Charging 18650 Lithium Ion Cell With 12.66V Solar Panel & BMS Board—Charge Time?
252 9
How long does it take to charge a single 18650 Li-ion cell, and how can I tell when it is fully charged when using a solar panel and BMS board?
A single 18650 Li-ion cell is considered fully charged at 4.2 V, not 4.0 V, and Li-ion charging should follow CC-CV: constant current until 4.2 V, then stop/hold at that limit [#21681675] The charge time depends on the charge current and battery capacity; one reply says the standard charge current is 1.25 A, which can take about 3 hours max, while up to 4 A can charge in less than 1 hour, though lower current is better for battery life [#21681675] The HX-3S-25A board appears to be made for 3-cell packs, so it may not be the right board for a single 18650, and a board designed for one Li-ion cell is recommended [#21681678] For a single-cell charger, 5 V is sufficient, and a 6 V solar panel is suggested with a charger board that accepts up to 6 V input; 12 V is not the right input for the one-cell charger discussed [#21681680] To check whether it is fully charged, measure the cell directly: it should rise toward 4.2 V, and if it goes higher than 4.2 V the charging setup is wrong [#21681678]
  • 18650 cells are full at 4.2 volts
    #1 21681674
    david lopez
  • Wrong BMS board may overcharge 18650 cell
    #2 21681675
    David Ashton
  • #3 21681676
    david lopez
  • #4 21681677
    Elina Gomez
  • BMS board is for 3-cell packs, not one cell
    #5 21681678
    David Ashton
  • #6 21681679
    david lopez
  • Recommend a 6V solar charger board for 18650 cells
    #7 21681680
    David Ashton
  • #8 21681681
    david lopez
  • #9 21681682
    David Ashton
  • Solar charging requires proper lithium cell voltage control
    #10 21681683
    Roy F Alvord
The discussion addresses charging a single 18650 lithium-ion cell using a 12.66V solar panel connected through a Battery Management System (BMS) board. The BMS board in question, identified as the HX-3S-25A, is designed for managing and charging three 18650 cells in series, not a single cell, which may affect charging efficiency and safety. The correct full charge voltage for a single 18650 cell is approximately 4.2V, not 12.66V, as the latter corresponds to the combined voltage of multiple cells in series. Charging follows a CC-CV (Constant Current - Constant Voltage) method, with a typical charge current around 1.25A, allowing a full charge in about 3 hours at standard rates. Using a solar panel voltage higher than the battery voltage requires a suitable regulator or a BMS designed for single-cell charging to prevent overvoltage and overheating. For single-cell charging, specialized boards such as those from Adafruit, which accept 5V USB or up to 6V input, are recommended. Voltage readings below 3.7V indicate partial discharge, and a fully discharged cell should still show some voltage above zero. Proper charging and discharging limits are critical to avoid battery damage or fire hazards. Solar charging setups require appropriate voltage regulation and BMS selection tailored to the battery configuration.
