SPICE Model for NGTB40N120FLWG IGBT or Equivalent for LTSpice Tesla Coil Simulation
474 29
How can I simulate an NGTB40N120FLWG IGBT in LTSpice, or what equivalent should I use, and how do I estimate the current in a Tesla-coil driver with several IGBTs in series?
You can simulate it well enough in LTSpice with a voltage-controlled switch, or use an STW11NM80 MOSFET model as a rough substitute; seven of those FETs have about the ON resistance and gate charge of one of your IGBTs [#21670030] If you model the switch, add about 420 pF across it to represent the IGBT capacitance, using 180 pF reverse transfer plus 240 pF output capacitance [#21670036] Avoid stacking IGBTs if possible, because the top device needs a fast, high-current isolated gate drive; a small transformer secondary with back-to-back 10 V zeners is the suggested way to drive the gate quickly on and off [#21670036] The collector current is set by the primary LC and any series resistance, not by the 12 V gate pulse alone; with an inductor it follows V = L(di/dt), and without a limiting resistor capacitor charging current is only limited by turn-on time or saturation, so a flyback clamp or series resistor is safer for the IGBT [#21670044][#21670039] For a 600 V, 40 A condition the device turns on in about 50 ns and turns off over 140–400 ns with tail current, and switching loss is 5.8 mJ per event, so at 1 kHz that is about 5.8 W switching loss before conduction loss [#21670034]
  • Need for NGTB40N120FLWG SPICE model and current estimate
    #1 21670027
    Cody Gass
  • Use a voltage-controlled switch to model the IGBT
    #2 21670028
    DAVID CUTHBERT
  • IGBT paralleling guidance and current concern
    #3 21670029
    Cody Gass
  • LTspice switch model or STW11NM80 FET equivalent
    #4 21670030
    DAVID CUTHBERT
  • Generating complementary 555 output for H-bridge control
    #5 21670031
    Cody Gass
  • #7 21670033
    Cody Gass
  • IGBT switching loss and dv/dt estimates at 600 V
    #8 21670034
    DAVID CUTHBERT
  • Need gate capacitance conversion for voltage-controlled switch
    #9 21670035
    Cody Gass
  • Gate-drive transformer and zener method for IGBT switching
    #10 21670036
    DAVID CUTHBERT
  • #11 21670037
    DAVID CUTHBERT
  • #12 21670038
    Cody Gass
  • Blocking diode needed to protect IGBT from reverse voltage
    #13 21670039
    DAVID CUTHBERT
  • #14 21670040
    DAVID CUTHBERT
  • #15 21670041
    Cody Gass
  • Approximate IGBT SPICE emulation with 14 A pulse behavior
    #16 21670042
    Cody Gass
  • #17 21670043
    Cody Gass
  • Flyback clamp sizing for IGBT protection
    #18 21670044
    DAVID CUTHBERT
  • Questioning diode placement and resistor cooling margin
    #19 21670045
    Cody Gass
  • Use ultra-fast diodes and current-mode modulation
    #20 21670046
    DAVID CUTHBERT
  • Clamp capacitor and diode sizing questions
    #21 21670047
    Cody Gass
  • MUR460 simulation gives only 27 kV topload peak
    #22 21670048
    Cody Gass
  • MUR460 diode current and IGBT dissipation estimate
    #23 21670049
    Cody Gass
  • Reduce HV and tune the clamp resistor
    #24 21670050
    DAVID CUTHBERT
  • #25 21670051
    DAVID CUTHBERT
  • Adjusting clamp resistor by measuring IGBT collector voltage peak
    #26 21670052
    Cody Gass
  • #27 21670053
    Cody Gass
  • Monitor clamp voltage and keep MUR460 under 2 watts
    #28 21670054
    DAVID CUTHBERT
  • Series-parallel resistor network for IGBT thermal sharing
    #29 21670055
    Cody Gass
  • #30 21670056
    DAVID CUTHBERT
The discussion centers on obtaining or approximating a SPICE model for the NGTB40N120FLWG IGBT to simulate a solid state Tesla coil in LTSpice. Due to the lack of an official SPICE model, alternatives such as using a voltage-controlled switch or substituting with a similar MOSFET model (e.g., STW11NM80) are suggested. Key simulation considerations include modeling the IGBT's switching characteristics, tail current, forward voltage drop, and thermal impedance. The IGBT gate drive requires sufficient current for fast switching, and transformer-isolated gate drives are recommended for stacked devices, though stacking IGBTs is complex and not beginner-friendly. Paralleling IGBTs and gate resistor configurations are discussed based on application notes from On Semiconductor. The circuit topology involves a flyback converter style with blocking diodes to handle voltage swings and protect the IGBT from reverse voltage and avalanche conditions. Diode selection is critical; ultra-fast diodes like MUR460 are preferred over slow 1N4007s due to reverse recovery and forward recovery times. Clamping circuits with diodes, resistors, and capacitors protect the IGBT, with component values influencing voltage peaks and power dissipation. Thermal management and power dissipation calculations are emphasized, including switching and conduction losses at specified voltages and currents. The simulation also accounts for parasitic capacitances by modeling them as capacitors across the voltage-controlled switch. Practical advice includes gradually increasing voltage during testing, monitoring collector voltage, and adjusting clamp resistor values to prevent device damage. The user is advised on resistor and diode arrangements for current sharing and thermal stability. The discussion also touches on the user's educational background and aspirations in power electronics and analog design.
TL;DR: Need an LTspice IGBT model for a Tesla coil? Use a voltage‑controlled switch with ≈420 pF output capacitance; dv/dt at turn‑off can average ~4300 V/µs. “IGBTs are forgiving of high current.” [Elektroda, DAVID CUTHBERT, post #21670036]
Why it matters: This FAQ helps hobbyists and students simulate, size, and protect IGBTs when a vendor SPICE model isn’t available.
How do I simulate the NGTB40N120FLWG in LTspice without a vendor model?
Use a voltage‑controlled switch as the IGBT and place ~420 pF across it to emulate output plus reverse‑transfer capacitance. This lets you explore primary energy transfer, clamp behavior, and dv/dt. It is not identical to an IGBT, but it’s good enough to validate topology, stresses, and timing before hardware. Start conservative on voltages and duty cycle, then iterate. “The switch is not quite the same as an IGBT but it gives you a way to experiment.” [Elektroda, DAVID CUTHBERT, post #21670036]
What limits should I expect for IGBT switching in a Tesla‑coil driver?
Expect fast turn‑on (~50 ns), but turn‑off includes a tail current about 10% of peak, extending for a few hundred ns. These behaviors raise switching loss and affect primary ring‑down. Plan your frequency and duty cycle with this in mind, and ensure strong gate drive for clean transitions. High forward drop and die thermal impedance further limit continuous current. [Elektroda, DAVID CUTHBERT, post #21670028]
What dv/dt and switching loss numbers should I design around?
A referenced data point is ~4300 V/µs average dv/dt at turn‑off with 600 V and 40 A. Total switching loss about 5.8 mJ per event under those conditions. At 1 kHz this alone is ~5.8 W; add conduction loss Vce(sat) × I × duty. Example: 3.5 V × 40 A × 10% ≈ 14 W, totaling ~20 W. [Elektroda, DAVID CUTHBERT, post #21670034]
Can I stack IGBTs in series for higher voltage?
It’s possible but not beginner‑friendly. Stacked devices need isolated, high‑current gate drives for fast OFF transitions and reliable dynamic voltage sharing. Passive RC sharing helps only at low speed. A flyback topology with a proper clamp is a simpler, safer start than series stacks. [Elektroda, DAVID CUTHBERT, post #21670036]
How should I drive the IGBT gate—can a 555 or op‑amp work?
You need a low‑impedance gate driver that can source and sink high peak current to charge and discharge gate charge quickly. A simple 555 or op‑amp output is insufficient without a push‑pull buffer or a dedicated driver IC. “Driving an IGBT fast takes much less gate drive than a MOSFET,” but you still need current. [Elektroda, DAVID CUTHBERT, post #21670028]
What is dv/dt, and why does it matter here?
dv/dt is the rate of voltage change. High dv/dt at IGBT turn‑off stresses clamps, diodes, and insulation, and can couple into controls. At 600 V and 40 A, an average ~4300 V/µs was cited, so layout, diode speed, and snubbing are critical to avoid overshoot or avalanche. [Elektroda, DAVID CUTHBERT, post #21670034]
How do I size a flyback clamp for the primary?
Use a fast diode stack to a clamp capacitor and bleed resistor. Choose C so that dumping the primary’s energy raises its voltage by ~10% per event. Example: 20 A in 100 µH stores 20 mJ; 1 µF would rise about 200 V. Select R to hold the desired DC bias (e.g., ~800 V). [Elektroda, DAVID CUTHBERT, post #21670044]
Which diodes should I use for the clamp and series blocking?
Avoid 1N4007. It has slow reverse recovery and even slow forward recovery (~1 µs), causing reverse conduction and losses. Use ultra‑fast diodes like MUR‑class parts for both the clamp and series blocking paths. Parallel identical diodes can share without ballast if kept cool. [Elektroda, DAVID CUTHBERT, post #21670054]
Do I need a series blocking diode with the IGBT?
Yes, in a flyback‑style primary drive. After turn‑off, the IGBT node flies above the supply and then below ground. A series blocking diode prevents reverse voltage across the IGBT, while the clamp stops overvoltage. Push‑pull drivers self‑clamp but need floating high‑side drive. [Elektroda, DAVID CUTHBERT, post #21670046]
How do I account for primary LC current during gating?
Use V = L di/dt to estimate ramp during ON time. With a parallel tank capacitor, initial charging current can be very high unless limited by series resistance or finite turn‑on speed. Add a series resistor to move heat out of the IGBT during charge. [Elektroda, DAVID CUTHBERT, post #21670044]
What’s a simple way to start up and tune the clamp safely?
Three‑step bring‑up: 1) Start with reduced HV and monitor the clamp node with a DVM. 2) Adjust the bleed resistor to reach target clamp voltage while observing collector waveform. 3) Run briefly, then thermal‑check components and iterate. [Elektroda, DAVID CUTHBERT, post #21670054]
Can large electrolytics work as the clamp capacitor?
Yes, but beware voltage rating and total energy. Using larger C reduces voltage rise per pulse, but increases stored energy and fault stress. Series electrolytics need balance and clearance. Microwave oven capacitors can work if their ESR and voltage ratings fit your pulse duty. [Elektroda, Cody Gass, post #21670053]
How hot is too hot for parts in a hobby Tesla coil?
For non‑product builds, pushing parts is acceptable with caution. Running semiconductor junctions near 150 °C, resistors at rated power, and capacitors with minimal derating can be acceptable if you monitor temperature and provide airflow. This is an experimental tradeoff. [Elektroda, DAVID CUTHBERT, post #21670051]
Why did my LTspice show diodes conducting negative current?
Slow diodes exhibit reverse recovery; they conduct briefly in reverse when switching, which appears as negative current in simulation. This can overheat parts and distort waveforms. Replace with ultra‑fast diodes to reduce reverse recovery charge and ringing. [Elektroda, DAVID CUTHBERT, post #21670046]
What’s a practical audio/modulation approach for musical coils?
Modulate primary current rather than trying to linearize voltage. Sense current with a small shunt and use it in a control loop, or convert audio amplitude to pulse width so higher amplitude yields longer ON time. This avoids complex loop stability issues. [Elektroda, DAVID CUTHBERT, post #21670046]
What is a flyback vs. push‑pull primary drive in this context?
Flyback charges primary current then transfers energy on turn‑off; it needs a clamp and blocking diode but a simpler supply. Push‑pull alternates two switches, is self‑clamping, but needs higher supply voltage and a floating high‑side driver. Choose based on skills and parts. [Elektroda, DAVID CUTHBERT, post #21670046]
