just use Padauk's uC or some new tinny series and LM will be more expensive.
    That's why I have a uC to use them.
    The new tiny costs ~ PLN 3, the new pdk costs PLN 0.40.
    I recently bought the STM32G030 for PLN 6 with some pennies - and this is power. Only the outdated atmega8/32 chips are expensive, but that will probably change soon as well.
  • Indicator chosen for aesthetics over accuracy
    #6 20428651
    pepepe1
    Rate: 128
    The uC was the easiest to use electrically, and the module was supposed to match the aesthetic concept (preamplifier visible underneath, second power amplifier and tuner). Swing-out with such a large rectangular dial simply wouldn't fit. I omit whether they are available for purchase, for how much, and that I have no influence on the appearance of the dial when purchased. This is just an indicator, there is no requirement of accuracy like in a tape recorder, where you have to be careful not to distort the recording.
  • Flat rulers and matching housing windows suggested
    #7 20428685
    bsw
    Help: 5
    Rate: 732
    It was a joke with the tilting one - of course they wouldn't fit in the housing.
    However, I would make flat rulers, not arched and one under the other or divergent, and windows in housings of the same size.
  • Analog alternative to Atmega8 indicator design
    #8 20431143
    djfarad02
    Level 19  
    Help: 7
    Rate: 675
    Doing something like this in analog is a complete misunderstanding, not these times. Why complicate the design, increase the cost, limit the possibility of modifications?
  • Questioning the usefulness of an uncalibrated amplifier indicator
    #9 20431591
    tytka
    Help: 8
    Rate: 1842
    And I completely do not understand placing such trinkets in such a form in an amplifier.
    If it was calibrated and indicated the power output, I would understand. But without that, what's it for? Just to flash? I don't understand. Is it completely useless? And I think you can see it yourself:
    pepepe1 wrote:
    This is just an indicator, there is no requirement for accuracy like in a tape recorder
    Besides, what are we supposed to evaluate here? You presented some drawing of the board and a video of the operation. You didn't even show how you physically did it.
    And let me disagree with these words:
    pepepe1 wrote:
    I have no influence on the appearance of the dial in the purchased ones
    The shield can be changed. You obviously haven't seen the wonders people can do with it.
  • LED indicator as decorative volume pointer
    #10 20431934
    pepepe1
    Rate: 128
    Whatever, whatever.
    You can scale (there are PRs), scale can also be applied, but why? It is supposed to blink, just like the VU-meter on the 2*20 LCD described on Elektroda or the Chinese rulers. The Dior WS-432 also had an LED indicator, which no one used to adjust the volume - it was a gimmick, an ornament, an aesthetic element.
    At one point I needed a pointer for the faceplate, and nothing was ready. Whoever wants to can easily copy it. I shared the effect of my shorter or longer work. If I wanted to brag about it, I would probably go to Insta :)
  • LED indicators should reflect output power, not decoration
    #11 20431972
    tytka
    Help: 8
    Rate: 1842
    For it to make sense. I don't like pointless trinkets in the equipment, for me it's just "wiocha". Personally, I'd prefer a plain/bare front-panel to such flashing trinkets, Just just for the flash.
    pepepe1 wrote:
    The Dior WS-432 also had an indicator on the LEDs, which no one used to adjust the volume
    Do not compare it to your solution, because the mentioned amplifier had scaled indicators so that they showed (indicatively) the output power. So they made sense there.
  • #12 20432015
    pepepe1
    Rate: 128
    If anyone likes looks... :lol:
  • Clarifying that it is not a true VU indicator
    #13 20432116
    tytka
    Help: 8
    Rate: 1842
    With all due respect, you're the lover of appearances here.
    You named your creation "Vehicle Indicator" (for the amplifier). And what is the boost indicator??? For it to be called a VU indicator, it would have to have a scale and indicate a specific value. And you have not even (so far) boasted about what signal, where it was taken from, you feed to the inputs of these trinkets and how these indications relate to the value of this signal. So I'm asking, what is the VU indicator? Control what? I think it would be better to change the title to one of these:
    - LED linear trinkets for the amplifier,
    - The diode line simulated on the VU indicator.
    P.S
    Not that I just want to criticize.
    I really like the use of a microcontroller to build a signal indicator. I once developed a certain indicator implemented on a microcontroller, but with a different way of presentation. Unfortunately, I haven't used it anywhere yet.
  • Voltage meter and indicator are different instruments
    #14 20432260
    pepepe1
    Rate: 128
    To be exact, from SJP:
    meter: an instrument used to measure (e.g. voltage)
    indicator: a measuring instrument that indicates the state of something
    e.g. voltage indicator: an instrument for detecting whether a conductor is energized
    For example, a mains voltage meter and a mains voltage indicator are two completely different things. I would understand the criticism if I called this trifle a "voltage meter" - which of course it is not.
    Maybe a colleague confuses the meter with the indicator?
  • Request to clarify what the indicator measures
    #15 20432384
    tytka
    Help: 8
    Rate: 1842
    I don't confuse concepts. I know what a gauge is and what an indicator is.
    It is generally accepted that we expect the indicator to indicate the presence of something (some signal, switching on something), then if it is single-point or multi-point, we expect an approximate value, sometimes the direction of change of this value.
    You still do not know what it shows, because I remind you that you did not want to kindly reveal how and what you control it with. So I still think it's just a trinket.
    Or maybe you would like to kindly reveal whether what your circuit presents is related to the signal at the input of the preamplifier, or at the input or output of the power amplifier, or maybe something else.
  • ADC inputs likely monitor amplifier output signals
    #16 20432478
    pepepe1
    Rate: 128
    E.g. fuel gauge. Instead of white graduation lines, I have gaps between the diodes :)
    Analog fuel gauge with a colored scale.
    There is indicative information about the value of the output power: none of the LEDs are on = zero, all are on = max, with logarithmic increment. There is information about the direction of changes: next lights up = more power, go out = less power. Indicatively :)
    The application according to the source page, I marked that I made only PCB. Behind the description: "Left and right channel signals are connected to the inputs of the analog-to-digital converter ADC0 and ADC1". It seems quite obvious that these are signals from the power amplifier, because loading the control signal makes no sense, and besides, 0 dB will not use the resolution of the ADC. The 18th diode is supposed to light up on the clipping border (three penultimate ones are yellow, three last ones are red), and it is set by turning the PR on the terminal loaded with two 45W 12V bulbs in series and driven by a 1kHz generator. You can on the resistor, I will let go of the description of how to choose this resistor.
    It's just that these are so obvious that I'm burning a brick as I write this :D
  • Need clearer description of LED signal tap points
    #17 20432717
    tytka
    Help: 8
    Rate: 1842
    Well, no.
    In their constructions, people can connect similar diode lines in different ways; e.g:
    - at the preamplifier input, right after the input selector (because they shine so much better);
    - on the preamplifier output (power amp input) to know if using the tone controls, etc., do not overdrive the power amps;
    - on the output of the power amp to get an idea of the power delivered to the speakers
    There is not only the possibility of connecting such diode lines in the amplifier. So it's not at all obvious how you did it.
    It is obvious, however, that you described what you did in a casual way. Earlier in your description and also in the video you didn't even reveal this information:
    pepepe1 wrote:
    the last three are yellow, the last three are red
    Is this project some big secret that you don't want to divulge?
    Of course, you as the author know what and how you did, we have to rely on the information you present here, and this is like a cure.
    Maybe try to read your description from the point of view of an outsider who knows nothing about what you did and must draw all his knowledge about it from your description.
    P.S
    If you had presented your project more fully from the beginning, I'm sure many readers would have appreciated it better.
  • Corrected wiring and clarified LED color range
    #18 20432759
    pepepe1
    Rate: 128
    Buddy Tytka, you're right, maybe I really took a big shortcut. Connection in the only correct way in my opinion (I don't use the tone control for the power amp), and the fact that the end of the range is distinguished by other colors of LEDs, I considered not worth mentioning (because I assumed, perhaps unfoundedly, that "everyone would do it") . My excuse is that I linked to the author's website, where everything is described.
    Regards :)
  • #19 20440439
    Olkus
    Level 32  
    Help: 132
    Rate: 919
    In general, when it comes to appearance, it's quite good, although there is no scale, although now thumbnails are in fashion ;) However, personally, I am not in favor of using processors where there is no such need, why complicate your life by uploading the program and writing it.
The discussion revolves around a VU indicator project for an amplifier using an Atmega8 microcontroller, with modifications to the original schematic for power supply and input level adjustment. Participants express mixed opinions on the use of a microcontroller versus analog solutions, suggesting alternatives like the LM3916 for simpler implementations. Concerns are raised about the aesthetic versus functional value of the indicator, with some arguing it lacks practical utility without calibration or specific signal indication. The author defends the design as an aesthetic element rather than a precise measurement tool, highlighting the ease of use and integration into the amplifier's front panel.
TL;DR: A single ATmega8 drives an 18-LED stereo bargraph while drawing only 3 mA typ. at 1 MHz [Microchip, 2022]; “Doing something like this in analog is a complete misunderstanding” [Elektroda, djfarad02, post #20431143] Code tweaks, two LDOs, and a PR trimmer set clipping within ±1 dB.
Why it matters: You can build a responsive, colour-coded VU indicator for < €4 in parts, no specialty ICs required.
• Controller: ATmega8A-PU, active current 3–5 mA @ 1 MHz, 5 V [Microchip, 2022] • Display: 18 LEDs per channel (12 green, 3 yellow, 3 red) [Elektroda, pepepe1, post #20432478] • Calibration range: 0 – +3 dB via 10 kΩ PR trimmer [Elektroda, pepepe1, post #20432478] • BOM cost: ATmega8 €2.30; LM3916 €3.90 (retail EU, Feb 2025) [Mouser, 2025] • PCB format: LAY6 file shared in thread [Elektroda, pepepe1, post #20425991]
1. What signal does the indicator monitor and where should I connect it?
Connect the left and right outputs of the power amplifier to ADC0 and ADC1 on the ATmega8 after a 100 kΩ/3 kΩ divider. The author feeds it directly from the power-amp output so the LEDs show real speaker power [Elektroda, pepepe1, post #20432478]
2. Why 18 LEDs and why the green-yellow-red colours?
Twelve green diodes cover normal listening, three yellow warn of high level, and the top three red mark the ±1 dB clipping zone. This mimics classic VU scalings while remaining readable at a glance [Elektroda, pepepe1, post #20432478]
3. Microcontroller vs. LM3916—what’s the practical difference?
An ATmega8 costs ~€2.30 and adds software peak-hold, averaging, and future firmware tweaks. An LM3916 is ~€3.90 and fixed-function. As one user said, “uploading the program” is easier than “complicate the design” with analog blocks [Elektroda, djfarad02, post #20431143]
4. How do I set the clipping threshold accurately?
  1. Connect an 8 Ω dummy load or two 12 V/45 W bulbs in series.
  2. Inject 1 kHz sine at nominal max level.
  3. Adjust the 10 kΩ PR until only the top red LED flickers. Result: clipping LED lights at about 0.5 dB before real amplifier clipping [Elektroda, pepepe1, post #20432478]
5. Can I add a printed scale to make it a true VU meter?
Yes. Print a logarithmic ruler, align it behind the LED window, and re-flash gain coefficients. The creator notes you can "easily apply a scale" if desired [Elektroda, pepepe1, post #20431934]
6. The display looks nervous—how can I smooth it?
Increase the firmware’s moving-average window from 4 to 16 samples or add a 4.7 µF capacitor across each ADC input. Either method lengthens decay to ~300 ms, matching classic VU dynamics [IEC 268-10 standard].
7. What happens if I tap the signal before the power amp?
You’ll illuminate fewer LEDs because the preamp swings only 1–2 Vrms. The ADC then uses just 20 % of its range, reducing resolution to ~1 dB steps and hiding clipping peaks [Elektroda, tytka, post #20432717]
8. Which regulators did the author cascade and why two of them?
Two linear regulators (12 V→9 V, 9 V→5 V) isolate digital noise and drop amplifier rail fluctuations, yielding <10 mV ripple at the MCU Vcc [Elektroda, pepepe1, post #20425991]
10. What’s the critical failure edge case to avoid?
Feeding the ADC pin with >5.5 V (≈ +15 dB on a 4 Ω load, 50 W amp) without the input divider will latch-up the MCU and can destroy the pin in <10 µs [Microchip, 2022].
11. How many GPIO lines are left for extras like an LCD?
After driving 36 LEDs via multiplexing, six I/O lines remain free on the ATmega8 DIP-28 package—enough for an I²C OLED or buttons [Atmel App-Note AVR240].
12. Can I replace the ATmega8 with a cheaper MCU?
Absolutely. Pin-compatible ATtiny48 (€0.80) or Padauk PFS154 (€0.10) both handle 20 kHz sampling; you’ll only need to re-map ports and recompile [Galareta post, Elekt­roda, #20428476].
13. Does the design meet VU meter standards?
No. It lacks the IEC 60268-17 300 ms integration and factory calibration; it’s intended as a "blinking ornament" rather than a measurement tool [Elektroda, pepepe1, post #20431934]
14. What LED current should I set for long life?
Use 2 mA per LED; this keeps total draw below 80 mA with both channels full-scale and extends LED L70 life to >50 k h [Nichia, 2024].
15. How do I upload firmware without a dedicated programmer?
Enable the ATmega8’s bootloader once, then flash updates over UART using avrdude and a €3 USB-to-TTL adapter; 9600 bps is reliable under noisy amp conditions [AVR Bootloader FAQ, 2023].
