USB Cable Colors - Identifying Positive (+) and Negative (-) for A4 Mouse Cable DIY Lamp Project
shadow1578 85639 17
How can I identify the + and − wires in a USB cable with unusual wire colors for a DIY lamp project?
You cannot reliably identify USB + and − by those colors alone; either measure the cable with a meter, or test wire pairs with an LED and a 1 kΩ resistor until it lights, which shows the polarity [#9434279] [#9435689] Standard USB power is 5 V, and in a normal USB cable only two conductors are power and ground while the other wires are for data or, in some connectors, an extra unused/shield connection [#9435029] [#9435096] If you do not have a meter, the forum advice was that you will not check it properly without one [#9435161]
  • #1 9434255
    shadow1578
    Rate: 18
    Hello. I don't know if I positioned the topic correctly, but well.
    I have a USB cable from the A4 mouse something like that (I don't know the model because I already threw it away). Well, I want to make a USB lamp, but I have a problem with the cables inside the USB. There are small cables of such colors: blue, green copper, green - copper and blue - copper. Which of them is + and which is -?
  • #2 9434279
    ajpier
    Level 37  
    Help: 363
    Rate: 480
    Measure yourself with a meter.
  • #5 9434532
    shadow1578
    Rate: 18
    Only I don't have any gauge or other miracles. And the Usb type is A. I don't know much about electronics and I just want to make a laptop lamp to illuminate the keyboard in the evening ...
  • #6 9434630
    Elektronik9
    Level 30  
    Help: 21
    Rate: 195
    You can buy such a lamp ready, for example on the Allegro. The USB has a 5V power supply and has a current efficiency of 500mA from what I remember.
  • #7 9434645
    lekto
    Help: 294
    Rate: 299
    it has a minimum of 500mA, I was pulling over 1A but that depends on the motherboard.
  • #8 9434675
    Elektronik9
    Level 30  
    Help: 21
    Rate: 195
    1A to FireWire (IEEE 1394) nominally had. No. USB has a separate power supply so it's true, it depends on the mobo. But 500mA will run smoothly from USB.
  • #9 9434967
    shadow1578
    Rate: 18
    So about these cables: where can + and where - be?
  • #10 9435029
    MarekPPN
    Help: 245
    Rate: 154
    You have 4 wires in the USB cable:
    - live red is +,
    - black vein is -,
    - the rest is transfer.
    USB 2.0 500mA, USB 3.0 900mA. Both 5V.
  • #11 9435089
    shadow1578
    Rate: 18
    Well, but he writes that I have 5 veins: blue, green, green - copper, blue - copper and copper. Well, my question is: Which is + and which is -.
  • #12 9435096
    Elektronik9
    Level 30  
    Help: 21
    Rate: 195
    Some USB connectors (mini-USB, etc.) have 5 pins (including wires). Four perform the primary function (power supply, ground and 2 differential signal cables), and the fifth is largely unused.
  • #13 9435111
    lekto
    Help: 294
    Rate: 299
    or connected to a metal housing.
  • #14 9435161
    MarekPPN
    Help: 245
    Rate: 154
    Since you do not have a meter, you will not check it.
  • #15 9435163
    jankolo
    Rest in Peace
    Help: 1792
    Rate: 587
    Then buy it, borrow it or go to someone who has such a miracle.
    shadow1578 wrote:
    I do not know anything about electronics and I just want to make a laptop lamp to illuminate the keyboard in the evening ...
    I repeat the suggestion above: go to someone who has a gauge and an idea of what he will be doing. I warn you: you will damage your equipment. By the way: can you solder?
  • #16 9435271
    shadow1578
    Rate: 18
    By the way: what should I damage myself? I only work on the cable.
    Yes I can.
    wlw_wl
    Help: 208
    Rate: 148
    Take the LED, solder a 1k? resistor to it and connect it to two cables in various combinations, when it lights up, you found + and -
  • #18 9435939
    jankolo
    Rest in Peace
    Help: 1792
    Rate: 587
    All the necessary answers have already been given. I close the topic.
The discussion revolves around identifying the positive (+) and negative (-) wires in a USB cable from an A4 mouse for a DIY lamp project. The user is uncertain about the color coding of the wires, which include blue, green, copper, and variations thereof. Responses suggest using a multimeter for accurate identification, but alternatives are provided for those without tools, such as connecting an LED with a resistor to test combinations until the correct polarity is found. The standard color coding for USB cables is mentioned, with red typically representing + and black representing -. However, the user notes the presence of five wires, leading to confusion about their functions. The conversation emphasizes caution to avoid damaging equipment during the DIY process.
