Is Back EMF From Heating Pad Damaging 5V 1A Linear Power Supply? Diode Protection?
288 6
  • Back-emf unlikely; add flyback diode and check supply overload
    #1 21670457
    Ethan Hathaway
  • #2 21670458
    Gary Crowell
  • #3 21670459
    Ethan Hathaway
  • #4 21670460
    Gary Crowell
  • Flyback diode recommended to protect FET
    #6 21670462
    Gary Crowell
  • #7 21670463
    Ethan Hathaway
A 10W 5V heating pad powered by a 5V 1A linear power supply through a TO-220 MOSFET controlled by a PID occasionally causes the power supply to fail. The heating pad draws approximately 2A, exceeding the 1A rating of the power supply, which likely causes the shutdown. The concern about back EMF damaging the power supply is unlikely since the heating pad is a resistive load with minimal inductance; back EMF typically arises from inductive loads and would more likely damage the MOSFET rather than the power supply. Adding a flyback diode such as a 1N4001 diode reverse biased on the MOSFET output is recommended as protection for the MOSFET but will not address the current overload issue. A power supply capable of delivering at least 2A, preferably 3-4A for margin, is advised. A simple wall wart switch-mode power supply is suggested as a suitable replacement.
