Why Use 30M Ohm Resistors in Optical Slave Trigger Circuits?
192 14
Why would an optical slave trigger circuit use two 30 MΩ resistors in series, and what role do they play?
Those resistors are probably part of the photodiode/SCR trigger network, where a very high resistance is used to bias the sensor and help control sensitivity or ambient-light filtering rather than to carry significant current [#21670871] In similar trigger circuits, high resistance is also used so voltage can build until the trigger element closes and fires the main discharge path [#21670864] However, one reply warns that the resistor bands may be misread because band colors on molded resistors can be deceptive, so the first step is to verify the actual value if possible [#21670870]
  • Possible misread of M notation or high-value transimpedance use
    #1 21670863
    Mark Nelson
  • High resistance forces capacitor voltage buildup
    #2 21670864
    Chuck Sydlo
  • High-value resistors likely form a voltage divider
    #3 21670862
    Elly Elisa
  • Identified 30 MΩ resistors in trigger circuit
    #4 21670865
    Elly Elisa
  • Optical slave trigger uses low-voltage sync contact
    #5 21670866
    Elly Elisa
  • Flash output limiting may explain the 30 MΩ resistor
    #6 21670867
    Chuck Sydlo
  • #7 21670868
    Elly Elisa
  • Questioning the 30 MΩ resistor values
    #8 21670869
    Elly Elisa
  • Suggest checking resistor values and circuit schematic
    #9 21670870
    Frank Bushnell
  • Need to identify the resistor color code and circuit role
    #10 21670871
    Elly Elisa
  • #11 21670872
    Elly Elisa
  • #12 21670873
    Frank Bushnell
  • #13 21670874
    Elly Elisa
  • Electronics learning resource links
    #14 21670875
    Frank Bushnell
  • #15 21670876
    Elly Elisa
The discussion centers on the use of very high-value resistors, specifically 30MΩ resistors in series, within optical slave trigger circuits for photographic strobes. These circuits typically include a photodiode (likely a BPW34), an SCR, a capacitor rated at 400V 0.047µF, a 4.7kΩ resistor, and the two 30MΩ resistors. The high resistance is believed to serve in allowing voltage buildup on a capacitor until a threshold triggers the SCR to close the main circuit, discharging the strobe flash. This design enables the optical slave to detect a master flash and trigger the slave flash accordingly. The use of such large resistors may be to handle very low current from the photodiode or to limit current to prevent false triggering, although the exact function remains unclear. Some speculation includes historical resistor labeling conventions, current-to-voltage conversion for low nanoamp signals, or flash output limiting to avoid overexposure. The circuit is pre-digital and encapsulated in resin, complicating analysis. Attempts to verify resistor values by color code are hindered by resin color distortion. The discussion also notes that older strobes can have high voltage at the hotshoe, requiring the trigger circuit to withstand these voltages, while newer strobes operate at lower voltages. The community suggests searching for similar "flash slave" circuits and studying electronics resources to better understand the design principles involved.
TL;DR: Optical slave triggers may use ultra‑high values (e.g., 30 MΩ) because a photodiode can deliver only “a few nanoamps,” so “you need big resistors.” [Elektroda, Mark Nelson, post #21670863]
Why it matters: This FAQ helps DIY photographers and tinkerers diagnose, clone, or improve optical flash slaves without false triggers or damaged gear.
Why would an optical slave use 30 MΩ resistors?
To bias or sense nanoamp‑level photodiode currents and let a small timing capacitor ramp until the SCR triggers. “They used high resistance in the trigger circuit to force the voltage to build in the capacitor.” This raises threshold, improving immunity to ambient light until the flash pulse arrives. [Elektroda, Chuck Sydlo, post #21670864]
Are those parts really 30 MΩ, or are the color bands misleading?
Bands under resin can shift hue; orange, brown, and red may look alike, and pale blue can read as grey. Visual misreads happen often in potted assemblies. Confirm values only by measuring a bare sample; photos alone can deceive. [Elektroda, Frank Bushnell, post #21670870]
How does a basic optical slave trigger actually work?
A photodiode senses the master flash. The circuit drives an SCR that shorts the strobe’s sync contacts, firing the tube. Many units act purely as an electronic switch, not as exposure control. Set the flash to manual when using an optical slave. [Elektroda, Elly Elisa, post #21670866]
What components were observed in the discussed unit?
A photodiode (BPW34‑like), an unreadable SCR, a 0.047 µF 400 V capacitor, a 4.7 kΩ resistor, and two 30 MΩ resistors in series. These appear in both the hotshoe and plug‑type versions shown. [Elektroda, Elly Elisa, post #21670865]
Would a 10 kΩ in place of 2×30 MΩ make it more sensitive?
Yes, but it would likely false‑trigger constantly. The poster saw even 10 kΩ create excessive sensitivity. Very high values help reject ambient light and noise during the brief flash impulse. [Elektroda, Elly Elisa, post #21670869]
Could the “M” marking mean 1,000 (old notation) instead of megaohms?
Historically, “M” sometimes meant 1,000 in the 1930s–40s, later replaced by “K” in the U.S. by the 1950s. However, modern four‑band resistors in photo gear are unlikely to use that convention. [Elektroda, Mark Nelson, post #21670863]
Does this circuit limit flash power (a smart TTL feature)?
No. The described unit is just an “eye” that shorts the sync to fire the flash. It is separate from the strobe’s exposure control. Users typically select manual power when using optical triggers. [Elektroda, Elly Elisa, post #21670868]
What voltages must an optical slave withstand at the sync?
Older strobes can present about 300 V on the hotshoe at discharge; newer isolated designs keep sync potentials at or below 6 V. Design for the higher case to avoid failures. [Elektroda, Elly Elisa, post #21670866]
How can I reduce false triggers in bright daylight?
Add an RC filter across the photodiode or bias network to slow response to steady light. Shade the sensor or use a dark cap to prevent photodiode saturation outdoors. This addresses the common daylight failure mode. [Elektroda, Elly Elisa, post #21670871]
What is an SCR in this context?
An SCR is the solid‑state switch that, once triggered by the sensor network, shorts the strobe’s sync contacts to fire the flash. It latches during the discharge and then resets. [Elektroda, Elly Elisa, post #21670866]
Why do some builders pot the board in clear resin?
Clear resin admits light to the photodiode and makes the device rugged. The downside is difficult diagnosis and rework because components are encased. [Elektroda, Frank Bushnell, post #21670870]
Could those tan, resistor‑shaped parts be inductors instead?
Unlikely in this case. The contributor checked inductor color codes and noted the blue third band didn’t fit. Photos of both units showed consistent resistor coding. [Elektroda, Elly Elisa, post #21670871]
Is there a simple way to prototype a robust optical slave?
Try this: 1) Photodiode feeding an RC to ground to filter ambient light. 2) Bias into an SCR gate with a high‑value network. 3) Wire SCR across the sync to short on trigger. Test indoors and then in sunlight. [Elektroda, Elly Elisa, post #21670871]
Where can I find reference schematics or explanations?
Search “flash slave circuit” to find many variations and explanations. Comparing multiple schematics helps identify the RC timing and SCR gate choices that fit your parts. [Elektroda, Frank Bushnell, post #21670870]
Why not just buy a cheap optical trigger instead of cloning one?
Building your own teaches how sensitivity, RC timing, and SCR selection affect reliability. It also lets you tailor the design to legacy high‑voltage syncs or modern low‑voltage gear. [Elektroda, Chuck Sydlo, post #21670864]
