Designing a Tunable High Voltage Oscillator for Pulsing 5 Electromagnets 1-20Hz
300 15
How can I design a tunable 1–20 Hz pulsing circuit to drive five electromagnets from a high-voltage supply, and what information do I need to size the parts?
You need the electromagnets’ current and voltage ratings first, because the circuit should be sized from coil current rather than voltage alone; the advice was to use a transistor/MOSFET switch driven by a pulse source such as a 555, and to choose a MOSFET with Vds at least 1.5× the maximum coil voltage, preferably 2× [#21663907][#21663915][#21663917][#21663918] If the gate-drive device is a logic-level FET, 5 V is enough; otherwise about 10–12 V is needed, and for roughly 300 V and above an IGBT was suggested instead [#21663908] Put a protection/flyback diode across the inductors in the opposite polarity so it conducts when the FET turns off and suppresses reverse EMF [#21663918][#21663919] A series resistor is optional and can be 0 Ω; it mainly exists to limit coil current [#21663921] The 12×9 V battery idea only works if it can supply the required current; one example given was 5×120 V, 0.5 A magnets needing about 2.5 A, while a 12×9 V stack was estimated at only about 0.4 A, so the batteries may be far too weak [#21663907]
  • Need load current and coil resistance first
    #1 21663906
    Aaron Hiniker
  • Need magnet voltage and current ratings
    #2 21663907
    Peter Evenhuis
  • MOSFET or IGBT switching for high-voltage coils
    #3 21663908
    Steve Lawson
  • #4 21663909
    Steve Lawson
  • Clarifying electromagnet current and FET basics
    #5 21663910
    Aaron Hiniker
  • #6 21663911
    Aaron Hiniker
  • #7 21663912
    Steve Lawson
  • #8 21663913
    Aaron Hiniker
  • Suggest starting with basics before designing the circuit
    #9 21663914
    Steve Lawson
  • Current-limited transistor drive for coil pulsing
    #10 21663915
    Steve Lawson
  • #11 21663916
    Aaron Hiniker
  • Clarifying the oscillator diagram and safety warning
    #12 21663917
    Steve Lawson
  • FET voltage margin and flyback rectifier advice
    #13 21663918
    Steve Lawson
  • #14 21663919
    Steve Lawson
  • #15 21663920
    Aaron Hiniker
  • #16 21663921
    Steve Lawson
The discussion centers on designing a tunable high voltage oscillator circuit to pulse five electromagnets in series at frequencies between 1-20 Hz. The original poster has limited electronics experience and seeks guidance on circuit design, power requirements, and component selection. Key advice includes determining the electromagnets' voltage and current ratings to match the power source, as mismatched voltage or current can damage coils. Using multiple 9V batteries in series to achieve high voltage is generally insufficient for high current demands. Safety warnings emphasize the dangers of voltages above 24V, with lethal risks above 80V. For switching, MOSFETs are recommended due to their ability to handle higher voltages and currents, with logic-level MOSFETs requiring 5V gate drive and others needing 10-12V. For voltages above 300V, IGBTs are suggested. The importance of selecting a MOSFET with a drain-source voltage rating at least 1.5 to 2 times the maximum applied voltage is stressed. A protection diode (flyback diode) across the electromagnets is advised to suppress voltage spikes caused by inductive load switching. The discussion also touches on the role of resistors to limit current, though often zero ohms (a wire) is used. The original poster is encouraged to build foundational electronics knowledge before attempting complex high voltage designs. Example circuit diagrams involving a 555 timer controlling a MOSFET switch with an LED indicator and protective diode were shared. The focus is on current control rather than voltage, as electromagnet performance depends primarily on current. Overall, the conversation highlights the need for careful component selection, safety precautions, and incremental learning in high voltage pulsed electromagnet applications.
TL;DR: For pulsing five electromagnets at 1–20 Hz, size for current, protect against inductive kick, and respect lethal voltages—“DC above 80 V can kill,” and “Be safe and double check always.” [Elektroda, Peter Evenhuis, post #21663907]
Why it matters: This FAQ helps hobbyists safely choose switches, voltages, and protection parts when building a tunable high‑voltage EM pulser.
What information do I need before designing a 1–20 Hz electromagnet pulser?
List each coil’s resistance, inductance, and rated current. Decide series or sequence operation. Pick supply voltage that achieves target current. Choose a switch device with sufficient Vdss and current. Plan for a flyback diode and a pulse source (e.g., 555) feeding a driver. Safety rules apply above 24 V and become lethal above 80 V. [Elektroda, Peter Evenhuis, post #21663907]
Why do experts say “it’s all about the current” for coils?
Magnet strength depends on ampere‑turns, so current through the winding dominates. Voltage is only the means to push that current through coil resistance and inductance. “If it’s inductors you are driving, then it’s all about the current.” Size your supply and switch around current first. [Elektroda, Steve Lawson, post #21663918]
How do I pick the right MOSFET voltage rating (Vdss)?
Choose a MOSFET with Vdss at least 1.5× your maximum coil voltage; 2× offers more margin. Inductive transients can exceed supply voltage during switch‑off. This headroom helps avoid avalanche and device failure. Pair it with a flyback diode to limit spikes. [Elektroda, Steve Lawson, post #21663918]
Do I need a flyback diode across the electromagnets?
Yes. Place a rectifier diode across each coil, reverse‑biased to supply. It stays off when the MOSFET is on, then conducts on turn‑off to absorb reverse EMF. Without it, voltage spikes can punch through the MOSFET. [Elektroda, Steve Lawson, post #21663919]
Can I drive a MOSFET gate directly from a 555 timer?
Yes, if you use a logic‑level MOSFET that fully turns on at 5 V. Non‑logic MOSFETs may need about 10–12 V gate drive. Keep gate leads short, and include a small series resistor if ringing appears. [Elektroda, Steve Lawson, post #21663908]
Are stacked 9 V batteries good for powerful electromagnets?
No. A dozen 9 V cells give about 108 V but only around 0.4 A. That low current starves the coils, delivering weak magnetization despite the high voltage. High‑current supplies are a better match for strong EM pulses. [Elektroda, Peter Evenhuis, post #21663907]
Is rectifying 120 V AC for this project a good idea?
Not for beginners. Mains‑derived DC is lethal and unforgiving. The forum cautions that DC above 24 V can burn and above 80 V can kill. Use isolated, current‑capable low‑voltage supplies and proper training before attempting mains work. [Elektroda, Peter Evenhuis, post #21663907]
What is a MOSFET, and why use it here?
A MOSFET is a transistor that acts as an efficient electronic switch. It handles coil current with low loss and is easy to drive from logic if it’s a logic‑level type. Choose adequate Vdss and current ratings, then add a flyback diode. [Elektroda, Steve Lawson, post #21663908]
When should I consider an IGBT instead of a MOSFET?
Use an IGBT when coil voltages approach a few hundred volts and you still need pulsed current. The thread suggests IGBTs for 300 V‑class applications, with strict safety discipline. Ensure proper isolation and protection networks. [Elektroda, Steve Lawson, post #21663908]
How do I estimate coil current from resistance?
Measure DC resistance (R). For steady current, I ≈ V/R once inductive transients settle. Ensure the supply can deliver that current continuously. Size wiring, switch, and diode for at least that current. [Elektroda, Aaron Hiniker, post #21663910]
How should I wire five electromagnets that must pulse together?
Place the coils in series if they must share the same current. Drive the series string with one MOSFET low‑side switch. Add one flyback diode across the entire string, observing polarity. Verify the MOSFET’s Vdss margin. [Elektroda, Steve Lawson, post #21663917]
What’s a logic‑level MOSFET gate requirement in plain terms?
Logic‑level MOSFETs reach low Rds(on) with a 5 V gate. Standard MOSFETs often need about 10–12 V to turn fully on. Match your driver to the device type to avoid heating and voltage drop. [Elektroda, Steve Lawson, post #21663908]
Can I limit coil current with a series resistor?
Yes, but it wastes power. The thread shows an optional series resistor to cap current when coil specs are unclear. Prefer setting current via supply voltage and proper coil design when possible. [Elektroda, Steve Lawson, post #21663921]
How do I add a safe switching stage to a 555 pulser?
Use the 555 to generate 1–20 Hz, then drive a MOSFET gate. Choose Vdss ≥1.5× supply and add a flyback diode across the coil. Keep control ground and power ground common and short. [Elektroda, Steve Lawson, post #21663918]
What’s a quick three‑step to protect my switch from coil kick?
  1. Wire a diode across the coil, cathode to supply, anode to the switch side.
  2. Size diode current to at least the coil current.
  3. Verify MOSFET Vdss margin and layout short leads. [Elektroda, Steve Lawson, post #21663919]
Any final safety guidance for high voltage coil drivers?
Work one‑handed around energized circuits, verify isolation, and double‑check wiring. Respect thresholds: above 24 V causes burns; above 80 V can be fatal. “Be safe and double check always.” [Elektroda, Peter Evenhuis, post #21663907]
