Identifying Positive and Negative Pins on Laser Diode for Laser Cutter Project
345 6
  • Need diode pinout from diagram
    #1 21671140
    Abram Andreu
  • #2 21671141
    DAVID CUTHBERT
  • #3 21671142
    Abram Andreu
  • #4 21671143
    DAVID CUTHBERT
  • #5 21671144
    Abram Andreu
  • #6 21671145
    DAVID CUTHBERT
  • #7 21671146
    Abram Andreu
A beginner Mechanical Engineering student working on a laser cutter project sought to identify the positive and negative pins on a laser diode to correctly connect it to a driver. The discussion clarified that pins 1 and 2 on the diode are positive terminals, while pin 3 serves as the negative terminal. This pin configuration allows proper soldering of the diode to the driver, ensuring correct polarity for the laser diode operation.
