change on / off switch – modulate peed of on off by using?
360 8
  • Asking for adjustable on-off cycling control
    #1 21685445
    Daves123
  • Suggesting 555 timer or microcontroller control
    #2 21685446
    Richard Gabric
  • #3 21685447
    Aiflondon
  • #4 21685448
    Kevin Kendal
  • 555 timer or microcontroller for pulse switching
    #5 21685449
    Chris Baron
  • Opto mos relays offer fast switching speeds
    #6 21685450
    Richard Gabric
  • #7 21685451
    Daves123
  • #8 21685452
    crossvid
  • Continuous 28–49 VAC load with linear control
    #9 21685453
    Daves123
The discussion addresses replacing a manual on/off switch with a variable frequency control to modulate the on/off timing from fractions of a second up to one second. The load involves driving 28-49 VAC at 3 to 5 W/m² to polarize glass, powered by two batteries. A linear control potentiometer is preferred, with continuous operation. For such rapid switching, electromechanical relays are generally unsuitable due to slow response times. Instead, electronic switching elements like MOSFETs or IGBTs controlled by a 555 timer circuit or a microcontroller (e.g., Arduino) are recommended. The 555 timer offers an analog solution with adjustable RC timing, while microcontrollers provide versatile digital control via ADC inputs. Opto MOS relays can achieve switching speeds in the millisecond range but have limited power handling. Industrial PLC modules are an alternative for robust, commercial-grade solutions but at higher cost. Duty cycle considerations (e.g., 50:50 square wave) and load characteristics influence the choice of switching method and circuit design.
